Old 08-22-2013, 11:25 AM   #151
cannon98
Member#: 187775
16 Sti
CWP
nice read, definitely look to do this when I get my 14' wrx in
cannon98 is offline   Reply With Quote
Old 08-23-2013, 12:19 AM   #152
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Not sure if this has been asked, gas oven or electric? Not sure if it would make a difference
imac6471 is offline   Reply With Quote
Old 08-23-2013, 07:21 AM   #153
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Great question, I used an electric for these lights that I have been doing lately. Any that I have done before were done in a gas stove. They both work really well but I feel that the gas allows you to go lower in temperature when you are using it to bake paint.
Old 08-24-2013, 03:24 PM   #154
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Thanks, this question actually came up at a meet I was at last night ha-ha. They had the same concern I had at first. I was going to do it this weekend but no where actually carries the metalcast yellow. Looks like I will be ordering it online. Thanks for the awesome write-up!
Old 08-25-2013, 03:14 PM   #155
ixwrxxi
Member#: 334215
2015 Forester
Finally did it..
ixwrxxi is offline   Reply With Quote
Old 08-25-2013, 05:59 PM   #156
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
should i use gloss black or flat black? Is there a certain type of paint required?
WhatsASubie is offline   Reply With Quote
Old 08-25-2013, 07:59 PM   #157
dsn112
Member#: 332561
2016 ChargerScatPack
Flat black high heat paint is the reccomended paint. BBQ grill paint is good for this
Old 09-13-2013, 09:40 PM   #158
Overland04
Member#: 293311
2013 FXT 6-Speed
Just finished up another members STi headlights.
This set received yellow high-beam bowls, satin black housing, black turn signal, and black reflector.
Perfection!
Old 09-13-2013, 09:43 PM   #159
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Ooooh snap! That looks sick!
ChesterWRX is offline   Reply With Quote
Old 09-13-2013, 09:51 PM   #160
hdorre
Member#: 367339
^^ Im actually speechless haha.. Those look amazing!
hdorre is offline   Reply With Quote
Old 09-13-2013, 10:06 PM   #161
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks guys!
If anyone has interest in getting theirs done, send me a message at: Facebook.com/OverlandDesigns
Cheers
Old 09-14-2013, 02:07 PM   #162
rambosabeast
Member#: 364175
2013 WRX 5d
Crystal Black Silica
Nvm, got that, now I have standard non-HID lights and I removed 3 bulbs, 3 10mm screws, and 6 Phillips head screws. How do I remove the wiring that the bulbs were connected to? It runs through the housing.
rambosabeast is offline   Reply With Quote
Old 09-14-2013, 11:41 PM   #163
Overland04
Member#: 293311
2013 FXT 6-Speed
To get the harness out from inside the housing, you'll need to remove the plug from the bottom of the light. It should be a smaller 1" grommet.
One you remove that, the harness can be fished out from there.
Are you sure you up for splitting and painting? Hate to see you damage a $700 light. PM me if you run into trouble.
-Jason
Old 09-14-2013, 11:49 PM   #164
rambosabeast
Member#: 364175
2013 WRX 5d
-Jason
I looked on this thread and saw that the light can be baked with the wiring still in the housing. I removed the bulbs just to be safe and used the same paint you did after I got it seperated. I hope it's ready to be reinstalled tomorrow. My concern is refitting everything, and then getting it right with no fogging later. Is there any additional type of adhesive that you know is effective if the original adhesive leaks?
Old 09-14-2013, 11:58 PM   #165
XERO287
Member#: 253541
2011 WRX 5DR Premium
-Jason
I see what you did there
XERO287 is offline   Reply With Quote
Old 09-15-2013, 07:41 AM   #166
Overland04
Member#: 293311
2013 FXT 6-Speed
I use a small amount of (THIS) butyl rubber glue to seal the areas near the screws. Before I started using this stuff I was still able to get a good seal with fogging issues. As long as you heat the housing and lens enough to get the glue soft again, you should be more than fine.
Good luck!
Old 09-15-2013, 10:07 PM   #167
SnowBlack
Member#: 363479
2016 WRX STI
Hyper Blue
Post 3
SnowBlack is offline   Reply With Quote
Old 09-15-2013, 10:19 PM   #168
willowlee
Member#: 358533
2013 sti sedan
wrb
Wished all write ups was like this. Very thorough and with lots of pictures. Good job.
willowlee is offline   Reply With Quote
Old 09-15-2013, 10:21 PM   #169
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks man, enjoy!!
Give it a shot too, it's a fun afternoon project.
Old 09-16-2013, 09:10 AM   #170
CJ3W
Member#: 364657
2013 WRX Premium
Dark Metallic Grey
Overland, just a beautiful job and write up. This is exactly what I was hoping for in a DIY. I now have the confidence to do it myself. Your car looks excellent too. I love it!
CJ3W is offline   Reply With Quote
Old 09-16-2013, 11:26 PM   #171
makikogi
Member#: 192990
2012 Impreza WRX
anyone done a gunmetal housing? I have a white wrx and sometimes I think it's a little racoon-ish when the headlights are blacked out too much. I do hate the chrome but love the look of the highbeam/DRL housing painted yellow.
makikogi is offline   Reply With Quote
Old 09-17-2013, 07:21 AM   #172
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
I sprayed my turn signal chrome cup gunmetal. I'll see if I can get a pic for you. I wouldn't how ever spray the high beam housing with gun metal. 2 very light coats of reflective gunmetal really cut down on the visibility of the turn signal, it is just above the level that I would be trying to figure out how to take it off, for respect of other drivers.
00camaro16 is offline   Reply With Quote
Old 09-17-2013, 04:19 PM   #173
Erod13wrx
Member#: 365694
2013 Impreza WRX
Satin Pearl White
That looks legit, I've been wanting to do this to mine but i guess i dont want to mess up the headlight. How hard or easy is it to mess up the headlight by baking it?
Erod13wrx is offline   Reply With Quote
Old 09-17-2013, 05:06 PM   #174
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Follow the directions and you'll be fine. Just don't be Like me and not take out all the screws then wonder why it isn't opening (stupid moment, we all have them). Its quite easy.
Old 09-17-2013, 05:27 PM   #175
currymaciel
Member#: 346941
2010 WRX
So are you saying no dark colors? Im wanting to do mine, and i want to just black the whole thing out, maybe some red accents. I rarely use high beams but Id still rather not cut down on visibility
currymaciel is offline   Reply With Quote
