Old 08-19-2013, 07:54 PM   #51
UPPCOS
Member#: 364680
In case you're wondering what the rolling antilag is about, here's a graph to show you what it's actually doing.
It's plotted against speed, and it simulates a 50mph 3rd gear roll. The green is just a normal sweep, like I was cruising at 50mph and stomped on the gas. The red is with antilag. So getting ready for the race I got up to 50mhp, hit the gas and the anti-lag button. This is a relatively large turbo (T76) so it took ~6seconds to spool (and my RPM's were only 3500 which didn't help). Spooled ~15 psi (outa the peak 22), then let go of the button.
Now there are a few things that effect this spool time and what not, namely the RPM (and therefore speed) that you're going. So you'll have to play with it at different speeds and see how long it takes to spool, this way when it comes race time, you'll know how long in advance you'll need to prepare. IE for me if I'm doing a 3 honk race I want 2nd gear, 40mph roll, and I push the button on the first honk cause it takes no time at all to spool it. So a 40 roll is optimal for me, and I know this in advance so when I setup a race, that's what I'm looking for.
But when you let go of the button look what happens. +191hp over what you'd normally see, and +276 ft/lbs.
And if you look at the instantaneous tq applied it goes from 43ft/lbs (button in) to 553ft/lbs (button out) over the course of about 0.5 seconds. Quite a kick.
CK
UPPCOS is offline   Reply With Quote
Old 08-19-2013, 08:15 PM   #52
BlueEvoEater
Member#: 168305
2004 Impreza WRX
WR Blue
Originally Posted by UPPCOS View Post
Oh absolutely. LC will hold your RPM's in check, antilag will give you boost to go with it. Watch the video, it shows both. The BAP BAP BAP you hear (even in the antilag session) is actually the 2-step, it just gives boost to accompany it.
Well that's awesome!
BlueEvoEater is offline   Reply With Quote
Old 08-19-2013, 09:34 PM   #53
Paidfor
Member#: 267815
Be in awe
dont hate .)
That's one hell of an improvement UPPCO !!!!
Everybody hates you cuz your the big man on campus lol jk
Interesting graph tho...........still workin on my rollin anti.
Paidfor is offline   Reply With Quote
Old 08-19-2013, 10:00 PM   #54
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
CK
This is really cool. I think someone posted earlier about getting a datalog to see what the car is actually doing. Is there any way of getting that from a launch standpoint and a rolling?
StIGC11 is offline   Reply With Quote
Old 08-19-2013, 10:10 PM   #55
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Call it what you want, but this is genius. I personally have an AEM but I helped a friend put this on his SR55 powered 06 WRX that wouldn't built more than 3-4 psi with a 5k rpm 2 step. It quickly builds 16-17 psi now. I had to change one other table to get timing to go below 7*- Base timing idle minimum vehicle speed enable has 7* as the minimum value above 176* F coolant temperature. I set that to -15*. This table can be used to set the 'floor' for timing so that it won't run more negative than the value set in that table. Thanks UPPCOS for the contribution.
06rexwagon is offline   Reply With Quote
Old 08-19-2013, 11:42 PM   #56
UPPCOS
Member#: 364680
Ahhh, good call. Think I remember screwing with those too. As far as the logs go, it was actually on a customers car, which I don't have at the moment. I probably have logs, but I never name any of them, and there's literally 1000's of them with all the Subies we've tuned.
If I see it back in the near future for anything else, I'll try to get some logs.
CK
Old 08-21-2013, 07:57 AM   #57
WhatTurboLag?
Member#: 243992
2006 WRX TR
I want more videos!
WhatTurboLag? is offline   Reply With Quote
Old 08-21-2013, 10:00 AM   #58
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Originally Posted by WhatTurboLag? View Post
I want more videos!
I agree I've been waiting. Any ewg videos?
bswilmington is offline   Reply With Quote
Old 08-21-2013, 10:13 AM   #59
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
First off, thank you for sharing this, very kind of you!
I tried this out on my RSTi yesterday and love it so far. I have 2 things to point out.
1: If you goto the autostore and buy a 5 pin relay, make sure it is the style with pins 87 and 87A! There is a 5 pin relay that offers 2 87 pins for hooking up extra lights, it will NOT toggle the IAT line off like desired. Some people may say this is an obvious thing, but it you are in a rush to try a new mod (like myself last night) and quickly buy something, it may be wrong lol... Just a FYI here
2: A relay reacts VERY slowly. Watch your IAT when you press the button, it will slowly creep to the -40. Another way to do this, and cheaper btw, is to just buy a Normally Closed Momentary Switch. Ditch the relay altogether and just intercept the IAT wire with the switch. When it isn't pressed it will be connected, and when you do hold it down it will cut the signal. Less parts, less wires and should work faster. I say should because I haven't tried this just yet, I just ordered the switch to test it out.
