Old 08-22-2013, 01:15 PM   #1
Stage13
Member#: 333934
2005 STi
wrb
Default how big of injectors can u run with stock 05 sti ecu
Whats the biggest the stock ecu will allow u to tame? Im looking into 1600s but wpuld like 2150s for safety but dont wanna go aem quite yet mainly for $$ reasons
Stage13 is offline   Reply With Quote
Old 08-22-2013, 07:01 PM   #2
Paidfor
Member#: 267815
Be in awe
dont hate .)
That's some BIIIGGGG injectors brother..if you don't mind my asking.....what? are you gonna do with this car ? lol
Im not sure how accurate itll be but you can scale injectors to like 9999.99 in opensource if you want to. Of course youd have to tweak the hell out of the MAF, latencies and a bunch of other **** to get it right?
Doable tho I sure.
Old 08-22-2013, 07:59 PM   #3
Stage13
Member#: 333934
2005 STi
wrb
Well I just ordered aem stand alone to be safe but im currently 600 whp on 28psi we are hoping for 40 psi and 700+ in my 05 sti swapped gc my motor is very well built benson sleeves cp pistons turbo tuff rods h11 h3ad studs arp case studs the hole 9 yards on a 6262 and e85
Old 08-22-2013, 10:22 PM   #4
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Gonna need some better studs for 40psi. You are gonna lift the heads.
Old 08-23-2013, 06:43 AM   #5
Stage13
Member#: 333934
2005 STi
wrb
Coswortg h11 head studs wont hold ?
Old 08-23-2013, 07:32 AM   #6
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I'm seeing people needing 13mm to 1/2 in
Old 08-23-2013, 08:51 AM   #7
dux10
Member#: 235338
2002 Faggin Wagon
srp
I've run id2000's on stock 32 bit ecu's before without issue.
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 08-23-2013, 04:55 PM   #8
Stage13
Member#: 333934
2005 STi
wrb
Well dam lol I ordered aem already oh well anybody need an 05 sti ecu !
Old 08-24-2013, 04:27 PM   #9
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Syick with the aem. Less headache on a build like yours.
fastblueufo is offline   Reply With Quote
Old 08-27-2013, 06:05 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
How hard were they to dial in @ low loads?
When I did some on a 16bit Carberry ROM I had to run full time open loop for smoothest operation at low loads. In closed loop it would buck sometimes on slow acceleration (like stop sign --> school zone type daily driver stuff), same map forced open it was fine and smooth. Any issues like that on the 32bit ROM?
Any time you needed to get on it, the tuning was fine with closed loop, but just that really light stuff AFR would oscillate some.
Old 08-29-2013, 11:13 AM   #11
dux10
Member#: 235338
2002 Faggin Wagon
srp
If you set target afr at lower loads/idle to say 13.5ish its good. The problem with my car was the 4" maf housing. The car drove well enough to drive, but it was not ideal. That car went SD obviously. lol With a normal sized maf housing, it would've been good though. I used CL compensations to dial in a lower AFR at idle/low loads. Other tuners advise tweaking the O2 scaling, but I didn't like that idea.
Old 09-13-2013, 04:54 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Doing it in the compensations seems the right way. That way you can run richer only at the load cells you need to, then lean out the cells that matter more for MPGs.
Tweaking the O2 scaling would change all CL loads. Seems crude.
Full time OL is working well, but I'll try CL @ richer in the low load cells too.
Old 09-13-2013, 09:32 PM   #13
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
As Steve said, try richening it up at low loads. Try 13.5:1 at idle, 14.0:1 while cruising. I'm assuming you're on 16 bit?
Old 09-15-2013, 11:11 AM   #14
dux10
Member#: 235338
2002 Faggin Wagon
srp
Eric, you can target 14.7 beyond 2000rpm. Ithink between 1200-2000 I targetted 14.0
Steve @ Pullz- On Tuning
