Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 08-20-2013, 08:43 AM   #1
Italiano
Member#: 2137
a 6spd Manual
Acura
Default Ferrari 458 Speciale
Ferrari 458 Speciale speeds toward Frankfurt
By Noah Joseph
Posted Aug 20th 2013 7:22AM
the Ferrari 458 Speciale – the successor to the 360 Challenge Stradale and 430 Scuderia, and the hard-core version of the 458 Italia.
the award-winning, high-revving 4.5-liter V8 has been retuned to deliver 605 cv (596 hp by our standards), up from 562 hp in the standard 458, while torque remains the same at 398 lb-ft. But the other side of the power-to-weight ratio (quoted at 2.13 kg/cv) is the extra mass Ferrari has cut out of the equation: the 458 Speciale's dry weight is quoted at 1,290 kg (2,844 lbs), representing a significant drop from the 458 Italia's 1,485 kg (3,274 lb) curb weight.
Adaptive aerodynamics – which Ferrari plans on integrating into all future road cars – further help the 458 Speciale run to 62 mph in 3 seconds flat and to 124 mph in 9.1 seconds. It's also said to lap Fiorano in 1:23.5, half a tick behind the twelve-cylinder F12 Berlinetta. The engineers in Maranello have also cooked up a new Side Slip Angle Control system that interfaces with the electronic differential to help it handle on the limit, with specially-developed Michelin Pilot Sport Cup 2 rubber to help the Speciale grip at 1.33 g in lateral acceleration.
http://www.autoblog.com/2013/08/20/f...ankfurt-debut/
http://motori.corriere.it/motori/mot...39d609c3.shtml
Daniele Sparisci
20 agosto 2013 | 12:39
Italiano is offline   Reply With Quote
Old 08-20-2013, 10:56 AM   #2
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Sad for the loss of the triple tail pipe, but man does that look good!
Old 08-20-2013, 01:13 PM   #3
Pre
Member#: 139693
CEO- 5dr Mafia
Rear diffuser is sick!
Old 08-20-2013, 01:37 PM   #4
WRXHillClimb
Member#: 206907
2014 EvoX GSR
^ An actual diffuser with fins instead of a hunk of black plastic marketed as a "diffuser"
WRXHillClimb is offline   Reply With Quote
Old 08-20-2013, 01:39 PM   #5
delongedoug
Member#: 124113
and beyond!
A 430 Scuderia showed up at my last track event and it was insane. I'm sure the diffusers cost more than my car. The sound is obviously orgasmic. I expect more of the same with the 458.
delongedoug is offline   Reply With Quote
Old 08-20-2013, 04:18 PM   #6
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Comparing dry weight to curb weight is kinda dirty isn't it? Makes the weight savings look bigger than it is. Though that's still impressive...
OrbitalEllipses is offline   Reply With Quote
Old 08-20-2013, 04:53 PM   #7
delongedoug
Member#: 124113
and beyond!
It is, but at least they clarified it. For that much power and everything that power requires, it's a crazy low weight!
Old 11-11-2013, 11:01 AM   #8
torquemada
Member#: 128484
2006 EDM WRX STI
Old 11-11-2013, 07:07 PM   #9
torquemada
Member#: 128484
2006 EDM WRX STI
Those look like fast stripes…
Oh yes. This is the 458 Speciale, successor to the 360 Challenge Stradale and 430 Scuderia, two of Ferrari's best – and stripiest – cars ever. It's not a limited edition and not a replacement for the 458 Italia. It's an additional, more hardcore 458.
Is it as fast as it looks?
How about 0-62 in three seconds dead? It's rocketed along by a 4.5-litre naturally-aspirated V8 that makes an astounding 605bhp. It can corner at 1.33g, where an Enzo managed a not-piffling 1.1g. It's caressed onto the road by about 210kg of downforce at 125mph.
How do they do that?
A weight cut, for a start: it loses 90kg thanks to a some even more rinky-dink alloys in the all-aluminium structure, a lighter roof, lighter intake system (carbon-fibre airbox), more skeletal wheels, thinner glass and a plastic rear window. In the cabin, it's all low-fat trim and no carpets.
Next up, some truly nifty aero. At the tail, the spoiler is re-shaped, raised and moved back. This works hand-in-hand with the gaping lower diffuser, a triple-channel tunnel – the exhaust had to be re-shaped to make room for it. The diffuser causes drag though, so at 140mph three motorised flaps open down into the channels, stalling it and cutting the drag back. As soon as you turn the wheel, you need your downforce again, so the flaps pop shut.
