Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 08-08-2013, 09:43 AM   #26
thebigd1973
Member#: 339368
Originally Posted by dets34 View Post
anyone know what year thebigd1973's outback is. looks like an 01 but I could be wrong. I just totaled my 02 wrx and picked up a swagin wagon myself and was just wondering what year his was because that is the cleanest looking wagon ever. great work!
Hi there, My Outback Ltd, is a 2000. The Generation is from 2000-2004. I hope that this helps you out.
thebigd1973 is offline   Reply With Quote
Old 08-08-2013, 10:07 AM   #27
03wrxyllw
Member#: 277176
Originally Posted by 03wrxyllw View Post
Just wondering can you use 08+ Sti coilovers on a 01 legacy?
So does anyone know the answer to this
03wrxyllw is offline   Reply With Quote
Old 08-08-2013, 11:23 AM   #28
Sideways the Seven
Member#: 320455
2012 STI Sedan
You can't use those, the GR suspension is different.
Sideways the Seven is offline   Reply With Quote
Old 08-08-2013, 11:44 AM   #29
03wrxyllw
Member#: 277176
Thanks I had seen something on a subie page on fagbook that said you could and wanted to see if anyone in here had tried it
Old 08-08-2013, 12:04 PM   #30
Sideways the Seven
Member#: 320455
2012 STI Sedan
No problem, pre-08 will work though.
Old 08-08-2013, 12:17 PM   #31
03wrxyllw
Member#: 277176
Are you sure they look a lot different
Old 08-08-2013, 12:39 PM   #32
Sideways the Seven
Member#: 320455
2012 STI Sedan
Almost certain. May want to double-check on legacygt.com for full confirmation.
Old 08-09-2013, 08:47 AM   #33
dets34
Member#: 320143
2002 WRX stage 2+
Awesome! Yeah im going to pick up my 2001 outback ltd today and have plans to do something similar to yours. Just curious, I don't have the money for coilovers so which type of strut/spring combos am I gunna be looking for. I read somewhere that legacy suspensions should work on the outbacks but drop a little more?
dets34 is offline   Reply With Quote
Old 08-09-2013, 09:26 AM   #34
thebigd1973
Member#: 339368
I am actually using a Legacy spec'd Coilover system from K-Sport. Any of the like year legacy suspension will line right up with ours on the Outback. As for being lower, you are correct. As the outback is naturally a couple of inches higher for ride height, putting the legacy coils or struts and springs will automatically bring the ride height of the outback down by a couple of inches.
Old 08-10-2013, 08:41 PM   #35
videcarli
Member#: 365012
Great posts.
videcarli is offline   Reply With Quote
Old 08-13-2013, 08:53 AM   #36
dets34
Member#: 320143
2002 WRX stage 2+
Old 08-13-2013, 09:56 AM   #37
RS2004
Member#: 95450
Default My 07 H6
this is my 2007 Legacy outback LLbean H6
when i first got it she was sitting high up off the ground. I found a set of legacy GT struts and sprint and swap out the stock struts and lowered it down about 2 inches from stock height. after that I swapped out the rear sway bar for a 24mm cobb sway bar to tight it up in the corners. Its riding on a set of Legacy gt 06 rims 17 inch.
I also blacked out the head lights and tinted my tails with uv tint spray, and yellow over lays tint on the fogs. I put a set of rally armor. I tinted the windows. I was able to find some one with the same color legacy that wanted to go wingless and I swapped trunks for a wing and debadge it. I just put on the dual quad tip Megan 3" from cat back exhaust. Sounds nice and looks great I thinkorns.
I forgot the set of hella horns. And A DIY wire ground kit
things that are next on my list are. Need to get a set of wheel spacers to help fill in the fenders
Engine/Performance
Full 3" from cat back Megan quad tipp exhaust
Suspension/Handling
Lower on a set of LGT struts and springs
24mm Rear Cobb Sway bar with up graded bushing
LGT 17" rims plasic dipped black
Exterior
Hella horns
Rally armor mud flaps
Debaged trunk
Lighting
Blacked out head lights
And tinted tail lights
Headlight armor overlay yellow foglights
Interior
Didnt like the look of the fake wood trim and I got some carbon fiber overlay
35% window tint
[IMG][/IMG]
[IMG][/IMG]
RS2004 is offline   Reply With Quote
Old 08-14-2013, 12:50 AM   #38
Sideways the Seven
Member#: 320455
2012 STI Sedan
Looks good! Love the OB sedans
Old 08-14-2013, 02:35 PM   #39
RS2004
Member#: 95450
thanks
Old 08-16-2013, 03:40 AM   #40
Ronald_Type-R
Member#: 200886
2000 Legacy Wgn STi
Hi everyone! New on NASIOC here, and I'm just looking through all the sub-forums on here! Hoping to get to know more people on this site in the near future!
