Old 08-11-2013, 10:34 PM   #126
awenthol
Member#: 355024
2013 DGM STi Sedan
Originally Posted by 9MMSWORD View Post
Are you using the 3ft or? Does the longer cable effect charge rate? My 2.1a charger in my car won't even charge it fast enough while I'm using it is that normal?
Yes, 3ft. Longer cable shouldn't be problem unless it's a crappy cable.
Sounds to me like you're not actually charging at 2 Amp...there are apps that will tell you what you're pulling for power, from your charger. Off the top of my head, Elixir is pretty good at a LOT of parameters most people don't know are in an Android.
awenthol is offline   Reply With Quote
Old 08-12-2013, 11:01 PM   #127
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
I've tried using two different 2.1 amp chargers for my car as well as the OEM cable and aftermarket cables they all seem to charge very slow if I plug my tablet into the oem Wall charger it charges fast I don't know what the problem is at this point... Any help would be awesome.
9MMSWORD is offline   Reply With Quote
Old 08-12-2013, 11:14 PM   #128
awenthol
Member#: 355024
2013 DGM STi Sedan
Name brand chargers?
Old 08-13-2013, 12:20 AM   #129
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
One is a belkin and the other is a pny' both are the little CIG lighter deals with the USB socket and 2.1 amp.
Old 08-13-2013, 05:02 PM   #130
tinkwithanr
Member#: 360865
Well I know what I'm upgrading the stock stereo to now... Very well done.
tinkwithanr is offline   Reply With Quote
Old 08-14-2013, 12:10 AM   #131
awenthol
Member#: 355024
2013 DGM STi Sedan
Possibly an issue with the cigarette lighter? I hardwired my adapter to the radio's switched source.
Have you tried Elixir to see your charging amperage trying various things?
Old 08-15-2013, 02:29 AM   #132
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
Yes I tried elixr it works on my s4 perfectly, tells me the output I'm getting while charging but does not show on my N7 it only says "-" I've tried two different cig ports in my car both same outcome but my s4 on the same car charger same port charges lightning fast... I think it may be a cable issue? Is the stock n7 cable shorted? I could try it in my car with the same charger
Old 08-18-2013, 11:53 PM   #133
9MMSWORD
Member#: 336162
2013 WRX
Satin white pearl
okay figured it out I got a monoprice 6ft gold plated cable and an anker dual 3.6 amp car charger, the tablet with WiFi GPS and music playing doesn't even go to 99 percent when I'm driving now
Old 08-20-2013, 01:25 AM   #134
AnthonyA182
Member#: 59990
2011 WRX Hatch
great install!
AnthonyA182 is offline   Reply With Quote
Old 08-20-2013, 08:24 AM   #135
bhoostin_sti
Member#: 365966
Nice!!! I like it.
bhoostin_sti is offline   Reply With Quote
Old 09-01-2013, 12:38 PM   #136
awenthol
Member#: 355024
2013 DGM STi Sedan
Here are my tips...
If the tab is ONLY for your car:
1) Install TOUCH recovery (keep from needing access to the vol/pwr buttons)
2) Flash ROM that supports things like expanded desktop
2.1) Remove all apps that are going to be unused (ie, Phone, Gmail, Contacts, Email, etc)
2.2) Install Bluetooth Autoconnect
2.3) Install GMD Gesture Control (eliminate space wasting navigation bar, setup gestures for "back," "home," "recent apps," and ANYTHING else you can think of.
2.4) Set display wake on power
3) Kernel that supports undervolting and Fast Charge
3.1) careful with undervolting
3.2) underclock the CPU considerably---shouldn't need that much power
4) Tasker
4.1) Power On--sees power from USB
a) Bluetooth on
b) WiFi On
c) Set CPU to min/max
d) Screen timeout to 24hrs (max possible) OR install secure settings and turn off timeout
e) Bluetooth Autoconnect Plugin to connect to radio
4.2) Power Off--disconnected from USB
a) Bluetooth off
b) WiFi Off
c) Set CPU to min/min
d) Screen timeout to 7 secs (min possible) OR install secure settings and turn off display
And of course, most importantly is having a 12v charger/cable combo that does 2.1 amp minimum. Just because the charger is 2.1, does NOT mean the cable does! You can check your charging amps with apps like Elixir
Old 09-01-2013, 01:00 PM   #137
AzG22
Member#: 367132
2007 Impreza WRX
Crystal Gray Metallic
Sweet setup!
