Old 08-20-2013, 11:34 PM   #1
BeefCurtains64
Member#: 251257
12 WRX
Default af ratio question
My af ratio B is set at -5.0% every time I start the car or when its moving (does not matter what speed). my knock sensor sum B. Has the most knock too.
Also there is a sweet smell coming out of my exhaust... are those symptoms are showing that my cyl2 is about to go? I want some information before I bring it into the dealership... please help
BeefCurtains64 is offline   Reply With Quote
Old 08-20-2013, 11:38 PM   #2
BeefCurtains64
Member#: 251257
12 WRX
Might I add Stg 1 tp map. W/ a/c on...
Old 08-21-2013, 06:53 AM   #3
veritasaequitas
Member#: 333964
2005 sti
aspen white
That sweet smell that you are getting is most likely coolant. Easy way to check if your cylinder 2 is going is compression check and cylinder leak down test. Thats where I would start. Does the vehicle smoke? If so what color smoke?
veritasaequitas is offline   Reply With Quote
Old 08-21-2013, 01:17 PM   #4
BeefCurtains64
Member#: 251257
12 WRX
No smoke either no symt other then the car doesn't hit target boost anymore. usually its 18... but now its 17.6 or less.
Old 08-22-2013, 04:17 AM   #5
BeefCurtains64
Member#: 251257
12 WRX
yEAH FOUND A SOULTION, sorry about caps, suicidal post about it. my MAF scaling is correct ... I hope, so it must be leaking from turbo to TB
Since its smelling sweet, its the leak from turbo to the throttle body.... going to have to bring it in for a warranty. DAMN IT !!!!!