For now, here are a few pics of my 2000 Subaru Outback! I bought this car 8 months ago, and have since re-done the whole suspension, interior, wheels & tires, as well as a few performance upgrades under the hood
ENGINE
- '05 USDM EJ257 STi Ver.8 Engine Swap
- Crawford Air / Oil Separator V2
- Spearco 900cfm Weld-On Aluminum Top Mount intercooler
- DEI Gold Heat Reflective Tape
- Tial Q 50mm Blow-Off Valve
- Samco Silicone 2.4" Turbo Inlet Hose
- AEM Silicone Throttle Body Coupler
- Perrin Silicone Intercooler Elbow
- JDM STi by Samco Silicone Radiator Hoses
- Grimmspeed Port & Polished OEM Intake Manifold
- Grimmspeed Port & Polished OEM Drive-By-Wire Throttle Body
- Grimmspeed TGV Delete Kit
- Grimmspeed Phenolic 8mm Intake Manifold Spacers
- BeatRush Engine Mounts
- Injen Short Ram Intake
- APS Equal Length Exhaust Manifold
- APS Catless Uppipe
- Stromung 3" Bell-Mouth Downpipe
- iON Performance Stage 1 VF39 Turbo Upgrade (Port & Polished Factory Turbo, w/ Ceramic Coating)
- JDM Cusco Turbo Heat Shield
- Perrin Lightweight Crankshaft Pulley
- GFB Underdrive Power Steering Pump Pulley
- Komoto Racing Stainless Steel Midpipe
- Zero Sports Axleback Exhaust
- A'PEXi High-Capacity Race Aluminum Radiator
- JDM BE5 Legacy B4 S401 STi 1.3Bar Radiator Cap
- JDM BE5 Legacy B4 S401 STi Radiator Hoses
- Deatschwerks 320lph Fuel Pump
- Beatrush Radiator Cooling Plate
- Beatrush Alternator Pulley Cover
- Greddy Magnetic Drain Plug
- SYMS Aluminum Oil Cap
- SYMS Aluminum Brake Fluid Reservoir Cap
- SYMS Aluminum Clutch Fluid Reservoir Cap
TRANSMISSION
- OEM 5-speed Manual Transmission w/ JDM STi Ver.5 RA Cryo-Treated Gearset
- Cryo-Treated STi Ver.5 Shift Forks
- Quaife Cryo-Treated Front LSD
- JDM BE5 Legacy B4 S401 STi Transmission Mounts
- JDM BE5 Legacy B4 S401 STi Short Shifter Linkage
- Kartboy Short Shifter
- Kartboy Rear Shifter Stay Bushings
- Beatrush Polyurethane Shifter Bushings
- Lightweight Aluminum Race Flywheel (Unknown Brand)
- OEM STi Clutch Disc & Pressure Plate
- Beatrush Solid Aluminum Pitch Control Rod
INTERIOR
- JDM BE5 Legacy B4 S401 STi Instrument Cluster
- JDM BE5 Legacy B4 S401 STi Pedal Set
- JDM BE5 Legacy B4 S401 Aluminum Door Sills
- NRG Short Hub
- WorksBell Rapfix QRSII Steering Wheel Quick Release Kit
- ATC Rallye International Type 95 330mm Steering Wheel
- Sparco Dual External Horn Buttons
- Bride FO-Type Seat Rails & Sliders
- OMP WRC VTR Bucket Seat [Driver]
- OEM GDA STi V5 Bucket Seat [Passenger]
- Beatrush Titanium 5-speed weighted 220g Shift Knob
- Circuit Hero Shifter Extender
EXTERIOR
- JDM GDB STi V-Limited Front Lip w/ Optional Rubber Add-On Flap
- JDM BH5 Legacy Kouki Rev.D Headlights w/ HID
- JDM BH5 Legacy Kouki Rev.D Taillights
- JDM BH5 Legacy Kouki Rev.D Rear Spoiler
- JDM Pink STi Rear Emblem
- Ganador Carbon Fiber Powered Aero Mirrors
- WorksBell Carbon Fiber Hood
- JDM Zero Sports Front Grille
- Tein Hood Struts
FOOTWORK (SUSPENSION/BRAKES/CHASSIS)
- BC Racing BR-Type Short-Stroke Coilover Damper System w/ custom Swift Springs [16kg/mm Front & Rear]
- Beatrush Front Performance Bar
- Beatrush Front Strut Brace
- JDM Legacy BE5 Spec B Forged Aluminum Front Lower Control Arms
- Megan Racing Rear Upper Control Arms
- Megan Racing Rear Lower Front Control Arms