Meanwhile, also at 140mph, a passive vane in the nose opens to restore the front-rear balance. Oh and there are 'turning vanes' at the nose and fins over the sills ahead of the rear wheels, both further improving downforce, though only by a few kilos. They, like the stripes, probably add mostly psychological speed.
And more power demands more cooling. But instead of making the radiators bigger (and heavier), there are new extractor openings in the front bonnet. It starts to look like a proper racer.
The dampers are a new generation of adaptive magneto-rheological items, with re-programming to match. The springs are stiffer, the whole suspension recalibrated. And the tyres are a new generation of Michelin, grippy beyond belief in the hot and dry, without losing out to the standard 458 items in the wet and cold.
And it's a Ferrari, so I'm guessing there's something going on in the engine department?
Indeed. The Speciale's elaborations over the regular 458 engine, already one of the sharpest mechanisms in motordom, concentrate on high-rev power. The roof is raised to 9000rpm, and there are higher-lift cams, new pistons, shorter inlet tracts and new exhaust. But because the compression is now a staggering 14 to one, mid-rev torque didn't suffer. The howl of this assembly as it revs to the sky is something to make your day. Or year.
I'm getting the picture. It's not just about the stripes.
No, but they're lovely stripes. Run your finger across them and you don't feel the join. They magically float in the Speciale's impossibly smooth pool of paint.
The way Top Gear has it, the 458 Italia is already at the top of its game. Can this really be better?
Sorry, we’re going to have to keep you hanging on a moment. There's one more technical killer app. It's called side-slip angle control, or SSC. Basically it works out how much you're oversteering, and if you're doing the right steering correction it'll allow the rear wheels to keep spinning up. Normal skid-control systems inevitably cut the power by that stage. But the SSC talks to the e-diff, and tells it to lock, catapulting you down the straight a perfect combination of speed and smoky drama. But if you haven't countersteered enough or you're using far too much throttle, it'll reign the car back in.
Have electronics really taken over drifting, the last bastion of DIY driving?
This is not a car that lacks soul. For a start, the engine could quicken the dead. It fizzes with instant reactions, sings for joy and head-butts its 9000rpm red-line. The mid-range torque might not match a McLaren 12C or 911 Turbo, but the engine's always-on attentiveness and sounds make up for it. The twin-clutch transmission has also been put on high alert, with faster shifts than the already swift calibration of the 458 Italia.
It's supposed to be a semi-track car isn't it? Does it feel happy there?
In its element. It turns into corners flat and hard, and avoids understeer like there's a unstretchable filament connecting the nose to the centre of the bend's radius. The front and rear stay perfectly in balance, and there's an immense amount of feel coming up through your seat. After the apex, pour on the power and the back tyres accept huge loads. There's a lovely sense of security, as the transition from slip to grip is gentle and well-telegraphed. You feel confident.
So you pile on some more power. And here comes that side-slip control. It doesn't feel strange or artificial as you poke the car into increasingly comical angles. It simply makes the car feel supernaturally benign. This is with the traction control off but the lifesaving DSC (ESP) still on. And it makes you feel like a hero. It's like having a driving coach at your side, an angel at your shoulder. Go to far and it sweeps you up, but gently and subtly.
So it's banging-hard on the road?
Nope. Even though the springs are a little more taut, the new damping compensates and keeps the ride amazingly fluent. There's less of the brittle banging over broken roads that the standard 458 Italia sometimes feels. It fact it's closer to the compliance of the McLaren 12C.
Ferrari has stuck with its sharp and quick steering. You need to stay on top of it, because the Speciale does follow cambers a bit. But in sharp bends this quick rack means you can take advantage of the astounding agility.
And all the time everything is so sharp and full of information. Even at regular road speeds, the Speciale bursts with life. Find a place to push faster and the quickness and truth of this car is just fabulous.
So why would anyone buy a regular 458 any more, when the Speciale is better to drive, but no harsher?
Well, it costs £208,000, which is not to be sneezed at. That said, this price does include, like all Ferraris these days, all your servicing for seven years.
Any other drawbacks?
At brisk road speed the exhaust makes conversation pretty difficult in here. It'd get tiring on a run.
Hang on. It's a track-day car too. Most UK tracks have strict noise limits. Won't this so-called track car get itself banned?
Ferrari knows this, and is developing a special exhaust that's quieter than the standard one. It can be fitted by dealers. It won't be cheap.
So they made it loud to sound like a racing car, but if you want to drive it like a racing car you have to pay more money to make it less loud…
Something like that. But trust us, it's one small piece of silliness in what is otherwise a transcendently wonderful car.
http://www.topgear.com/uk/photos/fer...iew-2013-11-10
Old 11-11-2013, 07:25 PM   #10
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
the only thing wrong with it is the stripe.
