Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 08-22-2013, 11:05 PM   #7601
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Originally Posted by 340Duster View Post
That's my assumption, but how far to go first experimenting, Idk. The wide band blips lean then goes rich, so I'd assume that's the direction to go.
if you are seeing it actually go lean in tip-in on the wideband then you may need to richen it more. Tip in is pretty hard to see, so if you see it lean, odds are it needs to be a little richer and vice versa.
Old 08-25-2013, 01:50 AM   #7602
KBizzle z the shizzL
Member#: 366373
good read on last page, happens all the time actually, damn cocky internet posters
good response from mw
KBizzle z the shizzL is offline   Reply With Quote
Old 08-29-2013, 02:28 PM   #7603
Greenracer6
Member#: 7962
08 335i TwinTurbo
PSM 02WRX, 97 Dipped CRV
I'm back! For all the guys from yrs ago!
No more rotated 30R, 2000ccIDs, and built motor...:'(
Got to start all over, this time opensource and no LINK ecu. Makes it more fun...
Anyone have a base map for an 02 WRX, modded stock injectors to 740 or a 1000cc set with a 255 walboro for anywhere between 18-22psi
Tbe, uppipe, intake, e85 100% of course
Stock td04 :-(
Anything close really I can tweek out email greenbill88@gmail.com I can check it out in romraider
Greenracer6 is offline   Reply With Quote
Old 08-30-2013, 05:59 PM   #7604
Greenracer6
Member#: 7962
08 335i TwinTurbo
Default ...
wow i didnt mean to kil the thread...
So who makes the most power on here safely with a stock turbo and e85? What setups for the average guy?
modded 440's to 720
walboro 255
tbe
intake
18psi
safe timing at max load and then tapers up how high these days? used to be 10-12 at max load tapering up to 18-19 for big turbos 20G and bigger.
I imagine on these small ones you could do 15-16 ramped up to 22-24 deg as load goes down in high rpms
Old 08-30-2013, 06:07 PM   #7605
Andrewxxcarlson
Member#: 316415
2006 WRX
modded 440's to 720
walboro 255
tbe
intake
18psi
I'd have to log and recheck my timing but
06 wrx
Stock 565cc injectors
Tbe
Cobb intake
Turbo blanket + heatshield
E85 tune by Eric @ TP
VD @ 280/320 on low reading setting.
Old 08-30-2013, 06:35 PM   #7606
Greenracer6
Member#: 7962
08 335i TwinTurbo
06 wrx
Tbe
Cobb intake
I forget at what point the stock rails starve the far cylinder?
Old 08-30-2013, 06:45 PM   #7607
Andrewxxcarlson
Member#: 316415
2006 WRX
I'd like to think mid 400s is when an aftermarket parallel setup would be nice.
Old 08-30-2013, 06:56 PM   #7608
05_wRex
Member#: 170097
2007 WRX STi PTE6266
I have stock rails and don't have a problem. 560/487 at the wheels.
What would the far cylinder be? #1 is at the very end where the regulator is.
05_wRex is offline   Reply With Quote
Old 08-31-2013, 03:08 AM   #7609
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
It's #3 IIRC back where the turbo is.
340Duster is offline   Reply With Quote
Old 08-31-2013, 10:53 AM   #7610
05_wRex
Member#: 170097
Hmm. Gotcha. I need to get individual wide bands on this thing to know for sure I suppose. Lol.
Old 08-31-2013, 11:47 AM   #7611
Maxwell Power
Member#: 190729
No. It's #1.
There is no starving. Our injectors are plumbed reverse of firing order. 4231.
Take whatever you think you knew about fuel systems and toss it out because it doesn't apply.
Old 08-31-2013, 01:17 PM   #7612
05_wRex
Member#: 170097
Did you mean *no starving? Or just like it is?
Thanks.
Old 08-31-2013, 01:46 PM   #7613
Maxwell Power
Member#: 190729
Thanks.
No starving.