- Megan Racing Rear Lower Rear Control Arms
- Beatrush Driveshaft Carrier Hardened Bushings
- Beatrush Rear Differential Carrier
- Zero Sports 23mm Front Sway Bar
- Zero Sports 21mm Rear Sway Bar
- Whiteline Front Sway Bar Adjustable End Links
- Whiteline Front Control Arm Lower Inner Front Bushings
- Whiteline Front Control Arm Lower Inner Rear Bushings (Anti-Lift Kit)
- Cusco Rear Lower Arm Bar Stiffener Ver. II
- Whiteline Rear Sway Bar Adjustable End Links
- SuperPro Rear Trailing Arm Lower Front Bushings
- Beatrush Rear Strut Brace
- OEM WRX Front 2-Pot Brake Calipers
- Technafit Stainless Steel Brake Lines
- Axis Rear 2-pot Big Brake Kit
- ARP Extended Studs
WHEELS/TIRES
- JDM Work Meister S1R 18x9" (Glim Silver) w/ 225/40ZR18 Bridgestone Potenza RE-11 [Summer]
- JDM Work RS Extended Open Ended Anodized Red Lug Nuts
ELECTRONICS
- Cobb Tuning Access Port V2
- JDM A'PEXi Voltage Stabilizer & Ground Kit
- JDM Blitz DTT DC Turbo Timer
- Rockford Fosgate 10 Farad Hybrid Capacitor
- Pioneer AVIC-Z140BH Double Din Head Unit
- Phoenix Gold MS-2125 SQ Amplifier x2
- Focal Polyglass 165VB Component Speakers
- Focal Access 27 Twin Lux Subwoofers & Box
After I installed a JDM STi V-Limited Front Lip
Just a few nights ago, with my newly acquired personalized plates
Ronald
Ronald_Type-R is offline   Reply With Quote
Old 08-16-2013, 07:47 AM   #41
Sideways the Seven
Member#: 320455
2012 STI Sedan
Wow! Awesome OB! Very nice!
Old 08-19-2013, 10:06 AM   #42
RS2004
Member#: 95450
yes I agree very nice work
Old 08-19-2013, 10:12 AM   #43
Sasquatch88
Member#: 359943
2005 Outback
Willow Green Opal
Sooo cleeeean! Holy bulgogi. Maybe one day for me...in my dreams.
Sick though man, well done.
Sasquatch88 is offline   Reply With Quote
Old 08-21-2013, 12:34 PM   #44
grimmreeper
Member#: 365929
2000 Outback
Regatta Red
i have a 2000 sube legacy outback 2.5na with a question about coil overs. the car is bone stock, and i need new rear struts; i was gonna take this opportunity to install coilovers but having some trouble finding them for the 2000 legacy. i dont need anything too stiff, (its my wifes DD after all) i just need something that will give it a nice low, stanced look, but no retarded camber. im somewhat budget minded although i know "you gotta pay to play" any suggestions? the only ones i have found a Ksport brand and all my tuner buddies are telling me to stay away from those. i'm coming from a V8/muscle car background so this is a little new to me. any help would be awesome, thanks.
grimmreeper is offline   Reply With Quote
Old 08-21-2013, 01:15 PM   #45
kongzilla
Member#: 25864
02 WRX
suspension: JDM Spec B Rev A Bilstein shocks/springs
Wheels/offset: 17x7.5 Volk Racing CE28, 50 offset
tires: 225/55/17
kongzilla is offline   Reply With Quote
Old 08-30-2013, 12:30 PM   #46
PA-Outback2000
Member#: 161832
2000 Outback Limited
Ronald_Type-R... i thought my outback was heavily modded (which it is), but yours definitely takes the cake for now! can you get a few under-car pics? i'd love to see the braces you have to see how you got them to fit.
do you know if any parts you installed are 5-speed/manual specific? my car is sadly an automatic.
how did you get the larger swaybars to fit?
i love the roof-rack delete!
thanks!
