North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 08-17-2013, 02:19 AM   #26
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
See you bright and squirrely! Welder and powder coater are warmed up and ready to rock.
You must have got your base map? I love seeing the compressor blade spinning while it runs
morrocco88 is offline   Reply With Quote
Old 08-17-2013, 07:41 PM   #27
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
IAT sensor new location
DerekB707 is offline   Reply With Quote
Old 08-17-2013, 07:42 PM   #28
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Have to cut the wires on the MAF sensor to relocate to the IAT sensor
Old 08-17-2013, 08:33 PM   #29
Justin V
Member#: 98747
07 WRX
So you are running Speed Density and a MAFS? I've seen it done just wondering why you'd keep the mafs. Also recirculating the BOV to one of the intake tube ports?
I also see 2 boost controllers, you going to stick with the EBCS or run the hybrid method?
morrocco88 told me to watch your thread I can't wait to get my kit from him.
Justin V is online now   Reply With Quote
Old 08-17-2013, 09:08 PM   #30
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
My tuner wanted to run off the maf for closed loop, if it saturates the sensors capabilities, we will switch to speed density for open loop.
He wanted the air ricirc'd into the inlet off the oem bov, I asked Garris to weld in the purge valve and boost controller reference. The idea is to keep the car as streetable friendly as possible when just driving it like normal Daily driving. The dual boost controllers will be for a hybrid ecbs / mbc boost setup.
You're buying a great kit, you won't be disapointed.
Thanks,
Derek
Old 08-17-2013, 09:37 PM   #31
Justin V
Member#: 98747
07 WRX
Topspeed warned me about speed density saying the idle quality would be garbage, but I just finished a friend's build that's being phat botti etuned and it runs and idles amazing for it to be cammed and SD.
I'll probably go speed density this time to clean up under the hood. Looks great and can't wait to see the numbers.
Old 08-17-2013, 10:19 PM   #32
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
I was in Garris's car today that was on SD only, it idled pretty good. I was actually surprised. Pm me your results when its all said and done, would like to know how your car turns out.
Old 08-18-2013, 01:55 AM   #33
brokenfingerdesigns
Member#: 180914
2004 wrx
555 motorsports tuned wrb
I love this. now get busy I want a ride when shes done.
brokenfingerdesigns is offline   Reply With Quote
Old 08-18-2013, 11:56 AM   #34
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Calling on tuesday to schedule my tune.
Old 08-18-2013, 01:01 PM   #35
7R4V15
Member#: 321310
2004 STI
Thumbs up
Nice write up on the build.
The attention to detail that went into making that intake is just awesome.
7R4V15 is offline   Reply With Quote
Old 08-18-2013, 03:49 PM   #36
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Today I wanted to finish off the intake hose routing. For the recirc valve, I flipped the oem hose around onto the intake and then added a coupler. I went to my local auto parts store and asked if I could look at their radiator hoses till I found the perfect hose, lol.
Just about done, going to do a boost leak test later today and hope to schedule my tune on Tuesday.
Old 08-20-2013, 08:05 AM   #37
CWells90
Member#: 303552
07 STi OBP
SUBYDOO
Now I'm following your thread!
Do you have a set date for tuning or you're scheduling that today? Can't wait to compare our spool characteristics since I'm reverse manifold but nearly identical setup.
CWells90 is offline   Reply With Quote
Old 08-20-2013, 02:47 PM   #38
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Tuning on 9/4/13, will post my results as soon as I have them.
Old 08-21-2013, 12:00 AM   #39
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Leak testing
You can see the cobb bpv leaking, new gasket on order.
Getting ready to cut the front to clear the intercooler.
Fog light covers on order, ready for tuning.
Old 08-25-2013, 11:48 PM   #40
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Ordered a FUELPro fuel pump controller from DCCDpro.com, had a good experience with my old wrx when I swapped in a 6MT using their DCCD controller that I thought I would give their fuel pump controller a try in hopes of not having to hard wire my fuel pump.
http://dccdpro.com/zcart/index.php?m...&products_id=6
FUELPro controller wiring.
oem fuel pump controller
Have to remove the + and - Voltage supply pins to upgrade the wire diameter to something at least 16 gauge. I am going to 14 gauge wire for the added circuit current.
Used OEM wires to turn on the relay, then pass 12V through it to the new fuel pump controller.
The new fuel pump controller will be here later this week. Will update the thread once its all wired up and installed.
Old 08-28-2013, 10:52 PM   #41
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Relocating fuel filter from the tank to under the hood like the 02-03 wrx's.
Going to pick up a bracket tomorrow for this to put it in the oem location.
Fog light covers showed up today, still debating on if the STi logo stays or not, but glad they are here.
Old 08-29-2013, 11:28 AM   #42
CaptinCurt
Member#: 238017
2006 2.5I STI
1999 2.5RS
Have you swapped the fuel tank? My 2.5i still has stock one and I have problems keeping the fuel in the fuel pump tray. I was told I need to put a STI fuel tank in.
CaptinCurt is offline   Reply With Quote
Old 08-29-2013, 08:03 PM   #43
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Still has the impreza fuel tank, my tank has a quirk that I just deal with. The low level sensor does not work and the needle operates showing full at 7/8th and empty at 1/8th. I will probably address this at some point, for now I just keep plenty of fuel in it.
Old 08-29-2013, 08:55 PM   #44
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Got a hookup from my buddy from an old bugeye with this oem fuel filter bracket.
Just need the fuelpro controller to show up tomorrow and I should be ready for tuning next Wednesday.
Old 08-30-2013, 08:23 PM   #45
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
FuelPro showed up today!
Added a geeky pc fan to remove heat built up in the controller.
Everything tucked away.
It runs!
Old 08-31-2013, 12:37 AM   #46
brokenfingerdesigns
Member#: 180914
2004 wrx
Loom Please derek
Old 08-31-2013, 11:17 AM   #47
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Doesn't need it, its behind the panel, none of this is visible.
Old 08-31-2013, 11:15 PM   #48
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Lookin good Derek! Can't wait to see your results after the tune! You should try to stop by on your way home and take me for a ride.
Why did you take the pics down of Guido the shop dog?
Old 08-31-2013, 11:26 PM   #49
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Back by popular demand, I give you Guido!
If its a decent hour by the time I get out of there, I will hit you up, you are right on the way home. Really hoping for a good result, pretty much down to my last boost leak that I am fixing right now, everything else looks solid.
Old 09-01-2013, 07:10 PM   #50
wrxBRAH
Member#: 256841
2004 FXT
Subaru porn at its finest. Extremely clean build.
wrxBRAH is offline   Reply With Quote