AzG22 is offline   Reply With Quote
Old 09-02-2013, 12:40 PM   #138
tcoffin014
Member#: 173734
Sexy White Princess
Here are my tips...
4) Tasker
a) Bluetooth on
b) WiFi On
a) Bluetooth off
b) WiFi Off
How do you get tasker to do power on and off? It says that option is not supported on my nexus 7
tcoffin014 is offline   Reply With Quote
Old 09-02-2013, 12:42 PM   #139
Andrew025
Member#: 303408
04 STi
I use this
https://play.google.com/store/apps/d...ettings.plugin
Andrew025 is online now   Reply With Quote
Old 09-02-2013, 02:02 PM   #140
kfaragher
Member#: 367138
Default Amazing job
Jealous!
kfaragher is offline   Reply With Quote
Old 09-03-2013, 08:34 PM   #141
KingMillions
Member#: 367053
2006 Impreza 2.5i
Grey
That is pretty awesome and a cool mod.
KingMillions is offline   Reply With Quote
Old 09-08-2013, 12:40 PM   #142
tcoffin014
Member#: 173734
Sexy White Princess
Originally Posted by Andrew025 View Post
Thanks for that. Works perfect now. Before it would come on sometimes and sometimes not
Old 09-08-2013, 03:57 PM   #143
Andrew025
Member#: 303408
04 STi
Yeah I don't know what's up with it. I had the hardest time making it actually work all the time then out of the blue it just works all the time from then on.
Old 09-08-2013, 04:08 PM   #144
Siress
Member#: 347295
2013 WRX 5DR
Has anyone tried use the Nexus 7's camera as a dash cam?
I've been putting together my tablet install plan for a while now, and would really like to incorporate the dash cam with the setup. I'm leaning more toward a GoPro linked to Android, but if the built in camera works well enough day and night, then it'd be a cheaper setup.
Siress is offline   Reply With Quote
Old 09-08-2013, 06:06 PM   #145
awenthol
Member#: 355024
2013 DGM STi Sedan
How?
IMO, BlackVue dash cam. Android app, tons of features.
I have some screenies and pictures of it in my iwsti journal
Old 09-09-2013, 10:10 AM   #146
ScoobyJD
Member#: 185910
2007 WRX TR
BlackVue rocks!
ScoobyJD is offline   Reply With Quote
Old 10-10-2013, 07:35 AM   #147
carlosb1003
Member#: 370592
Soooo how much would I have to pay you to build me one of these bad boys....no really how much???
carlosb1003 is offline   Reply With Quote
Old 10-10-2013, 12:45 PM   #148
the_ocean
Member#: 329094
In case anyone else got totally confused like me, you can still turn *off* the Nexus 7 (2013) display with Tasker -- just use the System Lock action. Secure Settings is needed to turn it on with power, though.
Also, the ElementalX ROM 1.6 now supports OTG charging, as well as the all-important double-tap or swipe to wake.
Paranoid Android RC2 ROM works with ElementalX 1.6, and allows for fullscreen and pie controls. Versions after RC2 may break with the Nexus 7 due to Cyanogenmod moving away from the AOSP kernel on which ElementalX is based (I believe Paranoid Android uses Cyanogenmod kernel not AOSP).
the_ocean is offline   Reply With Quote
Old 10-16-2013, 12:03 PM   #149
maksusi
Member#: 317947
Where is your head unit? Or you don't have any now?! How did you wire speakers?
Never-mind - I've got your point with Parrot Sorry for spam
maksusi is offline   Reply With Quote
Old 10-16-2013, 12:38 PM   #150
DamnDodgeRams
Member#: 355139
2003 WRX wagon VF28
Mighty Car Mods did the same thing with an iPad in an outback
DamnDodgeRams is offline   Reply With Quote
