Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 08-27-2013, 06:36 PM   #1
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Default Legacy Down After Twin To Single Swap, Help Me Out
Hey guys, so i have a BD5 94 legacy RS Sport not the GTB but the sport.
A couple months back i decided to do the single turbo swap off the "dirty ol legacy" webpage, I have now successfully got everything back in and went to turn it over to have it not turn on, it cranks, and sounds like one cylinder gets ignition but it does not fire up completely.
i went over the grounds and whatnot and everything looks to be hooked up. i have a couple questions of my own but need the genius' of NASIOC to help me out.
First, on your injectors there is a black and grey harness for each side, which one goes to which cylinders(my understanding is that grey is the front cylinder and black is the back, same as the coils).
Second, the fuel lines coming out of the firewall (3 of them) from top to bottom which goes where? top to vent, middle to return and bottom to fuel filter(feed)? or how does that go?
Third, what ECU goes with the 440cc injectors? and will an RA and regular one work for the same injectors?
Forth, are there any sensors that would inhibit the car from starting? i have most of them on but the O2 is not and the original exhaust cat sensor is removed as well.
Fifth, Is there more then one intake ground? i have the main one behind the alternator hooked up but i have seen talk of another but had no luck finding it. I was told it might be one related to the injectors, where is this ground they speak of?
Sixth, i did the parallel fuel rail mod, i dont know if this info will affect but im telling
Seventh, Electronic boost controllers, i swapped for a manual, is this gonna be an issue with removing the black box and then converting to MBC? should i source a EBC and put that in?
can any one else shed light on this? it would be greatly appreciated. or if there is any idea of what it could be or methods to track down the issue, it would all be helpful. Thanks, Paul!
93GC8Dub is offline   Reply With Quote
Old 09-03-2013, 04:28 PM   #2
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
what hot mess!
Baja_Gernaut is offline   Reply With Quote
Old 09-05-2013, 01:40 AM   #3
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Ya well I'm down to just not having spark on the rear two cylinders, got fuel, and the cam gears are the same, timing belt for the third time,
How many grounds do the ingnition systems have?
Old 09-05-2013, 11:08 PM   #4
wolfd123
Member#: 365331
i BELIEVE THERE ARE TWO GROUNDS TO THE IGNITION. At least there are two on my legacy 2.2
wolfd123 is offline   Reply With Quote
Old 09-06-2013, 11:10 AM   #5
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
are they both on the intake? or two to the ECU? will a EJ20K ECU run the 02WRX coilpack conversion coils(with no ignitor box, built in ignitor)??
Old 09-06-2013, 09:09 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I would suggest trying these questions in the Subaru Conversions forum, as there are way more folks there that have dealt with engine swaps. I realize this isn't an engine swap, but the issues you're dealing with are the sort of thing that people run into with swaps and conversions.
Old 04-15-2014, 01:08 PM   #7
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