_brian_ is online now   Reply With Quote
Old 11-11-2013, 08:59 PM   #11
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
The stripe is fine, I'm more curious about the carbon fibre dildo on the centre console........
Old 11-12-2013, 08:57 AM   #12
tylerzero
Member#: 112397
'06 non-turbogasm
wagon
^^^I LOL at the thought of some idiot (like me) with too much money (not like me) pulling into the garage and then inadvertently yanking on that thing like a parking brake and accidentally hitting the "launch" button.
Ferrari meets dining room.
tylerzero is offline   Reply With Quote
Old 11-12-2013, 11:48 AM   #13
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Eh, still don't love it. Front end is too Enzo-ish and a downgrade from the 458 Normalé IMO.
EDIT: Kinda swoopy like a Ferrari P3/4 in that first shot...?
Old 11-28-2013, 04:34 AM   #14
torquemada
Member#: 128484
2006 EDM WRX STI
Old 07-10-2014, 02:11 PM   #15
torquemada
Member#: 128484
2006 EDM WRX STI
Old 07-23-2014, 02:39 PM   #16
torquemada
Member#: 128484
2006 EDM WRX STI
Old 09-26-2014, 01:10 PM   #17
torquemada
Member#: 128484
2006 EDM WRX STI
Ferrari 458 Speciale A (Aperta) Revealed
The convertible version of Ferrari’s hardcore 458 Speciale has been revealed, and it’s called the 458 Speciale A. The A is for the Italian word Aperta, roughly translating to “open,” and the production run for this latest Prancing Horse will be just 499 units.
As expected, the 458 Speciale A makes its world debut on October 2 at the 2014 Paris Auto Show. It is expected to be the last variant of the 458 line before an updated version, most likely with a turbocharged V-8 engine, is introduced at the 2015 Geneva Motor Show next March.
That would make the 458 Speciale A quite the collectible, as it would mean it’s the last Ferrari road car powered by a naturally aspirated V-8. The car’s engine alone is a masterpiece: its 4.5 liters of displacement is good for 597 horsepower at a screaming 9,000 rpm and 398 pound-feet of torque delivered at 6,000 rpm. That equates to roughly 133 horsepower per liter and means the 458 Speciale A’s engine, like the unit in the 458 Speciale coupe, is the most powerful naturally aspirated V-8 ever launched in a Ferrari road car.
On the road, this translates to 0-62 mph acceleration in 3.0 seconds flat and a lap of Ferrari’s Fiorano test track in just 1:23.5. That lap time is the same as that of the 458 Speciale coupe, a whole 1.5 seconds faster than the 458 Italia, and just half of a second off the pace of the V-12-powered F12 Berlinetta.
Key to its performance is a host of aerodynamic features (Ferrari boasts the 458 Speciale A is its most aerodynamic convertible ever), a rigid chassis and the innovative Side Slip Angle Control system which optimizes both torque from the engine and torque distribution between the two rear wheels (via braking) to improve handling.
The roof system, meanwhile, matches the one on the 458 Spider. It’s a retractable aluminum roof that needs just 14 seconds to go up or down. Incredibly, the weight difference between the 458 Speciale A and its coupe cousin is just 110 pounds.
The 458 Speciale A is being introduced in a unique triple-layer yellow livery with a Blu Nart and Bianco Avus central stripe as well as five-spoke forged wheels in Grigio Corsa. A similar theme is featured in the interior, with blue carbon fiber, seats in Alcantara and special molded door panels all adding a special touch.
http://www.motorauthority.com/news/1...perta-revealed
Old 09-26-2014, 07:08 PM   #18
gpshumway
Member#: 43950
07 WRX LTD Wagon
It's a purified dick!
Sorry, couldn't resist.
gpshumway is offline   Reply With Quote
Old 09-26-2014, 08:42 PM   #19
Hondaslayer
Member#: 4562
1995 Legacy LSi
Now I'm going to ask rogue to change it so you end up looking like an idiot!
Old 09-27-2014, 04:12 PM   #20
E. Nick
Member#: 8489
Mac MP4, Vip ACR,
BDR Cobra, M5, X5, F350
The fact that I really want one of these probably means it's a good time to pick up a 430 Scuderia.
E. Nick is offline   Reply With Quote
Old 09-28-2014, 06:06 PM   #21
gpshumway
Member#: 43950
07 WRX LTD Wagon
It certainly wouldn't be the first time...
Old 10-06-2014, 09:55 AM   #22
torquemada
Member#: 128484
2006 EDM WRX STI
Old 10-10-2014, 08:18 PM   #23
torquemada
Member#: 128484
2006 EDM WRX STI
