Old 08-16-2013, 04:08 AM   #1
m0t1v4t3
Member#: 290579
2005 WRX STi
Default Insight needed
I've been having an issue with my 05 STi, the IAM's won't come up to 1, they're sitting at .875. I did some logging today but ended up with a lot of USBSER.SYS bsods on my laptop so I only have 1 good log. To make it worse I missed throttle opening angle parameter so I don't know how useful it is without that. If I need to make another log please let me know.
I had new stock injectors installed along with a DW200 fuel pump about a month ago. I also removed the in-tank fuel filter and relocated it up front like it was in 04 by the washer fluid. No other power mods. Its idling and accelerating smoother than it was but still IAM's won't go back to 1 and I'm concerned.
Does this log provide any insight as to what might be wrong? I see knock, but is there anything else that might provide a clue as to why it would run lean? On a previous road test with a local tuner a large AFR dip was observed on multiple WOT pulls but they were unable to provide any insight as to why. Any help is appreciated.
romraiderlog_20130815_223120_4th_Pulled_Over
XML LOG: here
Thanks!
m0t1v4t3 is offline   Reply With Quote
Old 08-16-2013, 12:38 PM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
Are you on a stock map? Are you tuned? The table is a f'd up on my phone not being in .XML format. Either you are seeing true knock or you have something loose in the engine bay to only be able to get IAM to .875.
JonnyV2889 is offline   Reply With Quote
Old 08-16-2013, 06:11 PM   #3
m0t1v4t3
Member#: 290579
2005 WRX STi
Stock map, not tuned. I'll see what I can do to get a log in .XML.
Thanks!
Old 08-16-2013, 07:01 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Thanks!
heres an idea... let google convert the document.
Old 08-16-2013, 08:34 PM   #5
m0t1v4t3
Member#: 290579
2005 WRX STi
Not your first rodeo, eh?
XML Link is in the original post.
Thanks.
Old 08-16-2013, 11:10 PM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I would suggest finding someone else with a good running car and swapping MAF's.
Can you log "final fueling" its available in my 07, that's why I ask.
