Old 08-22-2013, 04:11 PM   #11751
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Originally Posted by Silver08Waggs View Post
Just a thought for now, might try and pick up a set of coilovers so I would be selling my koni/h&r set up...
Say WHAAAT?!
That's a downgrade...
Fendyman is offline   Reply With Quote
Old 08-22-2013, 04:21 PM   #11752
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Originally Posted by Fendyman View Post
Say WHAAAT?!
Really think so? I wanna go a little lower really and haven't found many reviews of ground control kit with the konis
Silver08Waggs is offline   Reply With Quote
Old 08-22-2013, 04:30 PM   #11753
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Say WHAAAT?!
Thought the same thing.
Old 08-22-2013, 04:33 PM   #11754
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Guess I'll shoot ground control an email see what they suggest for spring rates
Old 08-22-2013, 04:57 PM   #11755
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
I think its all a matter of if you like performance or comfort when it comes to suspension
SCNEot is offline   Reply With Quote
Old 08-22-2013, 05:03 PM   #11756
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
I know that I like how it rides now that's why I have no idea about spring rates I'll hit them up for suggestion and I'm at a happy medium with performance and comfort I would like a little more performance though and a little more low.. Lol
Old 08-22-2013, 05:34 PM   #11757
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Stiffer isn't always better. You gotta match the the suspension to the surface. It's difficult to make a comparison since the H&R springs are progressive. But I have been very pleased with my 217/194 set-up. I think a 4k/5k (224/280) would be a very comfortable solution. But it depends on the roads that you usually drive on. If your roads are super bumpy, you'll want something soft. But if they're super smooth, you'll want something stiff. If you can't get a perfect match, I believe that it is better to be softer rather than firmer.
And a list of known spring rates.
http://www.wrxforums.com/forums/13-3...tes-drops.html
I know I've posted this before. I feel like it is a good starting point for research.
Also keep in mind that you probably won;t see exactly the same results. Our N/A cars are about 200 pounds lighter than their F/I counterparts which everything is designed for.
JourdanWithaU is online now   Reply With Quote
Old 08-22-2013, 05:36 PM   #11758
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Thank you very much I'll do some reading and see what GC has to say about it
Old 08-22-2013, 05:54 PM   #11759
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
And to sound like a total noob, progressive spring rate means? Rate changes as springs compresses unlike other springs that the rate is the same no mater what?
Old 08-22-2013, 07:14 PM   #11760
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Picked a wide angle lens yesterday. Bought it for landscape work. Figured i'd take a few pics of my car.
Impreza 3-4 Front View by Fancyftwork15, on Flickr
Impreza 3-4 Rear View by Fancyftwork15, on Flickr
Impreza Interior Side by Fancyftwork15, on Flickr
Old 08-22-2013, 07:42 PM   #11761
.HaVoK.
Member#: 229726
'09 2.Slow
What happened to the wheels?
.HaVoK. is offline   Reply With Quote
Old 08-22-2013, 07:54 PM   #11762
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Put my current ones of for my road trip to CO. Decided it was time to sell the gold Rotas. I will be buying brand new come spring time.
Old 08-22-2013, 07:55 PM   #11763
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Here's a couple from the Garden of the Gods in CO Springs. Awesome place!
Impreza Garden of the Gods by Fancyftwork15, on Flickr
Impreza Garden of the Gods 2 by Fancyftwork15, on Flickr
Old 08-22-2013, 10:38 PM   #11764
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
^^ those seats look nice, hope they aren't to expensive to pick up.
Old 08-22-2013, 11:37 PM   #11765
fourthbrook
Member#: 362680
2009 Impreza 2.5i
Has anyone had any success with sport mesh grills off ebay? If so can you link me too the one you have?
I'm kind of interested in this... but Im afraid it will look cheap. Also how would I go about mount my subie badge on it?
fourthbrook is offline   Reply With Quote
Old 08-23-2013, 09:42 AM   #11766
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Email GC nothing back yet, but what about h&r Street coilovers they run a progressive spring and shocks valves to match them? Should be similar to current set up.
Old 08-23-2013, 09:54 AM   #11767
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
If its similar why are you getting a new setup?
You are probably at or slightly below the correct height for optimal performance.
Old 08-23-2013, 10:06 AM   #11768
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
I do wanna go lower and for some reason I wanna put more money into this car :-(
Old 08-23-2013, 10:24 AM   #11769
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
A progressive spring will get stiffer as it is compressed. A linear spring will maintain it's stiffness.
For example, if you put 10lbs on a linear spring and it compresses an inch. If you put 20lbs on it, it should compress 2 inches. 30lbs, 3 inches, and so on. 10lbs on a progressive spring may compress it an inch. 20lbs may compress it only 1.5 inches. 30lbs, 1.75 inches.
Progressive springs are designed to be more comfortable than linear springs. They're not exactly ideal for performance applications.
That looks a lot like the C-mod grille that I got a while back. I was not very impressed with it. Super cheap, and it did not fit very well.
I don't think that the dampening on the coilovers will be as good as the Konis. But I don't have any experience with H&R coils.
I have also noticed that GC kinda sucks at replying to their emails. You kinda gotta poke them a couple times before they reply. Not the greatest thing, but when they do reply, they're good.
Old 08-23-2013, 10:29 AM   #11770
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Coming in hot lol thank you, and idk what I want but maybe I should spend money elsewhere on the car like the stereo I was talking about last week or header and exhaust I just don't know haha because the suspension is pretty stacked but I want like 1/4-1/2inch lower for the look and you guys are probably right with its good as is should just stick with hight and have the better handling
Old 08-23-2013, 10:56 AM   #11771
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
You should just save your money and take a good month or two to decide what you really want to do instead of just throwing money at your car to make it "cool".
Old 08-23-2013, 10:57 AM   #11772
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
Yeah I know what your saying
Old 08-23-2013, 11:47 AM   #11773
fourthbrook
Member#: 362680
2009 Impreza 2.5i
Thanks do you possibly know where I can find this style grille, but in black?
Also Hellas or no Hellas. I would like to beef up the subies pathetic horn but i don't want to be just another hella fan boy. Any of you have them. Do you like them?
Old 08-23-2013, 01:45 PM   #11774
SCNEot
Member#: 344260
2009 Impreza OBS
Sage Green
Working on sketches for a fender flare/body kit. ONLY DRAWINGS at this time, may become plans if they are good, they do look STI-ish but with Polo WRC style fenders.
Old 08-23-2013, 03:26 PM   #11775
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
http://www.subarugenuineparts.com/pr...oducts_id=1267
If you want supertones but don't want to flaunt them, why not paint them black?
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