Sorry. Hate using my phone for this.
If you reach a point that you successfully starve an injector it's a fuel pump shortcoming.
Old 08-31-2013, 01:47 PM   #7614
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
modded 440's to 720
walboro 255
tbe
intake
18psi
This car has over 45k miles on it and has been making the power it ran 11.4 on for over 1yr already.. Still runs mint and will be back out in a few weeks to push that record a little lower.
http://forums.nasioc.com/forums/show....php?t=2371583
Old 08-31-2013, 02:05 PM   #7615
05_wRex
Member#: 170097
No starving.
I figured. No worries. Just making sure. Haha. I don't have any issues. I'd say you'd really only have to worry about it if you're running on the ragged edge of safety. At that point you can probably afford a new block every season if you need that last couple horsepower.
I run 11.6-11.8 (gasoline afr) on ethanol and 11-11.2 on pump gas.
Old 08-31-2013, 04:24 PM   #7616
Brown Ops
Member#: 291770
2004 Impreza WRX STI
Java & satin black
No. It's #1.
Mind blown. It looks like I have a ton of more reading to do!
Brown Ops is offline   Reply With Quote
Old 09-04-2013, 02:02 PM   #7617
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
everything is a balance. Once you establish proper flow paths, the size and length of the tubes all depends on total power output and system configuration.
Comparing up pipe sizes is about balancing flow to match total output and desired spool characteristics.
Comparing header designs is about proper flow path.
In other words, they aren't the same argument.
Exactly true,
I am running 2" primary headers and a custom 2-1/2" up pipe, along with a FP HTA GT3586 turbo. This setup is also one of Maxwell Powers longblocks and I made 532whp and 433wtrq at 23psi on E85 and a PIA tune. I have a great flow path for the setup I have chose including a 3 to 3-1/2" exhuast. Just another example as stated everything has to be designed to YOUR needs and not the one only way. A smaller faster spooling turbo would equal a smaller primary and up-pipe combo to be efficiant in the boost response range vs big turbo, big power cars need flow.
Sinister redlines is offline   Reply With Quote
Old 09-13-2013, 04:08 PM   #7618
jack klompus
Member#: 152885
2014 Malibu LTZ
Have any of you developed any fuel leaks at the injector area? I had a injector leaking, pulled it and found the bottom grommet seal to be much smaller than the new replacement, like the E is eating away at it. The leak was coming from the O-ring where the injector plugs into the rail, didn't see any damage or corrosion.
I went ahead and ordered a couple injector seal replacement kits, I will probably make this part of my annual maintenance.
Anyone else see anything like this?
jack klompus is offline   Reply With Quote
Old 09-13-2013, 04:25 PM   #7619
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
What injector?
Layvon is online now   Reply With Quote
Old 09-13-2013, 06:54 PM   #7620
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
2 years+ on e. Never happened.
gaby is offline   Reply With Quote
Old 09-13-2013, 07:27 PM   #7621
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
There probably are some o-rings and seals that are not compatible with ethanol.
I know I added an additional o-ring= 2@ o-rings to the top of the ID1k's (Bosch EV14's) I had and they fit perfectly and did not leak. My new ID1300's have an aluminum top hat adapter that fits over the injector body to accommodate different injector lengths and rail bores. I think this adapter fits the rails better and only requires 1@ o-ring.
Old 09-14-2013, 11:10 AM   #7622
jack klompus
Member#: 152885
2014 Malibu LTZ
Originally Posted by Layvon View Post
What injector?
The pixie dust injector.
Old 09-14-2013, 11:28 AM   #7623
05_wRex
Member#: 170097
So IDs?
Old 09-14-2013, 08:57 PM   #7624
jack klompus
Member#: 152885
2014 Malibu LTZ
So IDs?
DW 1000
Old 09-14-2013, 08:58 PM   #7625
jack klompus
Member#: 152885
2014 Malibu LTZ
Thats what I am thinking. Not a big deal to switch them out with new seals
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
