Old 08-27-2013, 06:06 PM   #1
protivakid
Member#: 265148
2001 Legacy
Default Keyless entry Lock & the Hatch problem
I have a crosstrek but since it's pretty much the same as the impreza hatch figured I would ask here.
One annoyance I am having is that each time I get out of the car, open the hatch by pressing the button on the back of the car, close the hatch, and then press "Lock" on the keyless entry remote the car does not lock. I have to either wait a minute for the interior lights to turn off and then I can lock it with the remote, or open the driver door and press lock.
This seems like a "broken by design" issue but didn't know if others had a solution to this problem.
protivakid is offline   Reply With Quote
Old 08-28-2013, 12:48 AM   #2
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
My '12 Sport Limited does not do that. I can lock my car immediately after closing the hatch or any door for that matter. I definitely would not like that "feature". Maybe there is a manual override?
Old 08-28-2013, 08:43 AM   #3
KC
Member#: 442
13 Crosstrek XV
00 S2000
My XV does not have to wait either. As soon as the hatch closes, I can lock it sucessfully.
--kC
KC is offline   Reply With Quote
Old 08-28-2013, 09:09 AM   #4
79letour
Member#: 302570
2013 XV
DGM!
My XV will lock as soon as I hit the button.
Old 08-28-2013, 11:23 AM   #5
protivakid
Member#: 265148
2001 Legacy
Just tried opening the hatch from the keyless entry for the 1st time and that doesn't work either. Has been doing the no lock thing since day 1 too. Just thought it was another annoyance. I'll take it in to see whats wrong.
Old 08-28-2013, 11:54 AM   #6
KC
Member#: 442
13 Crosstrek XV
00 S2000
Good idea. Could be a bad signal or bad programming from the factory.
I can lock the car, and then unlock the hatch using the key fob buttons (and the doors will remain locked except for the hatch.)
At that, if I don't open the hatch within something like 15 seconds or 30 seconds, it will lock by itself if the car is already locked.
The hatch will NOT unlock if the key is in the ignition and using the key to unlock it.
--kC
Old 09-23-2014, 01:59 PM   #7
protivakid
Member#: 265148
2001 Legacy
Well I finally bothered to figure this out. The problem was somehow caused by a LED light I put in the cargo area. I swapped the whole car over to LED bulbs but for some reason the cargo one caused this issue. When I put the regular bulb back in all works fine. Swapped the two bulbs several times to confirm. Most likely the draw from the cargo LED bulb is much less so perhaps I need some sort of a resistor. May bother to look into this or just use the regular bulb. It is really ugly though compared to all the other LED bulbs.
Still VERY odd though locking with the keyless remote after opening the hatch only is somehow related to the hatch bulb...
Old 09-23-2014, 02:52 PM   #8
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
PUP 5W30 87,634 miles
--kC
Is there some type of trick or hidden sequence of buttons to get that to work? That's one of the first things I tried after buying this car, along with unlocking all the doors with a double twist of the key lock. Neither worked.
Sent from my SAMSUNG-SGH-I337 using NASIOC mobile app
CLL_OBP is offline   Reply With Quote
Old 09-23-2014, 09:08 PM   #9
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Glad to see someone figured this out! I've been having the same issue and thought for sure something was wrong. I also have a LED in the cargo area. Weird...
Old 09-24-2014, 05:27 PM   #10
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
It must only be the hatch button that causes it, too, because I never use it and I never have trouble locking mine.
Tha Chakal is offline   Reply With Quote
Old 10-08-2014, 04:19 PM   #11
protivakid
Member#: 265148
2001 Legacy
After doing more research, if you use a CAN-BUS led it will work fine. Though (I think) we don't have a CAN-BUS car the CAN-BUS bulbs have a resistor in them to draw the full current where as a regular LED only draws what it needs. For some reason drawing less than the amount of a regular non-LED bulb is causing the Keyless locking issue. On SuperBrightLED's just grab a CAN bulb and it will work fine.
I didn't want to use a regular bulb as it looked bad with all my other LED's.
