Old 08-04-2013, 01:53 PM   #1
TurboRex
Member#: 8635
04 STI, 07 FXT
Default need help with opening image
I need help with opening my stock 2007 forester xt 5mt rom
. i was able to save the stock rom but cant open it. it says it needs ecu definitions but i set up this ecu def in romraider. it took me hours just to try to get everything downloaded so not sure what has been set up right.
thanks
TurboRex is offline   Reply With Quote
Old 08-04-2013, 02:47 PM   #2
TurboRex
Member#: 8635
04 STI, 07 FXT
i can read the rom in ecuflash so getting somewhere just not sure why i cant with rr.
Old 08-04-2013, 04:30 PM   #3
JonnyV2889
Member#: 197384
2006 WRX Ltd
You downloaded the latest defs from romraider forums?
You actually need to point the romraider to the def file location. Did you do that?
JonnyV2889 is offline   Reply With Quote
Old 08-04-2013, 06:03 PM   #4
TurboRex
Member#: 8635
04 STI, 07 FXT
yes, latest version, i pointed down to the subfile A8DK100I.xml.
Old 08-04-2013, 06:16 PM   #5
JonnyV2889
Member#: 197384
2006 WRX Ltd
That not what I was saying. I'm referring to the definitions not the ecu map that you need have referenced.
Old 08-05-2013, 09:36 AM   #6
TurboRex
Member#: 8635
04 STI, 07 FXT
This must be where I am not understanding. I unzipped the ecu definitions file. When I try to set it up as ecu definitions it keeps pointing me to subfiles until I pick one out of the forester xt group. I looked up the name for an 07 forester xt and 1clicked on this file. I thought this odd since I thought you would load the whole file and then let if find the file out of a list.
What am I doing wrong?
Old 08-05-2013, 10:46 AM   #7
JonnyV2889
Member#: 197384
2006 WRX Ltd
Well start from scratch.
Under the ecu def drop down menu click get defs. It will open the romraider thread, scroll to the bottom of the first post, download the zip. Once downloaded unzip to the location of your choice. The file name should say "ecu_defs.XML"
Back under the ecu def drop down menu in RR. Click ecu def man.
Click the add button. Locate "ecu_defs.XML" and click open. Then click save followed by apply buttons.
Old 08-05-2013, 11:18 AM   #8
TurboRex
Member#: 8635
04 STI, 07 FXT
If I recall, when I unzipped the ecu file it read ecu_defs.DTD. I extracted it with windows. I thought this odd and why it had to keep going into subfiles looking for a xml file.
I can try to unzip again but feel it will do the same thing.
Old 08-05-2013, 12:48 PM   #9
JonnyV2889
Member#: 197384
2006 WRX Ltd
Maybe download 7zip or winrar?
I went through the steps as I wrote that last post. I used winrar but I also have 7zip installed.
Hopefully it works?
