Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-22-2013, 06:14 PM   #1651
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Originally Posted by b3delta View Post
No it doesn't change airflow into the motor, but it's simple physics, it's easier for the engine to move with less weight than with more weight. This applies to off the dyno as that's where stuff matters and the car actually moves. Your car can dyno 900000 hp but on the road it could only be 4 hp.
You miss the point entirely which is that the data is a much more accurate indicator of power than a dyno chart. Then you add in some nonsense non sequitur about 900000 dyno horsepower actually being 4 hp which is not actually physics,just nonsense... The motor may accelerate more slowly with a heavier load but that does not change the power it is making to move the load...
Airflow timing boost RPM are not going to vary hugely among motors making similar power. We know what kind of airflow and timing it takes to make given power levels so it's easy to extrapolate from the data what's actually going on. BTW I have a degree in physics and aeronautical engineering...
Power = work/time; so for a given amount of power it will take more or less time to do work which is based on the weight of your car and the acceleration. SO a 300WHP car that weighs 2700 lbs accelerates faster than a car that wieghs 3300 lbs with the same power. Power does not change but the rate of acceleration does which changes the time to do the increased amount of work...
soobaviator is offline   Reply With Quote
Old 02-22-2013, 06:20 PM   #1652
b3delta
Member#: 242814
Midnight Black Pearl
Thank you for the correction on the 90000/4 hp thing, i was thinkin too fast, do that sometimes. hehe
Though things like rotating mass will have an effect on hp.
Thoughts on my #s?
b3delta is offline   Reply With Quote
Old 02-22-2013, 06:42 PM   #1653
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Thoughts on my #s?
It's like holy crap you are logging too many parameters... The log is only to 4.6KRPM. You pull ~194 g/s at that point which is about 260 at the crank if your timing is good. Timing is 14* which ain't that aggressive for 19 psi. It's a long way from 300 at the wheels. You probably actually peaked out at about 300 at the crank which is like 230-240 ATW being optimistic...
On the other hand here is a log from a very aggressive 2.1 stroker
Code:
TIME	G/REV	RPM	TIMING	IDC	IAT	KC	MRP	MAFG/S	MPH
3729	1.12	2343	28.50	9.00	63.00	10.00	0.29	56.83	32
3822	1.12	2342	29.50	9.64	63.00	10.00	0.52	41.92	32
3994	1.13	2398	30.50	9.72	63.00	10.00	0.75	46.21	32
4072	1.11	2424	31.50	9.44	63.00	10.00	0.89	43.40	32
4150	1.15	2366	30.50	9.59	63.00	10.00	1.16	46.37	32
4228	1.17	2446	30.50	9.91	63.00	10.00	1.39	48.57	32
4306	1.20	2444	30.00	10.43	63.00	10.00	1.55	48.75	32
4462	1.20	2441	30.00	10.42	63.00	10.00	1.76	50.61	32
4540	1.23	2495	30.00	10.40	63.00	10.00	1.97	50.79	32
4602	1.24	2473	29.50	10.55	63.00	10.00	2.13	50.79	32
4758	1.27	2502	29.00	10.68	63.00	10.00	2.46	53.80	32
4836	1.28	2541	28.50	11.38	63.00	10.00	2.55	55.45	32
4946	1.27	2540	28.50	11.34	63.00	10.00	2.75	52.92	34
5008	1.31	2554	28.00	11.44	63.00	10.00	3.09	56.63	34
5133	1.33	2606	27.50	12.16	63.00	10.00	3.23	58.04	34
5211	1.35	2615	27.00	12.27	63.00	10.00	3.42	59.20	34
5336	1.37	2624	26.50	12.20	63.00	10.00	3.62	60.79	34
5414	1.41	2645	26.00	12.98	63.00	10.00	3.83	62.57	35
5523	1.45	2672	25.00	13.63	63.00	10.00	4.06	66.17	35