PA-Outback2000 is offline   Reply With Quote
Old 09-25-2013, 01:03 PM   #47
panapower
Member#: 158467
2011 several
several cars
tires: 225/55/17
this is awesome. same car that i bought. i would certainly have to get some coilovers cause when it rains heavy here at work the street floods and there is no way to get out if a car is lowered.
panapower is offline   Reply With Quote
Old 10-16-2013, 07:37 PM   #48
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Originally Posted by joe r View Post
I see a raised thread going on but no lowered thread.
Please post,
Pic.
Suspension your running.
Any mods you had to do to make it work.
Wheel, tire size and offset.
As soon as I get mine all set up and figured out I will post pics. I own a 2003 Outback VDC Sedan with all options and Black leather...
I am running,
KW V2 coilovers for 03+ Legacy fitment.
Group N front top hats 02+ Impreza, wrx or STi fitment.
Legacy Spec B rear top hats.
Whiteline rear 20mm adjustable swaybar set on stiff Legacy/Outback fitment.
04+ STi Rallitek rear endlinks.
Mods to make it all work,
Removal of rear rubber bump stops that are mounted to the frame.
I will be installing paranoid 1" spacers front and rear, I am low at the suspensions highest setting. The ride is amazing and 100% better than factory.
Mods to come,
Rolling of my fenders front and rear.
18x8 STR 601 wheels +40 offset. "BBS LM reps".
225x50x18 BFG TA tires.
Whiteline 22mm non adjustable front swaybar Legacy/Outback fitment.
Whiteline front endlinks 02+ WRX fitment.
Stay tuned. I look forward to reading and drooling over your Outback.
joe r
You got any pics? Would be very interested to see how this setup looks; I'm pondering a very similar setup for mine (2004 OB H6 LLBean Wagon, white/tan on tan interior; 100% stock as of right now).
Also, did you have any problem with rubbing after rolling your fenders?
TurboLag23 is offline   Reply With Quote
Old 10-16-2013, 07:43 PM   #49
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Hey folks. Here are a couple of recent pictures of my ride.
SUSPENSION
- K-Sport AR Spec. Coilovers
- Whiteline Front Sway bar
- Whiteline Front end links
- Whiteline Rear Sway bar
- Whiteline Rear end links
- Whiteline Front tower strut bar
WHEELS & TIRES
- XXR 527's 18x8.75" 5x100 (Matte black)
- BF Goodrich Comp T/A 245/45-18
- NRG Lug nuts 471 Series in Pink c/w locks
ENGINE
- Weapon-R Short ram intake with Cold air extension piece.
- Borla Un-Equal Header
- Custom 2.5" Mid-pipe
- Apexi Noir muffler
EXTERIOR
- HID kit (6,000K) Low beams
- HID Kit (2,500K) Fog lights
- Blacked out Front grill with Pink Subaru Emblem
- Yakima Sky Box (attached to stock cross bars)
- Window Visors
INTERIOR
- Window tinting (Legal limit)
- Broadway convex mirror
- Pioneer In dash 7" Navi head unit
- Front stage - MB Quarts 6.5" Comp.
- Rear fill - Kicker - 6.5" Mid bass drivers
- Low end - RE Audio 15" SE Sub
- Amplification - MB Quart - 5 Channel - 980Watt Class D amp.
- Thought-out iPhone 5 Holder
- Viper 5901 Alarm/Starter system
Lots to come in the next few months. :-)
I absolutely love my Subie!!!
Awesome!!!
You have any problems with rubbing with that setup? Going to go ahead and guess you rolled your fenders haha. 8.75 would be a nice width to run if it's practical, because it could allow for a really wide tire (255/45 would be awesome).
Old 11-10-2013, 03:38 AM   #50
pkeating90
Member#: 373019
2005 OBXT
RED
[IMG][/IMG]
2005 OBXT
EJ257 STI swap and Tranny
Tien Springs, KYB Struts (not a fan of coils)
Whiteline F/R sways
Whiteline Endlinks
Cobb catless up
Cobb AP Stage 2
Nameless dp
Nameless 5in muffs
SPT CAI
Hellas
35% tint
12000k HIDs
More to come:
Wheels/tires
Braces
Mid/Y pipes
Stop tech BB
Gauge POD
Turbo
Custom Tan Recaros
Exteriors dress up..
pkeating90 is offline   Reply With Quote
