Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 08-04-2013, 03:38 PM   #1
xHairyBuffalo
Member#: 239576
2010 463WHP
Stock 5-speed
Default 93/E85 injectors for FP Red?
I'm currently running a 93 tune on my FP Red WRX with 1000cc injectors. I was previously running a dual fuel 93/e85 tune on the 1000s, but that was on the VF-52. I was told my injectors would be too small to make any significant gains on e85 since the FP Red is so much larger, so I opted out of the e85 tune. Now, I plan on going back to a 93/e85 dual fuel tune. So, my question is this:
What would the ideal injectors/size be to run a 93/e85 dual fuel tune for an FP Red, with a Walbro 400e85 pump? I would like for them to be big enough to not limit the power of the FP Red, but still be drivable on 93. My tuner is recommending five-0 1400cc, but Im pretty sure that's only because they have a contract with them... I've seen posts about them having horrible drivability and constant mis-fires. Thanks!
xHairyBuffalo is offline   Reply With Quote
Old 08-04-2013, 03:50 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Find some id1300s i believe they are out now
Im scared of all injectors but id because horror stories from other brands then them lately. Im not sure about Five-O but at least they didnt suggest DWs lol.
Shortpersonbk is offline   Reply With Quote
Old 08-04-2013, 05:13 PM   #3
xHairyBuffalo
Member#: 239576
2010 463WHP
Stock 5-speed
Wow, thanks for the heads up. Those ID1300s look perfect for my setup, exactly what I was looking for. Thanks!
Old 08-04-2013, 05:35 PM   #4
bjohnson_55
Member#: 216580
+1 for the ID1300's. Just a good as the ID1000's. Don't waste your money on anything else.
bjohnson_55 is offline   Reply With Quote
Old 08-18-2013, 04:59 PM   #5
Bizko1288
Member#: 151260
2011 BMW 135i
__________
You could save some money and just bump your fuel pressure to get more CC out of your ID1000s. That is the route I am going. ID1300s are so expensive, and I was told you can still only get them from T1.
I have an FP Red and am installing ID1000s next week to run E85 and plan on doing just that.
I'll bump this thread once I log what my duty cycles are at higher pressures
Edit: It worked for this guy.
http://forums.nasioc.com/forums/show....php?t=2453554
Bizko1288 is offline   Reply With Quote
