Old 06-05-2013, 03:12 PM   #126
gizmotron2030
Member#: 145183
2011 BMW M3
This thing is going to an interesting beast! Can't wait to see the end product
gizmotron2030 is offline   Reply With Quote
Old 06-05-2013, 03:30 PM   #127
rjh2pd
Member#: 317329
2003 Legacy
Looks good! does the H6 use a timing chain?
rjh2pd is offline   Reply With Quote
Old 06-08-2013, 11:34 PM   #128
kha-khees
Member#: 351930
certainly does.
What's the plan for wiring/ECU? ... also, are there any engineering issues in tas or are you just going to play dumb on notifying any rta? :P
kha-khees is offline   Reply With Quote
Old 06-09-2013, 05:20 AM   #129
vicious_fishes
Member#: 158864
2003 SOHC destroker
started to get stuck into the wiring today:
first came the dash etc:
then into more of it like the heater & stereo wiring & so forth:
and the real horrors behind the steering wheel:
finally all out. good 50kg of wiring in this car i reckon. absurd.
kha-kees: not sure mate. i'd like to get it engineered etc but i'm without doubt going to have a CEL and i don't think it can be passed if it has a CEL. if it can then all will be sweet but that's something i need to find out.
Old 06-09-2013, 09:28 AM   #130
kha-khees
Member#: 351930
well if it's the light itself... possible to disguise it? Disconnect that diode temporarily? hah.
I haven't looked into the registration side of things yet as I'm not close to doing the swap at all (a serious project ahead in my mind though) but I was more concerned about having an engineer sign off on the completely different engine in the car, despite using stock mounts etc.
If that's a fireplace in your garage I truly am jealous.
Old 06-09-2013, 10:51 AM   #131
vicious_fishes
Member#: 158864
2003 SOHC destroker
the size of the engine is all good. for N/A, you can do weight of car in KG*5=CC of engine capacity (so a 1000kg car can have a 5.0L engine) and for forced induction you can have weight of car in KG*3=CC of engine capacity, so a 1000kg turbocharged car can have 3.0L engine.
at least, that's last time i checked. you also have to upgrade the brakes/suspension to whatever the engineer signing off on it tells you. some have been forced to upgrade to the full brembo setup, others have gotten away with stocko's. i'm going to install the brakes that came on the front cut (the car that the engine was originally in), which are the 294x24mm rotors that the rexxy 4pots come with except with a bracket for 2pot calipers, and then the FHI 2pot rears. considering that the car that the engine came in is heavier, i don't foresee a problem. fingers crossed!
yes that is a fireplace in my garage. god knows, i need it. it's the only thing set up in the whole thing that actually makes sense. this is my old mans shed and my old man (indeed, both my parents) are f**king morons. the amount of ****e they have managed to gather over the years is incredible. you should see the pile of car parts, old oil, just scrap BS outside the shed that i was quite adamant we'd need a skip for... but nope. that would be easy
so instead there's just a giant pile of ***** outside, to go with all the crap inside that he refuses to throw away. there's an entire skipload of crap just in the shed alone.
Old 08-16-2013, 03:12 PM   #132
vicious_fishes
Member#: 158864
2003 SOHC destroker
parallel fuel rails and throttle body coolant bypass:
binned the AC
something's missing here
oh yes, that's right...
which can only mean...
Old 08-17-2013, 08:35 AM   #133
vicious_fishes
Member#: 158864
2003 SOHC destroker
well mechanically speaking, it's in.
just!
and a shot of how i routed the oil cooler lines. will get better snaps tomorrow. OEM header was bolted up just to ensure clearance (won't be running it):
Old 04-22-2014, 06:02 PM   #134
Nthads
Member#: 288350
'03 Forester XS
Java Black two tone
Bringing this back from the dead...slightly...
Looking good dude!
I should be up and moving forward with your old gear in 3 weeks finally have everything i needed!
Nthads is offline   Reply With Quote
Soccer05 Bugeye GTX3071 ej205 Street/Track Build Thread soccer05 Member's Car Gallery 652 08-03-2016 05:59 PM
DutchOven's Daily-driving, 2010 SWP WRX Track Slut build & showoff thread. DutchOven Member's Car Gallery 132 12-20-2013 09:23 PM
FS : Varis Half Carbon Front Lip 04-05 WRX, STI **Track Warrior Scars Included** rey_vibora Exterior/Styling 47 02-23-2012 06:51 AM
('08-'10) My car history and small build thread of 09 LR Impreza 2.5i 5mt! sl0wbaru Impreza Forum 4 10-04-2011 05:36 PM
Finally got my ej207, here is my build thread! Cyclops Built Motor Discussion 77 11-04-2009 11:19 AM