5570	1.51	2706	24.50	13.86	63.00	10.00	4.25	66.65	35
5694	1.51	2719	24.50	14.50	63.00	10.00	4.51	69.65	35
5804	1.52	2755	24.50	14.69	63.00	10.00	4.74	70.60	35
5913	1.55	2771	24.00	14.78	63.00	10.00	4.97	70.37	36
5991	1.56	2799	24.00	15.44	63.00	10.00	5.14	74.43	36
6084	1.56	2804	24.00	15.55	63.00	10.00	5.36	73.48	36
6147	1.57	2833	23.50	15.67	61.00	10.00	5.53	73.95	36
6240	1.59	2860	23.50	15.86	61.00	10.00	5.74	76.11	36
6318	1.61	2904	23.50	15.90	61.00	10.00	5.90	80.16	37
6459	1.63	2926	23.50	16.85	61.00	10.00	6.19	77.53	37
6584	1.65	2939	23.50	16.80	61.00	10.00	6.38	83.24	37
6677	1.65	2957	23.50	17.03	61.00	10.00	6.57	81.83	37
6786	1.69	3016	23.50	17.22	61.00	10.00	6.77	83.01	39
6849	1.68	3012	23.50	17.99	61.00	10.00	7.00	82.29	39
6958	1.71	3068	23.50	18.21	61.00	10.00	7.21	88.33	39
7036	1.71	3064	23.50	18.30	61.00	10.00	7.39	89.51	39
7161	1.75	3100	23.50	18.52	61.00	10.00	7.60	87.35	39
7254	1.76	3117	23.50	19.28	61.00	10.00	7.81	93.29	40
7395	1.79	3162	23.00	19.56	61.00	10.00	8.04	93.04	40
7442	1.80	3198	23.50	19.54	61.00	10.00	8.31	95.60	40
7520	1.81	3194	23.50	20.44	61.00	10.00	8.53	97.15	40
7660	1.87	3238	22.50	20.69	61.00	10.00	8.82	101.84	40
7754	1.87	3270	22.50	20.93	61.00	10.00	9.17	99.71	42
7878	1.93	3299	22.50	20.99	61.00	10.00	10.00	107.27	42
8003	1.97	3327	22.50	22.71	61.00	10.00	9.86	108.91	42
8034	2.01	3351	22.00	22.80	61.00	10.00	10.33	113.91	42
8112	2.11	3412	21.00	24.02	61.00	10.00	10.98	118.49	42
8331	2.20	3426	20.00	24.65	61.00	10.00	11.62	129.24	44
8409	2.39	3490	17.50	28.29	61.00	10.00	13.05	138.04	44
8471	2.28	3467	18.50	26.63	61.00	10.00	12.24	130.55	44
8580	2.61	3554	16.50	31.09	61.00	10.00	15.01	155.76	44
8612	2.48	3524	16.50	30.07	61.00	10.00	13.92	147.27	44
8814	2.85	3618	14.50	34.73	61.00	10.00	17.29	173.12	47
8939	2.73	3612	15.50	32.00	61.00	10.00	16.05	168.97	47
8970	2.96	3671	13.50	35.99	61.00	10.00	18.56	186.32	47
9017	3.12	3724	12.00	38.93	61.00	10.00	19.92	195.69	47
9064	3.21	3767	11.50	39.94	61.00	10.00	20.96	201.91	47
9220	3.32	3852	11.50	43.55	61.00	10.00	22.18	212.28	48
9282	3.44	3898	11.50	43.60	61.00	10.00	23.30	226.48	48
9392	3.52	3894	11.50	46.52	61.00	10.00	23.96	232.56	48
9470	3.57	4000	11.50	48.28	61.00	10.00	24.69	239.60	48
9501	3.67	4034	11.50	49.92	61.00	10.00	25.25	253.76	48
9641	3.72	4120	11.50	50.37	61.00	10.00	25.68	257.05	51
9766	3.77	4148	11.50	52.21	61.00	10.00	25.93	260.33	51
9797	3.80	4178	11.50	52.59	61.00	10.00	26.09	261.97	51
9875	3.76	4271	11.50	53.75	61.00	10.00	26.10	264.72	51
10000	3.81	4300	11.50	55.04	61.00	10.00	26.10	277.20	51
10094	3.79	4409	11.50	54.44	61.00	10.00	26.10	281.51	55
10203	3.73	4440	12.00	55.89	61.00	10.00	25.81	280.43	55
10328	3.73	4515	12.00	55.47	61.00	10.00	25.47	281.51	55
12324	3.73	4515	12.00	55.47	61.00	10.00	25.47	281.51	55
now at 4.5K this motor is flowing 45% more air and a bit less timing, lower IAT than your car. If your car was putting up 300WHP then this motor was making 430+ on a small 16G with an EWG? je pense que non....
You made an assumption that crank HP = WHP which therein lies your problem..
Old 02-22-2013, 06:48 PM   #1654
b3delta
Member#: 242814
ahh, saw what I did, updated my post with the full log
...and i know the dif between chp and whp. lose about 25% through the awd train
Old 02-22-2013, 06:58 PM   #1655
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
I'll give you credit for posting a 250-260 WHP log... No way it approaches 300WHP.
