Old 08-25-2013, 11:51 AM   #1
Gahrmm12
Member#: 351593
Default Lug problems
Where can I get some colored lugs that fit the stock wheels on a 2011 Sti limited?
All the ones I find are for aftermarket wheels
Gahrmm12 is offline   Reply With Quote
Old 08-25-2013, 11:58 AM   #2
sc00by4life
Member#: 97135
man if only we had a ton of threads about lug nuts.
try searching. the answer is easier than you think.
Old 08-25-2013, 08:08 PM   #3
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Wow...
Old 08-25-2013, 09:34 PM   #4
Trustkevin13
Member#: 259184
2008 Subaru WRX
Lol, or just answer and be done with it. Muteki's are the one I ran with stock rims. Most say aftermarket to prevent sueing them. Make sure its 1.25x12mm (i think, you better double check that) and a certain style fitting end. I forgot, it's been a while. Sorry mate.
Trustkevin13 is offline   Reply With Quote
Old 08-25-2013, 09:58 PM   #5
Dale2011WRX
Member#: 304299
2011 WRX, white
Come on mate, do the research for this guy.
Old 08-25-2013, 10:09 PM   #6
garamas
Member#: 169194
04 STI
You need 12x1.25 conical lug nuts 60 degree taper
garamas is offline   Reply With Quote
Old 08-26-2013, 10:08 AM   #7
08Legacy-GT
Member#: 325949
regardless of the specs, all brands say DO NOT USE ON OEM WHEELS. Doesn't get any more specific from the manufacturers of the product (YES I'm talking Muteki)
08Legacy-GT is offline   Reply With Quote
Old 08-26-2013, 10:51 AM   #8
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
Get your stock ones powder coated?
Dmochowski is offline   Reply With Quote
Old 08-26-2013, 10:54 AM   #9
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Not this bs again.
The manufacturers say that as a blanket statement to cover their asses for liability reasons. It makes more sense for them to say
"Do not use on OEM wheels"
Instead of
"Do not use on OEM wheels except for [this car] and [this car] and [this car], those are OK"
Most Subarus (I'll say most because I'm not positive if all) use the same 60* taper conical seat that all tuner lugs use.
Therefore it is perfectly fine to use "tuner" lugs on Subaru OEM wheels with the same seat.
gsrcrxsi is online now   Reply With Quote
Old 08-26-2013, 08:48 PM   #10
sc00by4life
Member#: 97135
Originally Posted by gsrcrxsi View Post
Not this bs again.
Instead of
ALL subarus use the exact same 60* tapered seat that is found on aftermarket lugs.
a simple search would've yielded those results, without needing to start a new thread (when we have far too many already).
Old 08-27-2013, 10:49 AM   #11
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
thanks for the clarification. i was only unsure about the REALLY old subies.
Old 08-28-2013, 12:31 PM   #12
08Legacy-GT
Member#: 325949
Not this bs again.
Instead of
Cover there asses for good reason. I normally go by the manufacturers and what they say. I don't show you having any pictures or you using them so ......
Old 08-28-2013, 12:38 PM   #13
sc00by4life
Member#: 97135
I have. I do. Stop posting. I recognize that you're new around here, but you're adding to the confusion and misinformation.
The seat is IDENTICAL. that's all that matters.
Old 08-28-2013, 01:33 PM   #14
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Really? We've all told you they will work with stock wheels.
THEY WILL WORK WITH STOCK WHEELS!!
Does that make it any more clear?
An here's a pic of McGard spline drive lugs & locks on stock STI wheels.
mav1c is online now   Reply With Quote
Old 08-28-2013, 02:42 PM   #15
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Cover there[their] asses for good reason. I normally go by the manufacturers and what they say.
I understand what you're saying - I typically go by what the manufacturers say, too. But in some cases, it's abundantly obvious that the manufacturers put a disclaimer on their product for no reason other than to cover their asses against BS, not because there's some fundamental problem with the product they're selling. One need only look at how many aftermarket performance parts are marketed as "FOR OFFROAD USE ONLY" to see examples of that.
An aftermarket lug nut with a 60deg conical seat and the proper 12mm-1.25 threads has the same functionality as an OEM lug nut with a 60 deg conical seat and 12mm-1.25 threads.
How long did it take you to search through the 1700+ posts that gsrcrxsi has made to see whether or not he has posted pictures of aftermarket lug nuts on OEM wheels?
Here's a picture of RAYS lug nuts on my V7 wheels:
I've also used McGard Splinedrives on those wheels.
Here's a picture of RAYS lug nuts on the '99/00 2.5RS wheels I used to have:
Here's a picture of RAYS lug nuts on my old '02+ optional BBS RK wheels:
And I don't have any pictures handy, but those RAYS lug nuts were also used with 17" UK WRX wheels that I had years ago.
Patrick Olsen is online now   Reply With Quote
Old 08-30-2013, 02:08 AM   #16
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
I have ran both blox and muteki's on my OEM JDM Ver. 7 goldies too. I have pics to prove it if needed...... lol
pho_shizzle is online now   Reply With Quote
Old 08-31-2013, 08:37 AM   #17
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
I'm using mutekis and they're just fine
Mr. Lin is offline   Reply With Quote