Thanks again for sharing, it is fun to play with and easy to setup! I am running a 02 WRX ECU setup and when looking at the MAF connector from the wire side, it is the far 2 left side wires (brown and green/red on mine) that are IAT. Cutting either works. Just another FYI for other people playing with this.
insaneimpreza is offline   Reply With Quote
Old 08-21-2013, 10:20 AM   #60
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
Old 08-21-2013, 11:01 AM   #61
TS7XREX
Member#: 287450
2011 Impreza WRX
Is this to be used in conjunction with launch control? It says you have to have the throttle plate 100% open. How does that work for rolling anti lag? Are you depressing the clutch while rolling?
TS7XREX is offline   Reply With Quote
Old 08-21-2013, 11:04 AM   #62
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
For the LC part, you just use LC like normal and then hold the button. Release on take off.
The rolling one Im still playing with a bit. But since it reacts a lil slower with the relay, I will press the button and then go WOT right after. In 3rd gear at 3k on my car it fully spooled. As soon as it did, I released the button and off I went. (I have a EJ257 with TD06 20G for reference)
Old 08-21-2013, 11:09 AM   #63
TS7XREX
Member#: 287450
2011 Impreza WRX
Sweet, I think you should to be the one to upload videos... Since you're just playing with it...
Old 08-21-2013, 11:15 AM   #64
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
Don't threaten me with a good time lol
When I go out to lunch Ill take a couple.
Old 08-21-2013, 12:28 PM   #65
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I think you will find that it is not the relay that is causing that delay.
Old 08-21-2013, 12:42 PM   #66
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
You think its the ECU gathering data slowly from the IAT? Hmmm. I have it setup so I can easily test it with just the switch vs the relay setup. Im curious to see if it's different now.
Regardless, this mod can still be done for almost nothing and less complicated still (not that it's actually complicated, just saying there is less involved with only using the right switch)
Old 08-21-2013, 01:36 PM   #67
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
Here's a vid of it from a stop using LC + Antilag:
Ill get the roll one on my way home. Really not trying to use it constantly or right in a row. I just got this thing back together lol.. Im trying to drive it at least a week before breaking something else
Old 08-21-2013, 03:45 PM   #68
UPPCOS
Member#: 364680
Correct, the ECU is getting the data fast, but the way it interpolates it is slower. The is because there is a built-in filter to do away with any noise jitter. Same thing with your fuel level gauge, it averages a reading over time so your gauge isn't jumping around when you go over bumps or take corners.
Insane, good call on the relay, I forgot to mention that.
We used a relay because you can trigger it with a button that's already in the car, like a horn, or brights switch, etc.
CK
Old 08-21-2013, 03:47 PM   #69
UPPCOS
Member#: 364680
Well I know there's quite a few of you playing with this now, but still no donations. ;( So how about this instead, just hit us up and like our FB page, this way you can keep up to date with things we're doing and new releases. Fair enough?
https://www.facebook.com/UPPCOS
Old 08-21-2013, 04:30 PM   #70
06rexwagon
Member#: 114730
[email protected]
I am running into an issue using this on an 06 STi. I have the switch working but the table for timing compensation activation isn't defined. I got it to work on a friends 06 WRX but the STi won't work without that table. Does anyone have a definition file for the A2ZJE11J STi that contains that table? Thanks!
Old 08-21-2013, 05:08 PM   #71
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
Got one on the way home from a roll.
Upp, i will gladly send a donation. And the normally closed switch will be here tomorrow. Cheap mod is good but even cheaper mod is better still
Old 08-21-2013, 06:31 PM   #72
UPPCOS
Member#: 364680
How comfortable are you editing defs? You may be able to look in the WRX and copy/paste it into the STi. Of course you'll need to double check when you're done to make sure the values seem legit that are in there, and when you edit it that's actually what its doing (verify by logging).
CK
Old 08-21-2013, 06:35 PM   #73
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
CK
the WRX def isnt close. I already looked.
Old 08-21-2013, 11:42 PM   #74
adosdrummer
Member#: 348773
06 LGT and Mr-s
adosdrummer is offline   Reply With Quote
Old 08-22-2013, 10:11 PM   #75
TS7XREX
Member#: 287450
2011 Impreza WRX
Originally Posted by adosdrummer View Post
What is your plan with this monetary switch?
