Closed Thread
Old 08-20-2013, 04:54 PM   #4001
79letour
Member#: 302570
2013 XV
DGM!
so far my only complaint with the XV is that it wasnt fully detailed and waxed when I got it. The shop part was closed and they said theyd give it the full new car detail when I bring it in at 3000 miles.
The problem is- they put a ****-ton of wax on some areas and didnt buff it off. Like the roof. It turns white at night or with condensation. And all the black plastic bits like the antenna base have somehow absorbed the wax (i think) causing the parts to turn a light gray dull color. I'm hoping that some sort of wax stripper may help. I don't wanna use Back To Black- its like armor-all once you use it you have to continue.
Sure beats burning oil though!
79letour is offline
Old 08-24-2013, 11:51 AM   #4002
79letour
Member#: 302570
2013 XV
DGM!
it appears subaru changed the specs for oil capacity from 5.3qts to 5.1.
That will make the dipsticks read correctly!
79letour is offline
Old 08-24-2013, 01:17 PM   #4003
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
As long as they don't do this to you, I think you're probably ok. Too bad most of the pictures are no longer available. That dude got a pretty bad run-around from the dealer, and it took intervention by Subaru of Canada to sort out the mess.
lymphomaniac is offline
Old 08-24-2013, 01:25 PM   #4004
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Where did you see that
flyboy1100 is offline
Old 08-24-2013, 03:00 PM   #4005
79letour
Member#: 302570
2013 XV
DGM!
in a pdf that I downloaded. Its a section of the xv/impreza service manual specs or something. I'll try to get you a link.
79letour is offline
Old 08-24-2013, 03:24 PM   #4006
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I'd also be very interested in seeing this.
jr0bb5 is offline
Old 08-24-2013, 04:17 PM   #4007
79letour
Member#: 302570
2013 XV
DGM!
just go and search for a pdf of an XV owners manual.
Its right there in 12-4 in the Specifications section.
https://www.subaru.com/my-subaru/own...ls/search.html
79letour is offline
Old 08-25-2013, 07:23 PM   #4008
79letour
Member#: 302570
2013 XV
DGM!
I think the quiet change was made so that the dipstick level would be easier to read and all.
79letour is offline
Old 08-26-2013, 10:56 AM   #4009
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
It's funny, the next time I change my oil will be the first I'm doing it myself (had free before now), and I was planning to only put 5 qt in and then get up to temperature and check the level because my dipstick has always been high coming from the dealership where I assume they always put in 5.3.
Xafen is offline
Old 08-26-2013, 11:46 AM   #4010
79letour
Member#: 302570
2013 XV
DGM!
How high was the dispick level on your dealer fills?
My record for highest dealer fill was 6++ quarts. It read well over an inch above the full mark!
79letour is offline
Old 08-26-2013, 04:29 PM   #4011
Xafen
Member#: 306398
Camellia Red
My dipstick currently reads ~1/2" above full, from what others have said, that the amount between full and add is 1 qt, that probably is ~0.5 qt overfull.
Xafen is offline
Old 08-26-2013, 05:33 PM   #4012
jr0bb5
Member#: 315353
5MT OBP/DGM
I'd just stick with 5 quarts even especially now that Subaru lowered the fill amount from 5.3 to 5.1 quarts. That's what I plan to do from now on... If I ever get my car back :/
jr0bb5 is offline
Old 08-26-2013, 05:39 PM   #4013
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
the online manual for the 2012 still says 5.3, but for sure i see the 2013's say 5.1
Old 08-26-2013, 05:41 PM   #4014
jr0bb5
Member#: 315353
5MT OBP/DGM
I've been using 5.3 quarts of Amsoil OE 0w20, but now I'm just going to buy 5 quart jugs of M1 or Penzoil platinum. No more measuring out .3 quarts... No muss, no fuss.
jr0bb5 is offline
Old 08-26-2013, 05:43 PM   #4015
jr0bb5
Member#: 315353
5MT OBP/DGM
I'm wondering what the reasoning is behind that other than a lot of people's dipsticks read over full with 5.3 quarts?
jr0bb5 is offline
Old 08-26-2013, 05:46 PM   #4016
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
it makes sense to me, .2qts = about 6oz, which is what i have noticed it takes to get it to read about 1/4" over full from full dot
Old 08-26-2013, 06:00 PM   #4017
jr0bb5
Member#: 315353
5MT OBP/DGM
It's either that or Subaru tweeked the 2.0 fb for the '13+ models because of oil consumption concerns and now they only require 5.1 quarts of oil. Who knows...
jr0bb5 is offline
Old 08-26-2013, 06:41 PM   #4018
lymphomaniac
Member#: 334451
DGM (sedan)
Random guess: 5.3 was the volume required for a bone-dry engine; 0.2 is somehow being retained in the system during oil changes, so a wet system only requires 5.1?
Old 08-26-2013, 06:43 PM   #4019
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
nope, bone dry engine is 6.0qts IIRC
Old 08-26-2013, 07:17 PM   #4020
lymphomaniac
Member#: 334451
DGM (sedan)
I stand (sit?) corrected.
Old 08-26-2013, 07:27 PM   #4021
Xafen
Member#: 306398
Camellia Red
Yep, from my service manual I got last year:
Total capacity at overhaul - 6.2 qt
when replacing oil and filter - 5.3 (as listed in my service manual)
when replace oil only - 5.1
Xafen is offline
Old 08-28-2013, 11:41 AM   #4022
jr0bb5
Member#: 315353
5MT OBP/DGM
Got a bit of good news this morning. My dealership called to let me know that they expect to have the rest of my engine parts within the next couple of days. Hopefully they'll be able to get to it right away once they receive the parts.
jr0bb5 is offline
Old 08-28-2013, 01:17 PM   #4023
79letour
Member#: 302570
2013 XV
DGM!
Good luck man.
79letour is offline
Old 08-28-2013, 04:42 PM   #4024
jr0bb5
Member#: 315353
5MT OBP/DGM
Good luck man.
Thanks man. Keeping my fingers crossed that everything goes smooth and I don't run into any issues when I get it back like some others have.
jr0bb5 is offline
Old 09-03-2013, 02:27 PM   #4025
jr0bb5
Member#: 315353
5MT OBP/DGM
So I got to get a look at my torn-apart engine today while I was at the dealership getting the oil changed on the loaner car. The amount of carbon build up was rediculous! The tech assigned to fixing my car said he's never seen anything like it before on an engine with only 30k miles. He told me it looked like an engine that would have about 200k miles on it that constantly burned bad gas. Still waiting for one of the heads to come in from back order so they can reassemble and get it back to me. Eight weeks now and counting...
Oh yeah, the tech also told me that Subaru has 'unofficially' admitted the problem to inner circles and has quietly implemented a fix at some point. Also, the majority of all the oil consumption problems occur in cars with the 5MT for some reason.
jr0bb5 is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