Same car, small 16G, and it would make 300WHP on almost any dyno. Actual power between 300 and 320 ATW. A little less aggressive on top AFR's 12.1 peak torque and 11.9 at power peak. It's a small 16G so notice how it's pretty much all packed up and done by 5.8KRPM with this boost curve.
Code:
TIME	G/REV	RPM	TIMING	IDC	IAT	MRP	MAFG/S	MPH
234	1.09	2654	42.50	9.63	70.00	0.66	54.03	35
343	1.16	2676	31.00	10.84	70.00	1.12	53.29	35
437	1.20	2676	32.00	11.42	70.00	1.35	54.37	35
561	1.23	2704	31.50	11.53	70.00	1.88	56.09	35
655	1.25	2736	30.50	12.26	70.00	2.13	58.92	35
764	1.28	2733	30.00	12.41	70.00	2.51	59.76	36
873	1.32	2763	28.50	12.97	70.00	2.92	60.96	36
967	1.35	2804	28.50	13.15	70.00	3.29	63.67	36
1029	1.37	2831	27.50	13.29	70.00	3.65	64.01	36
1092	1.40	2836	27.00	13.92	70.00	4.08	68.00	36
1217	1.43	2858	25.50	14.02	70.00	4.41	68.19	37
1310	1.45	2876	25.00	14.72	70.00	4.78	71.31	37
1419	1.49	2934	24.00	15.02	70.00	5.16	72.04	37
1513	1.51	2949	23.50	15.73	70.00	5.57	74.79	37
1607	1.55	2958	23.50	15.78	70.00	5.98	77.12	39
1716	1.59	3012	23.50	16.71	70.00	6.28	81.48	39
1763	1.61	3030	23.50	17.45	70.00	6.65	82.31	39
1887	1.65	3075	23.00	17.71	70.00	7.10	86.28	39
1997	1.69	3098	23.00	18.50	70.00	7.58	88.76	39
2059	1.73	3133	23.00	19.38	70.00	7.97	92.63	40
2137	1.77	3129	23.00	20.18	70.00	8.45	94.44	40
2277	1.83	3194	22.50	20.44	70.00	8.97	95.57	40
2387	1.88	3200	22.50	22.05	70.00	9.48	102.53	40
2433	1.92	3265	22.50	22.29	70.00	10.04	104.80	40
2527	2.00	3254	22.50	22.90	70.00	10.62	110.80	42
2652	2.05	3311	21.50	24.02	70.00	11.12	114.25	42
2761	2.13	3354	21.00	25.04	70.00	11.87	122.64	42
2855	2.21	3386	20.00	26.00	70.00	12.68	124.53	42
2964	2.31	3414	20.00	26.94	70.00	13.44	134.59	42
3057	2.40	3498	19.00	29.10	70.00	14.46	140.27	44
3167	2.52	3490	17.50	30.52	70.00	15.55	151.25	44
3198	2.63	3558	17.00	32.64	70.00	16.86	157.29	44
3291	2.75	3592	15.50	33.71	70.00	18.18	171.48	44
3416	2.85	3628	14.00	36.75	70.00	19.32	177.59	44
3510	2.96	3685	13.00	37.74	70.00	20.52	183.37	47
3603	3.04	3738	12.50	39.70	70.00	21.50	193.67	47
3728	3.11	3815	12.00	40.69	70.00	22.33	198.73	47
3822	3.16	3850	12.00	42.71	70.00	22.95	205.79	47
3931	3.21	3910	12.00	43.37	70.00	23.42	209.69	47
4025	3.24	3912	12.00	44.23	70.00	23.42	220.56	49
4103	3.27	3994	12.00	46.01	70.00	23.75	220.63	49
4181	3.31	4100	12.00	46.36	70.00	23.86	225.56	49
4290	3.32	4180	11.50	48.16	70.00	23.94	231.68	49
4337	3.33	4150	11.50	48.70	70.00	23.73	233.04	49
4493	3.36	4242	11.50	49.77	70.00	23.90	239.84	52
4555	3.35	4308	11.50	49.63	70.00	23.65	242.11	52
4680	3.32	4360	11.50	50.23	70.00	23.47	244.36	52
4758	3.32	4391	11.50	50.58	70.00	23.20	244.81	52
4867	3.28	4440	12.00	50.57	70.00	22.97	246.61	52
4976	3.27	4568	12.00	50.67	68.00	22.70	245.27	57
5070	3.24	4537	12.00	50.33	68.00	22.49	248.85	57
5179	3.23	4601	12.50	51.04	68.00	22.26	251.55	57
5210	3.23	4708	12.50	52.23	68.00	22.10	252.45	57
5351	3.21	4774	13.00	52.96	68.00	21.85	253.79	57
5429	3.20	4765	13.00	52.86	68.00	21.64	255.13	60
5522	3.20	4820	13.00	52.44	68.00	21.58	259.17	60
5616	3.20	4892	13.00	54.27	68.00	21.33	260.96	60
5756	3.19	4947	13.00	54.88	68.00	21.25	262.31	60
5834	3.19	5010	13.00	55.57	68.00	21.08	267.69	60
5897	3.19	5081	13.00	56.37	68.00	21.10	269.53	64
6068	3.19	5092	13.00	56.48	68.00	20.96	271.84	64
