Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 08-20-2013, 08:42 PM   #1
ivanshinoda
Member#: 349057
Default 2002 Impreza WRX 1st gear whine*VIDEO
Hello everyone, my 2002 impreza with 126k and has started to making this whine in 1st gear, i don't know what it could be, i already changed the tranny fluid with grimmspeed cocktail mix, and drive 9 miles but don't hear any changes, anyone of you guys have this problem? my question is, what i could be and what happend if i continue driving with this whine, i already search on other post but nothing exactly like this issue that i'm having so... save yours ''Search Before post'', i'm looking for help, and the forums are for exchange knowledge, mechanics is not my forte, so i'm useless in this forum, i am a software engineer, so if you ever need something i'm will be glad to help you asap, thank you everyone, and excuse my english.
this is the video
http://www.youtube.com/watch?v=6dQMI...ature=youtu.be
ivanshinoda is offline   Reply With Quote
Old 08-21-2013, 07:13 PM   #2
ivanshinoda
Member#: 349057
anybody to help me?
Old 08-22-2013, 10:46 AM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
So, what are you saying, exactly?
You get a whine just by putting the gear shift lever into 1st gear?
Your not driving the car?
Your not touching the gas?
Old 08-22-2013, 02:26 PM   #4
ivanshinoda
Member#: 349057
Yes, i was driving downhills, the whine gets louder when speed increases
the whine comes up when i try to put on first gear and when in first gear.
Old 08-23-2013, 10:06 AM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
How long have you had the car?
How long have you been using the GS Cocktail Mix?
How do you shift, and be truthful? Do you force the lever into 1st gear when driving like a lot of people do when it doesn't wan't to go in?
Sounds like a worn syncro which could be from bad shifting, bad gear lube, or a combination of both
Old 08-23-2013, 07:50 PM   #6
ivanshinoda
Member#: 349057
i have the car for at least 6 months, i have put the GS Cocktail Mix like 4 days ago. And no, i don't force the lever, i just push a little bit on first gear and let it do it's work alone.
Old 08-24-2013, 10:08 PM   #7
some dude
Member#: 100300
06 WRX
CGM
I can tell you that you shouldn't be doing what was in the video. Only shift into 1st when the car is stopped. Do any other gears make that noise? I can hear ( synchro? ) spooling up as you apply pressure to go into gear. I hear a similar noise but much much quieter in my car. Whatever is going on w/ ur car , I can tell you I would never shift my car into first while rolling anything over 5mph.
some dude is offline   Reply With Quote
Old 08-25-2013, 04:38 AM   #8
ivanshinoda
Member#: 349057
it's just on 1st gear
Old 08-25-2013, 10:52 AM   #9
some dude
Member#: 100300
06 WRX
CGM
Do you have a magnet on the drain plug? Any metal on there? I'm not sure if something is 'wrong' with your car or if that's just the synchro spinning first gear up so you can shift in.
As before at least don't do that any more. On the handful of times I've let someone borrow my 06' The only thing I tell them is to not shift into first until the car is COMPLETELY stopped. This was bad in the earlier WRXs and was re-designed at some point (2004 or so?).
Old 08-26-2013, 07:31 AM   #10
ivanshinoda
Member#: 349057
yes, it have the magnet, when i take out, it has like a paste, a little bit less than this photo but don't found any large pieces of metal.
Old 09-06-2013, 03:53 AM   #11
ivanshinoda
Member#: 349057
Any opinion?
Old 09-13-2013, 09:02 AM   #12
whagen2903
Member#: 336847
The first gear in wrx transmissions doesn't have a synchro so you should never put it in first while the car is moving. That whining noise is the gears trying to compensate for you forcing first into place. Your going to destroy your first gear if you keep doing that, just some words of advice.
whagen2903 is offline   Reply With Quote
