Old 06-09-2003, 06:16 AM   #26
Qaveboy
Member#: 23979
Default installing lsd
hey guys we just came upon this as we are doing our project. just in case any of you out there are thinking of doing the swap. our 99L rear crossmember?( i think) is slightly different than those to the wrx, so if you are going to install the wrx lsd, u also need to get the rear crossmember. unless we made a mistake, the lsd wouldnt fit the L crossmember. just our experience may be wrong.
kevin
Qaveboy is offline   Reply With Quote
Old 06-09-2003, 04:07 PM   #27
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I have not heard of that before.
-Jon
stimpy is offline   Reply With Quote
Old 06-10-2003, 10:39 AM   #28
Boost4U
Member#: 16459
1998 2.5RS
How about this.....
I want to swap a WRX with 5MT into my 98RS AT.....do I need all new axels front and rear, as well as drive shaft and rear diff????
Boost4U is offline   Reply With Quote
Old 06-10-2003, 12:03 PM   #29
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Originally posted by Boost4U
How about this.....
Nope, your front axles should work. Drive shaft and rear diff will be needed, IIRC. Rear diff is a definite as your AT RS rear diff is 4.44, I believe, and you need a 3.54 rear diff. If you get a 3.54 LSD rear diff, you'll need different rear axles than what are currently on your car.
- Trent
edit - Oops! Thanks for the correction on the rear diff ratio, Jon. I forgot about the weirdo 1.1:1 center diff.
peepshow is offline   Reply With Quote
Old 06-10-2003, 03:22 PM   #30
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The driveshaft is a different length between the MT and AT cars so you will need that if you are going to a 5MT. You need to match your rear diff up with your transmission. The WRX rear diff is an unusual bird at 3.54 final drive mating to a 1.1:1 reduction gear and a 3.90 final drive in the front.
Front axles are not needed. Splines are all the same. You would just need to have LSD axles to go with the WRX rear diff.
-Jon
thumping noise when very light on gas? (its not the rear diff) sleeepyrex Service & Maintenance 4 05-22-2009 03:20 PM
DE: complete WRX 5 speed swap (trans, axles, rear, hubs) rexspeedmaster Drivetrain 19 04-13-2008 10:14 PM
08 2.5i question (black metal/rubber behind rear diff) Mooneyes13 Newbies & FAQs 6 12-23-2007 03:42 PM
STI Swap Engine, tranny, axles, rear diff, harness and ecu SERGEREYES Private 'For Sale' Classifieds 22 07-01-2006 05:17 PM
Question about diff (mainly rear diff) iBlueVirus Transmission (AT/MT) & Driveline 10 08-24-2002 08:51 PM
