Old 08-14-2009, 03:36 AM   #101
vinxH
Member#: 159796
2006 WRX
there isn't anything you can do to fool the driver's seat position sensor or the passenger occupant detection module unless you know how to manually reprogram the thing. as for the seat position sensor though, you can buy an oem seat for cheap and strip it off and attach it to your new seat.
and agreed... modding is fun and all, but not at the cost of safety... which is why i've kept my oem seats even though i hate them.
and as far as i know, once you swap the occupant detection module, it still won't be normal operation. the passenger airbag isnt just ON or OFF, it actually detects the weight of the passenger which in turns tell the airbag how hard to deploy... all of this gets messed up when you place the module in another seat that has not been properly positioned, which is why the car manual states that it has to be calibrated when you ever you mess with it.
if you've ever gotten the occupant detection module replaced under warranty for whatever reason, you'll realize that the dealership will test the system to see whether it is detecting the weight of the passenger correctly. simply sitting on the seat to see if it goes from 'OFF' to 'ON' isn't enough if you are expecting the safety of your car to be at its full potential. if you're swapping it between OEM seats, chances are the module will be correctly positioned if you put it back where you took it out from.... but for aftermarket seats.... its not the same geometry as the OEM.
the occupant detection module detects in two readings... whether its someone adult-sized or child-sized. if you have aftermarket seats that sinks down more than the oem seat as you sit on it, it may actually lighten the load a bit from the bladder and cause it to think that an adult is a child, or if its real firm, it may be reading more load than it should be, and think the child is an adult.
vinxH is offline   Reply With Quote
Old 08-14-2009, 04:23 AM   #102
Nitrous
Member#: 136929
I didn't read through the thread, but I have an '07 and I swapped '04 STi seats into my car. With a quick readthrough of Trooper's thread, all you have to do if you own an 06, is to remove the weight bladder from your stock seat, and put it into your aftermarket seat if it's possible to put it somewhere..
Nitrous is offline   Reply With Quote
Old 08-14-2009, 02:05 PM   #103
vinxH
Member#: 159796
2006 WRX
^perhaps you should read my last paragraph... or the last two paragraphs of the post above.
Old 08-14-2009, 10:03 PM   #104
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
the passenger side bag bladder outa my 06 tr seat works just fine in an 04 wrx seat in my 06
tested with seveal passengers of different sizes/weights and the results were virtually identical to the stock seat
Old 02-20-2010, 03:15 PM   #105
BlueSubaru01
Member#: 95499
This thread was spot on. swapped in 2 04 wrx seats into a 2006 TR, and just needed to move over the bladder on the passenger side, and put a 2.2K resistor in the driver side. Worked first time, like a charm!
BlueSubaru01 is offline   Reply With Quote
Old 02-20-2010, 05:05 PM   #106
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Originally Posted by ommmjido View Post
i've installed a Recaro SRD into my 06 TR. the airbag light is on, where can i buy a resistor for it?
Is this seat pushed back the farthest that it will go?
eurospek is offline   Reply With Quote
Old 03-16-2010, 04:52 PM   #107
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
1. Ok, So I understand the dangers of the airbag. However I can't move my seat back all the way if it were to be deployed, so it will either hurt like hell if it ever decides to blow, or it'll hurt me more than necessary.
2. I'll need a 3.3 ohm resistor and a 2.2 ohm resistor(driver) for for the side airbag.
3. I'll need to move the pressure bladder for my new seats.
4. The two things I'm still unsure about are the Seat belt latch detection, and the seat position sensor. Can someone please pm me on more info, because I plan on putting a harness bar and using harnesses. Is it possible to do something about the driver airbag never going off since I'll be using my harness bar and harness?
azer408 is offline   Reply With Quote
Old 03-16-2010, 05:54 PM   #108
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
Can anyone update me on this?
Old 03-18-2010, 03:13 AM   #109
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
Anyone?
Old 03-19-2010, 11:28 PM   #110
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
bump before my trip to frisco.
Old 03-27-2010, 11:35 PM   #111
chadb
Member#: 198179
2007 STI
UGM
what if u pull the fuse..
chadb is offline   Reply With Quote
Old 04-20-2010, 02:27 PM   #112
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
I finally said **** it and decided I might just pull my whole airbag module. Lol, No need for airbags with a harness.
Old 04-22-2010, 05:07 PM   #113
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
Does anyone know if this will throw a code with the BCM or should it be fine? Because I won't be needing the airbags with my harness.
Old 04-22-2010, 06:03 PM   #114
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
A harness on the street is not a good idea. Especially without a HANS device.
http://forums.nasioc.com/forums/show....php?t=1827312
As an airbag engineer, I get to see crash data. Trust me, you want your airbags and you want your factory belts. The two are designed to work in conjunction and they do a very respectable job.
Old 04-23-2010, 01:38 PM   #115
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
damnit. now I have to sell my harness and bar.....
Old 08-25-2013, 05:29 PM   #116
Cruzmissile
Member#: 243620
I know this post is kinda old but this the only write up I have been able to find on this subject and all the picture links are broken. I don't suppose the original poster has these pics and can repost them? I am trying to make sure the airbags will operate. Thanks.
Cruzmissile is offline   Reply With Quote
Old 08-25-2013, 06:44 PM   #117
TRooper
Member#: 62422
2006 Lotus Elise-
1.8L of Fury!!
Here is a writeup that I wrote for this swap.
http://forums.nasioc.com/forums/showthread.php?t=996050
TRooper is offline   Reply With Quote
Who has aftermarket seats in their car in the NOVA area? BillyD Mid Atlantic Impreza Club -- MAIC 11 07-12-2005 07:35 PM
WRX seats or aftermarket seats in '95 Legacy journey Legacy Forum 5 12-28-2004 06:13 PM
Any ideas for aftermarket seats in Impreza L? SubieFreak431 Interior & Exterior Modification 5 03-11-2004 10:59 PM
Anyone installed aftermarket seats in their car? Thug New England Impreza Club Forum -- NESIC 33 01-02-2003 11:30 PM
Who has aftermarket seats in their GC8? imprezawd Interior & Exterior Modification 0 12-19-2001 01:13 AM
