Old 08-29-2013, 05:41 PM   #1
subiedoutlegacy
Member#: 357802
1991 Legacy SS
Mica Red
Default 1994 legacy ej22 engine tick!
I recently spent days removing the head gaskets on my 1994 Subaru legacy with 233, 000 miles on it I got the heads boured and resurfaced and put everything back together. I replaced the water pump, timing belt and changed oil now I seem to have a fairly decent engine tick. What could it be? Bad valves? Seals? Please help this is my only car and I've been without it for almost a week now.
subiedoutlegacy is offline   Reply With Quote
Old 08-29-2013, 07:07 PM   #2
mschiavoni
Member#: 299104
2014 WRX
timing might be off slightly
mschiavoni is offline   Reply With Quote
Old 08-30-2013, 11:45 AM   #3
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
The early EJ22Es run hydraulic lash adjusters (HLAs) which is probably the source of your ticking.
What weight/brand of oil are you using?
Jessekrs123 is offline   Reply With Quote
Old 08-30-2013, 04:42 PM   #4
nickb21
Member#: 214412
+1, probably a collapsed HLA. You'll need to pull the valve covers and figure out which one it is an bleed it. I'm sure there is a writeup somewhere, it's not too bad a job.
Might also want to verify the tensioner is good, not sure if it's common on that gen for them to go bad.
nickb21 is offline   Reply With Quote
Old 08-30-2013, 08:19 PM   #5
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Definitely a HLA, especially if they were allowed to drain out while the heads were off. The tensioners on those never fail (old school piston type)
Old 09-04-2013, 12:10 PM   #6
subiedoutlegacy
Member#: 357802
1991 Legacy SS
Mica Red
The problem was the timing belt tensioner allowed the timing belt to jump but I adjusted it and she now runs great thanks for the heads up!
