Old 08-21-2013, 05:39 PM   #1
russian777
Member#: 300971
Rally blue
Default Rear Diff cooler?
Want to have a rear diff cooler made.
Any suggestions as to how to go about this?
I figured using a pump and a universal cooler should work. Would love some input.
russian777 is offline   Reply With Quote
Old 08-21-2013, 05:45 PM   #2
vicious_fishes
Member#: 158864
2003 SOHC destroker
only one i've ever seen used a bilge pump and a typical 10 row or whatever cooler like any oil cooler uses. not hard to splice it into the 12v at all. the hard part would be getting fittings to go in the diffs fill holes.
Old 08-21-2013, 05:59 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
why not just go with one of the finned diff covers? what type of racing are you doing that needs the extra fluid and cooling?
PARANOID56 is online now   Reply With Quote
Old 08-21-2013, 07:40 PM   #4
russian777
Member#: 300971
Rally blue
auto cross and drag racing in the hot caribbean weather. The finned diff cover isnt sufficient
Old 08-21-2013, 07:41 PM   #5
russian777
Member#: 300971
Rally blue
yeap pretty much what i thought. I may do a mock setup on a busted diff before i do mine.
Old 08-21-2013, 08:50 PM   #6
vicious_fishes
Member#: 158864
2003 SOHC destroker
iirc perrin make a diff cover that increases its capacity AND has the fins for air cooling. unless you're doing enduro racing i would imagine that would be worth a try first. much simpler solution, though wiring a bilge pump into the 12v uses a sum total of two wires and a flippable switch
autox and drag racing are all done & dusted in a manner of seconds. you shouldn't need to do anything at all RE: heat there.
Old 08-21-2013, 10:37 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
3/4 npt on the diff cover, then -10 to a mocal pump, to cooler then back to the top diff port. Might also want to run the top diff vent to a hose with a small catch can on it.
scby rex is offline   Reply With Quote
Old 08-22-2013, 04:55 AM   #8
vicious_fishes
Member#: 158864
2003 SOHC destroker
i still don't understand how you can overheat a diff in the 10 seconds of drag racing or 30 seconds of autox you do. something else is wrong IMO.
Old 08-22-2013, 08:47 AM   #9
biknman
Member#: 47915
2003 GG HC TT
GG-RC 08STI 16OB 96GC2dr
This is what I do for my hill climb car works great.
biknman is offline   Reply With Quote
Old 08-22-2013, 08:55 AM   #10
planky90
Member#: 242587
2010 STI SE
Grey
I overheat my diff drag racing. I have been thinking of ways to cool it down.
planky90 is offline   Reply With Quote
Old 08-22-2013, 03:55 PM   #11
omiotek
Member#: 272090
i dont see how you guys are overheating diffs unless your low on fluid or something in a drag race........ i see road race stis that dont even use them. some do dont get me wrong but the ones in my class in ttb do not run one.
anyways you can run a oil cooler style core with a pump to circulate the fluid throug. that to me is the best way. like above weld some fittings on and run your lines.
omiotek is offline   Reply With Quote
Old 08-23-2013, 10:04 AM   #12
russian777
Member#: 300971
Rally blue
Car is also daily driven in the heat.
Old 08-23-2013, 11:06 AM   #13
PARANOID56
Member#: 22035
2003 Brocoma DCab
I think you are way over thinking this. have you taken a temp reading of your diff? there is no way you are overheating it. even if you drive in the heat.
hell i drove 48 straight hours from los angeles to oklahoma and back in a single drive only stopping for gas driving through 100+ deg temps and never had an issue.
get a finned diff cover and thats all you need. if you want the cooler idea just for the coolness of it, then say so
Old 08-23-2013, 11:14 AM   #14
russian777
Member#: 300971
Rally blue
I have this lsd in the rear diff
http://www.rallispec.com/dif_cls_sti.html
After some spirited driving it begins to lock up around corners causing the back to start coming out. Also gives some torque bind when doing slow turning movements after heating up.
I highly doubt you know how hot it really is out here in Jamaica and Trinidad
so heat is always an issue.
Old 08-23-2013, 11:46 AM   #15
russian777
Member#: 300971
Rally blue
Thanks to everyone for their additions, will post a pic when its done
Old 08-24-2013, 07:40 AM   #16
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
also check ebay.co.uk. Prodrive made external coolers available at one time and many setups with quality braided hoses and the cooler come up, on the cheap side.
Old 08-24-2013, 06:41 PM   #17
russian777
Member#: 300971
Rally blue
will do bro thanks
Old 08-24-2013, 08:31 PM   #18
vicious_fishes
Member#: 158864
2003 SOHC destroker
and i daily drove mine in 40+ degree heat too, and on highways nonetheless.
diff's don't just overheat on a whim. something else is wrong.
Old 08-25-2013, 07:21 AM   #19
hoffmanEstates
Member#: 122043
04 wagonier
psm
Try this install a temp gauge and then see how hot the rear end is getting
hoffmanEstates is offline   Reply With Quote
Old 08-25-2013, 08:37 AM   #20
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
yep, I have not been able to find anybody that posted on this board about having a legitimate rear diff temp light come on.
I retrofitted my R160 with the R180 sensor, to match the Sti dashboard and was thinking that maybe the R160 gets hotter with higher levels of power.
There was a brief time in '04-05 where people were getting the light on, on factory Sti, but there was a grounding problem with the temp sensor, which Subaru fixed in the next year, by redesigning the grounding on that.
The faulty ground was turning the light on.
As it is, the factory sensor in the R180 is set to turn on at a very high temp, suggesting that Subaru thinks the R180 will be fine running really hot.
This may not be the case with the R160 with the visco though.
Old 08-27-2013, 10:59 PM   #21
mitch808
Member#: 10228
2002 Subaru WRX
You sure it is not just an incorrectly setup clutch pack and/or preload, or even a worn unit?
Even race cars in Arizona and Nevada are not putting in diff coolers, and their temps get hotter than your tropical paradise.
mitch808 is offline   Reply With Quote
Old 08-29-2013, 01:11 AM   #22
russian777
Member#: 300971
Rally blue
Consulted a fellow racer with a the exact same lsd , apparently these models lock up with even slight temperature increase from spirited driving, causing the torque bind etc.
the temperature sensor is also a good idea
Old 08-29-2013, 01:24 AM   #23
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
murrdogg24 is offline   Reply With Quote
Old 08-29-2013, 05:43 PM   #24
russian777
Member#: 300971
Rally blue
Originally Posted by murrdogg24 View Post
this is why nasoic rocks
Old 09-01-2013, 07:04 PM   #25
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
I was going to mention that perhaps you can change the settings on your diff. Less clamp load perhaps?
thefoos is offline   Reply With Quote
