Old 08-23-2013, 10:14 AM   #1
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Default 05wrx goes 16-17afr at wot
Problem solved! thanks
cosseywrx is offline   Reply With Quote
Old 08-23-2013, 11:26 AM   #2
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Did u flow test injectors before installing them?
Old 08-23-2013, 12:03 PM   #3
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
There is no way it's 16:1 at wot. What wide band are you using? Where is the O2 sensor for the wide band located?
With that kind of afr it wouldnt be a "knock" it would be a BOOM!!
Brother EddieJ. is offline   Reply With Quote
Old 08-23-2013, 12:16 PM   #4
Member#: 301037
2004 Forester XT
I would suggest taking it to a reputable shop for a look over and a dyno tune. It is hard for anyone even an experienced tuner to diagnose problems like this over the computer or Logs.
art@grimmspeed is offline   Reply With Quote
Old 08-23-2013, 02:10 PM   #5
cosseywrx
Member#: 276443
Ive had the injectors installed for 2 yrs. Multiple tunes.
I also changed the maps to verify it was not the tune.
Aem wideband located at the end of the dp.
No flow test has been done since problem.
No dyno with 400 miles of me.
Live in alaska
Old 08-23-2013, 02:13 PM   #6
cosseywrx
Member#: 276443
And yes it was 16 afr at wot. I have logs to prove that.
Old 08-23-2013, 03:40 PM   #7
cosseywrx
Member#: 276443
Can the FPR be stuck and only work fine under vaccum? Gonna get a fuel press gauge.
No flow test benches in alaska for injector tests
Old 08-23-2013, 03:45 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
^ this. that AEM's calibration is f'd up or just seeing too much surrounding air at the end of the pipe.
Old 08-23-2013, 03:49 PM   #9
Brother EddieJ.
Member#: 181617
2004 wrx
My honest guess is the o2 sensor is borked. Buy a new one and go from there. I have the same gauge and this happened to me. Lets see the 16:1 afr logs to prove the wide band is correct. 16:1=BOOM
Old 08-23-2013, 06:35 PM   #10
cosseywrx
Member#: 276443
Car still has knock and sputtters. Aem gauge is not gonna cause that.
16.2 on a most recent log with aem. 17 on the new front o2 sensor. This a a cell screenshot. Can upload doc once i get home.
Dont be dicks just tell me what ya think.
Old 08-23-2013, 06:56 PM   #11
cosseywrx
Member#: 276443
Also im on a carberry rom
Old 08-23-2013, 09:46 PM   #12
JonnyV2889
Member#: 197384
2006 WRX Ltd
For starters find a tuner? You need to add fuel or timing asap. I wouldn't keep going WOT with the 3 degrees pulled.
JonnyV2889 is offline   Reply With Quote
Old 08-24-2013, 01:51 PM   #13
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
so what was the issue??
Paul is online now   Reply With Quote
