Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 08-26-2013, 07:01 PM   #1
APM Tuned
Vendor Sales Rating: (1)
Member#: 282460
2005 Evo-STI
R.R.-WRB
Default Fall Openings...post beating your car up all summer!
So, we're offering a number of products and services for the summer seasons end. The racing season is going to be winding down soon and we know more than a few of you have a need for some items (and some may want to think about investing anyway for their own street cars).
As you all may know Flat 4 Motorsport has released a few products over the last year and we've tested, installed and abused them more than a few times with results working properly.
The F4M Powersteering line kits, includes a low and high kit, will help you retain the power steering pump from failures. With the high pressure systems helping the pump, the low pressure systems help the rack as fluidity in the lines mixed with the reduction of heat going into them will help retain proper fluid operations through the lines. All of the line kits come ready for installation, all fittings and washers are applicable along with padded line clamps.
The kits standard price is 239.99 but they are on sale for 189.99 with discounted installation available. You can purchase the line kits separate for 119.99 each.
F4M Hoses utilize Fragola Fittings, PTFE Stainless Hose and comes with a 5 year warranty.
All hardware is included along with instructions for the DIY people!
-Mark
__________________
[B]APM Tuned[/B]
Phone: (630) 833-8911
Email:
[COLOR="Black"][B][SIZE="1"]Fill out our online survey for up to $50 off your next order from APM -
[/SIZE][/B][/COLOR]
APM Tuned is offline
Old 08-27-2013, 02:44 PM   #2
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Get your street pads back on, slap on some blank rotors, get rid of the fluid and put the car back into the fall mode. Coming within a few more weeks it'll start getting colder out and those race pads are really going to be screaming!
If you still have some events coming like local test and tunes or the last of the SCCA and NASA club stuff, worth while to pick up some of these items while they're discounted! Little hassle later on and no need of doing things "quick, fast and in a hurry".
-Mark
__________________
[B]APM Tuned[/B]
Email:
[/SIZE][/B][/COLOR]
Old 08-28-2013, 03:36 PM   #3
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Most recently, we're having a great amount of gen. pop coming in for maint. Assuming the prices are fair and the turn around time is kept low it's a great way to go about things as a business truth be told.
In light of that, we're offering post seasonal and mid-seasonal (depending on the motorsports of choice, some do last longer) full work ups.
From the smallest of things like smoke testing every nook and cranny like evap, exhaust and intake tracts to compression and leak downs and torsion testing every bushing on the vehicle. This is also available at the discounted rate for the nominal drivers, no need to be a club racer to take advantage of the service.
It's all about getting in, getting out and getting back on the road. Preventative maint. will KEEP it on the road longer and obviously, away from our facility and THAT, will help keep you pocket book happy happy HAPPY!
Even something as simple as an approved fuel system cleaner to help promote injector stability, life span and reduce the chance of failure or an additive system to the engine oil to help promote bearing life, lubricity and longevity of the oiling system itself (NOT Lucas garbage). We've reported a a substatial loss of consuption when doing testing on stock and built motors. From 4G's to EJ's, the system works.
Cory Hock of Monkey Bone Racing/IC Signs and Graphics was a test subject for this. From a consumption rate of nearly a quart every 1500 miles (Locally built stage 1 engine using CP Pistons) down to less than a quart every oil change. Like we said, it's a simple system, it's safe for turbocharged cars and it does promote better MPG's, NVH from built motors is reduced, oil consumption is reduced and you get a sense that the engine feels smoother.
You WILL require new spark plugs post the first oil change with this type of service, you can opt to only perform the oiling service to reduce the costs of the spark plugs but it is recommended that every vehicle should perform something like this every major service interval at about 30K. Some vehicles, depending on the systems and products associated, will require the services to be rendered more than once. Doubling the service every OTHER oil change interval for those vehicles for a total of 3 services will help to improve the functions that we are speaking of.
All APM Synthetic Oil Changes run 60.00 and include an OEM Filter, AMSoil XL Series Engine Oil, New Crush Washer, Visual Inspection and for those opting for the oil program services, an additional 30.00 will be added as well as inspections for consumption values every 500 miles until the next oil change for free (it only takes an inspection of the oil with notations of WHERE the oil is on the dip stick every 500 miles).
-Mark
__________________
[B]APM Tuned[/B]
Email:
[/SIZE][/B][/COLOR]
Old 09-16-2013, 02:39 PM   #4
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Soon to be released products will be showcased on the Update page Right Here
All upcoming products will be posted here, soon to be released track items for the winter builds is coming up.
-Mark
__________________
[B]APM Tuned[/B]
Email:
[/SIZE][/B][/COLOR]
Old 09-20-2013, 03:21 PM   #5
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Gauging some interest for some "off road" guys as well.
Seeing if anyone has any interests in making chassis protection plating, front under carriage and or what not. We developed them on a car to car basis but we're also thinking about the "rally" exhaust systems that we've built to go along with it.
Technically they should be standardized with the down pipes but we know that three or four companies would allow them to work. Obviously working through the FIA Regulations of the exhaust system.
-Mark
__________________
[B]APM Tuned[/B]
Email:
[/SIZE][/B][/COLOR]
Old 09-23-2013, 02:11 PM   #6
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
Blackhawk Farms 10/16/2013
Yes, it's a Wed. Yes you will have 5-6 20min/30min, decently placed areas for the pits (shade available), the food is actually pretty good and of course all the people around you are accepting of whatever you ride.
People want to see the different....even if your an Auto X guy the course is fun enough even for us slow poke Fit guys!
Stop by, we're most likely working with a client that day under pit work but he's in the same class so we might be running our pocket rockets in between.
-Mark
__________________
[B]APM Tuned[/B]
Email:
[/SIZE][/B][/COLOR]
Closed Thread