6224	3.20	5194	13.00	58.06	68.00	20.77	278.83	64
6287	3.17	5282	13.00	57.46	68.00	20.63	278.83	67
6396	3.15	5326	13.00	57.95	68.00	20.44	278.35	67
6505	3.15	5357	13.50	58.28	68.00	20.32	280.21	67
6614	3.13	5423	13.50	59.00	68.00	20.13	283.47	67
6708	3.11	5442	13.50	59.21	68.00	19.97	282.55	67
6817	3.09	5506	13.50	58.73	68.00	19.72	283.01	70
6911	3.09	5564	13.50	59.34	68.00	19.47	287.20	70
6957	3.07	5576	13.50	59.48	68.00	19.20	286.73	70
7051	3.04	5601	14.00	59.74	68.00	18.97	285.80	70
7207	3.03	5656	14.00	59.12	68.00	18.64	288.12	70
7269	2.99	5699	14.00	59.57	68.00	18.27	286.73	74
7347	2.99	5742	14.00	60.03	68.00	18.04	287.65	74
7488	2.95	5791	14.50	60.54	68.00	17.71	285.80	74
7550	2.96	5846	15.00	59.86	68.00	17.58	288.59	74
7675	2.92	5943	15.00	60.85	68.00	17.27	288.12	74
7737	2.89	5943	15.50	60.85	68.00	17.00	289.52	77
7800	2.89	5943	15.50	60.50	68.00	16.67	289.52	77
7971	2.84	6034	15.50	59.21	68.00	16.18	284.40	77
8018	2.81	6082	16.00	59.69	68.00	15.88	284.40	77
8127	2.77	6082	16.00	59.69	68.00	15.28	284.40	77
8268	2.72	6162	16.50	59.16	68.00	14.72	281.15	80
8315	2.69	6168	17.00	57.89	68.00	14.46	276.03	80
8408	2.67	6168	17.00	58.81	68.00	14.04	277.43	80
Old 02-22-2013, 07:05 PM   #1656
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Then you understand that you are nowhere near 300WHP of airflow regardless of what any dyno chart says.
Old 08-13-2013, 01:36 AM   #1657
04BlackRexWagon
Member#: 364412
Default blouch 19t
Im doing this upgrade this month to my 2.0l i talked to mike and he said depending on this shape of it condition wise it goes anywhere from $400-$500 you send your turbo in and they rebuild it really its a great deal!
04BlackRexWagon is offline   Reply With Quote
Old 08-14-2013, 11:30 AM   #1658
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Mike who were are you sending it?
Ry-
labcoat is offline   Reply With Quote
Old 09-29-2013, 06:06 PM   #1659
ForesterWTi
Member#: 173892
2005 3.0R SpecB 1of1
grandma gold
WICKED! I started this thread (well actually the "PT Monstah" TD04 turbo with 19T compressor and TD04H hotside part of it) in what seems like a lifetime ago... it's nice to know it's still killing it. Happy conceptual designing and wrenching (always in that order)
BTW: I sold my GF8 that put down 262.5 awhp cf:1.28 (posting #1300) with this turbo about 3/4 years ago to a friend and the motor is currently being rebuilt and slightly built-up (excited!) due to high mileage but the turbo is still running like a champion --- NO FLAWS or FAILURES AT ALL.
ForesterWTi is offline   Reply With Quote
Old 10-13-2013, 05:11 PM   #1660
Leafy
Member#: 330625
2006 WRX
Well I'm going to pick up a blown up 2008 wrx turbo this week. It needs a new comp wheel and housing. So its going to be getting a Kinugawa billet 19t wheel and comp cover and STS turbine wheel and rebuild it. I should be all in for under $500. Kinugawa claims there that their billet comp wheel flows enough air to support 30% more power than the 13t. So that would put my car into the 300hp neighborhood, especially with the STS turbine wheel, which should be the highest flowing and lightest turbine wheel that fits in the 6cm housing.
Old 10-14-2013, 10:36 AM   #1661
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
^^ Cool!
