Old 08-14-2013, 09:04 PM   #1
danger1138
Member#: 279525
04 rex luger!
So today i went to clean my MAF, so i disconnected the two small screws and disconnected the connection and pulled the maf right out. The reason i went to clean it was cuz i was seeing high positive LTFT's.
So back to the maf, cleaned it, screwed it back on the intake, then went to turn on the car.. Wait, i forgot to plug in the maf connection. So the car turned on but obviously with a CEL (maf low input). Turned car off and opened the hood, plugged in the maf. All systems a go..
Now i have this annoying CEL on. Will it go away on its own after a few miles? Btw i can clear the codes with the AP, but choose not to cuz i wanna see if changing the o-ring on maf solved my high positive fuel trim issue.
danger1138 is offline   Reply With Quote
Old 08-15-2013, 04:07 AM   #2
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Clearing codes and reseting ecu are two totally different things. Clearing the code will not erase any other data.
Cathexis is offline   Reply With Quote
Old 08-15-2013, 06:38 AM   #3
danger1138
Member#: 279525
04 rex luger!
Well with the cobb ap the only way to clear codes is to reset.
Old 08-15-2013, 01:35 PM   #4
jthatch12
Member#: 321715
03 Big 16G WRX
Unplug your negative battery terminal for 10 minutes or use learning view if you have a tatrix.
Old 08-15-2013, 01:40 PM   #5
danger1138
Member#: 279525
04 rex luger!
But that method of unplugging the negative side of battery will reset my ecu, which i dont want to do. Ill just wait and see what happens
Old 08-15-2013, 02:17 PM   #6
jthatch12
Member#: 321715
03 Big 16G WRX
Originally Posted by danger1138 View Post
But that method of unplugging the negative side if battery will reset my ecu, which i dont want to do. Ill just wait and see what happens
Oh well just drive around with the CEL light on. After xxxx amount of miles of normal operation with your MAF plugged in, it'll clear itself.
Old 08-18-2013, 11:39 AM   #7
danger1138
Member#: 279525
04 rex luger!
Well never found the answer to my question. Just went ahead and reset the ecu.
Old 10-24-2013, 01:56 PM   #8
Nickfree
Member#: 370420
2013 WRX
Dark Gray
I have the same problem, I'm thinking a simple ECU reset will do the trick.
Nickfree is offline   Reply With Quote
