Old 12-06-2012, 02:41 PM   #76
SW00P_G
Member#: 5591
EJ257 Gt35r
You can see even in this lower power testing that the manifold was just starting to work. It just needed to be revved higher.
SW00P_G is offline   Reply With Quote
Old 12-06-2012, 03:39 PM   #77
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
I have an cosworth manifold here. If someone can get me an adapter plate for a drive by cable throttle body, I can throw it on and get some comparison data
xdrian is offline   Reply With Quote
Old 12-06-2012, 06:44 PM   #78
SW00P_G
Member#: 5591
EJ257 Gt35r
^ ROFL, geez if anyone could REALLY use one!
Try talking to THIS guy. He's got something rigged up on his.
Old 12-06-2012, 11:38 PM   #79
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Originally Posted by Clark Turner View Post
Yeah. 600+. At 700whp with good heads and cams, power can be made out to 8500 on the 2.5 with the manifold. At that rpm, the gains are huge.
I believe it Clark. Personally I think on a 700 whp car the gains would be closer to 70 whp or more past say 6500 rpm but didn't wanna post that! Sounds crazy but these things flow well up top.
Old 12-07-2012, 02:49 AM   #80
banny sti
Member#: 118815
This is mine
banny sti is offline   Reply With Quote
Old 12-07-2012, 09:59 AM   #81
xdrian
Member#: 104200
828 WHP BUGEYE
Originally Posted by banny sti View Post
This is mine
where did you get that done? how much etc..
Old 12-07-2012, 10:53 AM   #82
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Does the hood close with the IAC? I know this way you'll have to do the ac delete. Thanks
Old 12-07-2012, 02:24 PM   #83
banny sti
Member#: 118815
Im in the UK and my tuner did during the engine install, bonnet closes perfectly not catching at all
Old 08-31-2013, 02:24 PM   #84
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
bump
any further testing?
user1029 is offline   Reply With Quote
Old 08-31-2013, 02:32 PM   #85
Clark Turner
Member#: 178047
02 WRX STI Spec C
I have tested dozens of them now. Not recommend for street cars under 7000 rpm or 500hp. The loss in midrange power can be huge. Back to back testing on a GT35R was almost a full 1000 rpm later trq peak. Under 5000 rpm cars loose huge power and trq. Gains are 6500 and up for drag or high rpm setups. Road racing or drag racing? The manifold will help. Street? Forget it.
Clark Turner is offline   Reply With Quote
Old 08-31-2013, 03:20 PM   #86
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Very interesting!
Old 08-31-2013, 04:38 PM   #87
user1029
Member#: 57064
2008 STi IAG built
Great insight indeed
Although I have 35R, PnP heads, Kelford 272s, +1mm bigger valves, I will stick with the stock IM since 99.9% of my driving is on the street
Old 03-28-2014, 06:21 PM   #88
user1029
Member#: 57064
2008 STi IAG built
Not the exact ideal comparison due to differences in boost that was negated by differences in temperature but you get the idea :tup:
Driving impressions after Cosworth IM:
1. Turbo spool sounds 25% louder
2. Drives like stock at part throttle just like before.
3. Yes, the lag is definitely noticeable at WOT tip-in but it is not a deal breaker at all. The fact that I went with an HTA86 turbo, big heads/valves/cams already means that I am too far gone at trying to hold on to any low end. Might as well make the most of the top end!
4. The top end, oh yes the top end Basically I picked up 23-26whp/11wtq at every single rpm after 4500rpms according to the dyno graph. The top end is just downright BRUTAL now :tup:
5. Would I recommend the Cosworth IM? I would ONLY advise it to people with turbos at >70lb/min + headwork + running >30psi AND who operate at high rpms for lengthy periods (road racing or drag).
__________________________________________________ ________________
This is the interesting graph on straight 93 octane, boost is the same but varied greatly on ambient temperatures.
Impressions:
1. Even at 25psi, the Cosworth IM is still not able to "wake up". There are huge losses of power down low and shifting of the curve to the right.
2. I wouldn't say I lost power with the Cosworth IM because you have to account for the temperatures differences in the tunes but certainly the benefits of the Cosworth IM on low boost are marginal at best.
3. The OEM STi manifold is fantastic and I would recommend keeping it if you are not building a drag/road racer.
My mods for reference:
IAG V-band rotated turbo kit
- HTA86 0.82 Tial V band housing
- IAG FMIC kit with Spearco core and bumper beam
- IAG 4" Intake
- IAG V-band Uppipe
- IAG V-band Catless Downpipe
- Tial 44mm External Wastegate with open dump
- GT Spec Equal Length Headers V-band with Uppipe
- Harman Motive Catback Exhaust
- Aquamist HFS-6 running Boost Juice (50% methanol/50% water)
- Injector Dynamics 2000cc injectors
- Aeromotive 340lph Fuel Pump
- Aeromotive Fuel Pressure Regulator
- IAG Fuel Rails
- Grimmspeed Electronic Boost Control Solenoid
- Grimmspeed Thermostat
- Mishimoto Radiator
- Tial Q BOV
- LFR7AIX Spark Plugs
- IAG Catchcan
- Stock Air Pump deleted
- IAT sensor and 4 Bar MAP sensor
- Cobb Accessport Speed Density protuned by Jorge
IAG Stage 2 Bottom End (25,000 DD miles and counting... Built by Artie at IAG)
- Manley Platinum Series 99.5mm Piston Set
- Manley H-Beam Rods
- ACL Main and Rod Bearings
- OEM Nitrided Crank
- OEM 11mm Oil Pump
- Killer B Oil Pickup with Baffle
- Gates Racing Timing Belt Kit
- 12,000mile/1year warranty
IAG Stage V Heads (25,000 DD miles and counting... Built by Artie at IAG)
- Flipped Cosworth Manifold with retained Air Conditioning
- ARP2000 Head Studs
- OEM Headgasket
- Manley Extreme Duty 33mm Exhaust Valve Set
- Manley Race Flow 37mm Intake Valve Set
- Manley Valve Spring and Retainer Kit
- IAG Stage V headwork with Multi Angle Valve Job/Port&Polish
- Kelford Dual AVCS 272/268 11.30/11.50mm Lift Street Cams
- Cosworth Phenolic Spacers
- IAG TGV Deletes
Old 03-28-2014, 08:41 PM   #89
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Great that you updated the thread with your results. Also good to have this truly great thread bumped that contains comments from some of the best ever Subie tuners in this country.
Built motor, 35R, stock manifold vs. Cosworth Manifold AdamBOMB_STi Proven Power Bragging 30 01-26-2014 08:12 PM
F/S Cosworth Cylinder Heads NEW DEAL Free Cosworth Manifold Fastyellow Engine/Power/Exhaust 20 04-18-2010 11:37 AM
Finally Finished: TSR-70 Kit, Cosworth Manifold, Build Motor + MORE Mac323 Member's Car Gallery 35 03-12-2010 09:23 PM
Reversed Cosworth manifold and converted to DBC? dubya-R-ex Built Motor Discussion 7 12-14-2009 05:06 PM
2.5i or Cosworth manifold??? OB2 Built Motor Discussion 22 02-04-2009 11:18 AM
