Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 08-23-2013, 08:02 PM   #2076
erok81
Member#: 300717
2004 WRX
JBP
Sweet. Thanks for the replies. Looks like I have some work to do. Nice to see its doable without extending those.
erok81 is offline   Reply With Quote
Old 08-23-2013, 08:24 PM   #2077
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
I'm sure everyone has done this so does anyone have install pics of PS lines. In trying to figure out where on the rack they run to. Pretty sure I followed them both down to the right spots but I can't get at the low pressure lines bolt. Any help please
under0athh51189 is offline   Reply With Quote
Old 08-24-2013, 12:51 AM   #2078
erok81
Member#: 300717
2004 WRX
JBP
Originally Posted by arisking View Post
Back in the car, and out through the firewall under the brake booster. What I did. No extending necessary.
If you do this what do you end up extending? I don't care about the alternator stuff or any of the easy things. I just want to stay away from anything engine harness related extending.
Old 08-24-2013, 02:19 AM   #2079
TyConway
Member#: 193189
2002 wrx
Originally Posted by No Limit Motorsport View Post
Im going on 3.5 months now waiting for my wiring harness (was quoted 3 weeks). I call them 3 times a day as the car is useless now. Worst company I have ever dealt with. They made me send them the entire harness out of the car, fuse boxes and all. Almost 60lbs of wiring. Like an idiot I paid in full before I sent anything out. We have missed 4 race events already this season.
I am about to fly down there to handle it and get my stuff back. I don't think I have a choice, I have been getting lied to almost daily for months now. Otherwise the car is totaled.
This is how the car has been for the past 3.5 months now
Chase (chasebays) is local to me, hes moved shops 3 times in the last couple of yrs that i know of... Every time I've bought stuff from him, been cash on pickup... harnesses, made within a couple of days. But i did have wiring issues on a ls1 harness. Had to repin alot of the connectors.
TyConway is offline   Reply With Quote
Old 08-24-2013, 07:17 PM   #2080
arisking
Member#: 245282
04 JBP STi
Putting my fuse box in the steering column area only light wires needed to be extended, besides alternator stuff. No engine harness stuff.
Extended wires, 04 STi.
Not too bad.
arisking is offline   Reply With Quote
Old 08-25-2013, 01:44 PM   #2081
erok81
Member#: 300717
2004 WRX
JBP
Nice. Thanks for posting that. Extending some headlight wires (especially that many) is nothing. The way I have it now I was going to have to extend the alternator stuff anyway.
Looks like the fender is coming back off.
Old 08-25-2013, 04:47 PM   #2082
arisking
Member#: 245282
04 JBP STi
Yup, it's easy.
I de-pinned the fuse box wires, one at a time, and fed them through to the inside of the car. Then after feeding them you can decide which ones need extending.
Process of elimination of sorts.
Old 08-26-2013, 11:03 PM   #2083
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Yup, it's easy.
You wouldnt happen to know what wire colors etc? I have a 04 Sti and this would help me out a ton with bringing the fuse box into the interior.
Big-Sexy907 is offline   Reply With Quote
Old 08-27-2013, 11:56 AM   #2084
arisking
Member#: 245282
04 JBP STi
*double post*
Old 08-27-2013, 11:57 AM   #2085
arisking
Member#: 245282
04 JBP STi
I don't know what each wire does if that's what you're asking.
Take off the fender. Remove grommet from wall that goes into car. Undo the connections from the fuse box. Then de-pin each wire and feed it through grommet one at a time. Plug in each wire you've de-pinned right after you moved it through the grommet.
Eventually you'll have transfered the connector piece through the grommet without tearing the grommet open to get the connectors through. Time consuming! But it works.
Best I can explain it without having pics.
Old 08-27-2013, 12:10 PM   #2086
3mlwhly
Member#: 217648
01 2.5rs
That sounds like a pretty good idea
3mlwhly is offline   Reply With Quote
Old 08-28-2013, 01:44 AM   #2087
erok81
Member#: 300717
2004 WRX
JBP
Yup, it's easy.
This is going to go much better than the way I had it before. Fuse box inside. Engine harness I'll hack a hole in the firewall. Also figured I'll run my headlight harness on the other side in the bumper so that's hidden too. And the washer bottle fits perfectly inside the bumper. No more running wires for that thing.
Old 08-28-2013, 02:55 AM   #2088
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
No, basically I was asking if you could post which wires you extended. For example:
Purple w/ white stripe
Red w/ Yellow Stripe
Green w/ Blue Stripe
Etc.
Old 08-28-2013, 04:27 AM   #2089
arisking
Member#: 245282
04 JBP STi
Wires I extended
Old 08-28-2013, 07:28 AM   #2090
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Wires I extended
That picture is nice, but not that helpful.
Never mind, I'll figure it out...
Old 08-28-2013, 01:43 PM   #2091
arisking
Member#: 245282
04 JBP STi
Well it really is something you just figure out as you go along.
You'll get it! Trust me, its not that hard. :P
Old 08-28-2013, 02:04 PM   #2092
erok81
Member#: 300717
2004 WRX
JBP
Yep. Exactly. Once you lay it out it is really obvious which ones will still be in the fender and need to be lengthened.
Old 08-28-2013, 10:48 PM   #2093
kh15
Member#: 132400
2006 WRX
where are you guys moving the bcs to? in the cabin?
kh15 is offline   Reply With Quote
Old 08-29-2013, 12:58 AM   #2094
arisking
Member#: 245282
04 JBP STi
I have a neat location. I'll get a pic tomorrow.
Old 08-30-2013, 01:45 AM   #2095
erok81
Member#: 300717
2004 WRX
JBP
You should post a pic of where you mounted your fuse box too.
Old 08-30-2013, 11:53 AM   #2096
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
In for pics!!!!
Smurftastic is online now   Reply With Quote
Old 08-30-2013, 12:07 PM   #2097
3mlwhly
Member#: 217648
01 2.5rs
Me too
Old 08-30-2013, 07:27 PM   #2098
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
couple of shots from WekEast last weekend..
StealthWRX is offline   Reply With Quote
Old 08-31-2013, 05:51 PM   #2099
arisking
Member#: 245282
04 JBP STi
Something different. Fuse box pic soon.
Old 08-31-2013, 07:09 PM   #2100
25rsti
Member#: 166324
No taping the lines? jk
Full engine bay pic, please.
25rsti is offline   Reply With Quote
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 09:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 03:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 08:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 01:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-15-2004 11:58 PM
