Old 08-15-2013, 01:49 PM   #1
2JZ
Member#: 291949
Default Going to Drag Strip for First time... advice?
3267 pounds 2005 wagon with full JDM EJ207 STi swap. Revs to 8000rpm. Makes boost instantly and responds instantly. 7-8k I feel is slower and so does my tuner. I usually shift at 7k.
I own a set of V12 ventus tires (garbage can't hook on the street for ****)
and Hankook Z214 racing slicks for autocross.
Thinking of trying on street tires first.
My car makes almost 300whp and has an upgraded 'stage 2' exedy clutch. Launching on the street burns out all 4 tires.
I have DCCD Pro as well. What setting should I have the car set to launch it?
So any advice on how to learn to launch at the track? Do you generally drop from higher rpms than on the street? Do you slip the clutch a lot more? Can you slip/launch without making it smell?
2JZ is offline   Reply With Quote
Old 08-15-2013, 02:27 PM   #2
Subarudunk
Member#: 179439
2004 STI
JBP
I would say to try on your street tires first. When I went to the track I launched at around 4800 and then 5300 rpm. I try to blip the throttle around that area and then take off at the light. I was never concerned about my reaction time just my 60ft and 1/4 mile time. I'm assuming you have a 6 speed. I am not sure if the jdm gearing is similar to the 04 Sti but if it is you will have to shift into fifth before crossing the line. I would also slip the clutch until it catchs and then floor it.
This is just from personal experience but I have found that pressing yourself into the back of the seat really helps with the launch.
Good luck!
Subarudunk is offline   Reply With Quote
Old 08-15-2013, 04:56 PM   #3
urfsin
Member#: 128975
2005 Outback XT
Golden Thunder
Drive it like you stole it! :-0
urfsin is offline   Reply With Quote
Old 08-15-2013, 08:48 PM   #4
hkerekes
Member#: 66310
2015 korean muscle
My only advice is skip the drag strip and take the car to a track day.
hkerekes is offline   Reply With Quote
Old 08-16-2013, 12:22 AM   #5
2JZ
Member#: 291949
PWN3D
I go all the time including autocross. Just wanted to go with.some friends once and get my slips
Old 08-17-2013, 03:44 PM   #6
hkerekes
Member#: 66310
2015 korean muscle
Then my second point of advice is run whatever that will break less parts.
Old 08-17-2013, 04:37 PM   #7
Indocti Discant
Member#: 138000
L Bo Hope you meet
the spirit in the sky
its JDM right? to get the most out of it you must shift with your left hand.
Indocti Discant is offline   Reply With Quote
Old 08-18-2013, 08:24 PM   #8
2FastEj207
Member#: 365812
Try launching first and just see what happens. The biggest thing is trying to be consistent and understanding what the small changes with launch rpm and shift points do to your times.
Try to keep a record of when you shift and launch and compare it to your trap speed and time. You'll start to see a correlation between changes either working or not. Then just follow that course of action.
2FastEj207 is offline   Reply With Quote