They also balance the whole rotating mass for that price?
Is it a 'send-in your old unit and receive the upgraded one a few eeeks later'- deal?
Beetspeed is offline   Reply With Quote
Old 10-14-2013, 10:38 AM   #1662
Leafy
Member#: 330625
2006 WRX
Originally Posted by Beetspeed View Post
^^ Cool!
No, this is I order a bunch of parts and lay them out on my tool bench and a couple hours later I have a rebuilt turbo. That I need to take to a local balancer to get balanced. Though I'm considering not having it balanced since the components are neutrally balanced individually, so in theory there is only a very minute chance they wont be within acceptable balance when put together. This is the reason I bought an 08 td04 so I wouldnt have to machine the center housing for the larger exducer of the 19t wheel.
Old 03-14-2014, 03:28 AM   #1663
VWci
Member#: 260436
2003 EDM WRX
JBP
Nowadays i am seeing TD04L-20T option and TD04HL-20T option as well... It is getting bigger and bigger...
VWci is offline   Reply With Quote
Old 03-14-2014, 06:36 AM   #1664
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
any updates from folks?
Old 03-14-2014, 07:20 AM   #1665
Leafy
Member#: 330625
2006 WRX
Still isnt helping the 6cm turbine housing
Old 06-12-2014, 07:31 AM   #1666
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
How reliable are these td04 19t's? and what are reliable shops that can build them from a stock td04?
shamrock 05 is offline   Reply With Quote
Old 06-12-2014, 07:45 AM   #1667
Leafy
Member#: 330625
2006 WRX
Yes. I pulled the 08wrx td04 apart, its not a 19t. CHARA is only machined to 56mm and not 59.7 (IIRC thats the right size for the 19t). The wheel almost seems like its a 15t rather than a 13t though because its a bit big. I think I'm just going to double check the wheel, buy a new stock wheel and a rebuild kit and then just ebay it away as a rebuilt td04.
Old 06-13-2014, 01:32 AM   #1668
Spec R
Member#: 187752
99 RS/X5/Volt
Reliable as stock, as the rebuilds use stock. check out Blouch Turbo. the 19T rebuild isnt on their website but they still do them.
Spec R is offline   Reply With Quote
Old 06-13-2014, 09:15 AM   #1669
konmann
Member#: 125466
2006 WRX TR
SGM
For those interested I've got one for sale in the Nasioc classifieds. I had the 19t on an 06 2.5l engine for ~15000 miles. It performed well. Dyno results are in EFI Logics dyno database under Konrad Mann. Search my username to locate the 19t f/s classified.
Regards
Konmann
konmann is offline   Reply With Quote
Old 07-29-2014, 12:37 PM   #1670
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
I'm currently running a TD04-20T. Bought a used TD04-13T and then converted it using the Kinugawa 20T kit. Works good. Running on home tune at the moment and will need to get it on a dyno for real numbers.
IheartAWD is offline   Reply With Quote
Old 07-29-2014, 01:02 PM   #1671
Leafy
Member#: 330625
2006 WRX
Who did you have machine the bearing housing? Or are the now selling a 13t upgrade that has the same back plate size as the 13t.
Old 07-31-2014, 01:20 AM   #1672
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
I had a local machine shop machine the bearing housing to work with he 20T wheel.Then I rebuild it using an eBay kit and then ported/polished it. This one is using an 04 WRX TD04, so I believe its just TD04-20T. Not HL. I do have the original 13T housing if that's what you're asking about. I'll post the DIY when I get a chance.
I am actually selling a spare TD04 that I have. Could perform the conversion+PnP+Rebuild if anyone wants it.
I love the way it perform so much, that I might pick up their TD04HL-20T for a little added power.
Old 07-31-2014, 07:22 AM   #1673
Leafy
Member#: 330625
2006 WRX
ok, cool. Supposedly there is a company making upgrades for one of the volvo compressor sizes like the 15t or something that are designed to drop onto the bearing housing without machining. Now that would make a nifty upgrade. I've got a 13t from an 08 wrx just chilling in pieces after finding out that the rumors werent true and its not a 19t.
Old 07-31-2014, 12:19 PM   #1674
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
why not take it apart and see? The intake end diameter and wheel diameter should be able to tell you if it is indeed a 19T.
Old 07-31-2014, 12:25 PM   #1675
Leafy
Member#: 330625
2006 WRX
Well, I mean its in pieces on my work bench because I pulled it apart to measure the exducer... It needs a rebuild and a new comp wheel and one of the typical broken 08 wrx bolts extracted then I'll probably ebay it.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
