Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 02-03-2013, 02:52 PM   #26
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Model numbers and differences:
CZ624U1 (printed on front)
Clarion PF-3292A-A, Subaru 86201FG620, rear sticker ZR62
  • Used in 2011 Impreza/WRX/STI/OBS; 2012-2013 WRX/STI
  • 20-pin radio harness has CAN bus (pins 11 and 12), used for speed-sensitive volume and night illumination dimness cancellation ('NIDC')
  • Has single button for FM/AM, with SAT button below that
  • Compatible with OEM satellite radio tuner accessories
CP625U1 (printed on front)
Clarion PF-3297B-A, Subaru 86201SC620, rear sticker PR62
  • Used in 2011-2013 Forester
CM621UB (printed on front)
Clarion PF-3386A-A, Subaru 86201FJ620, rear sticker MR62
  • Used in 2012-up Impreza & Crosstrek
  • 20-pin radio harness no longer has CAN bus
  • Pin 11 is for "bright" mode ('NIDC')
  • Pin 19 is for Vehicle Speed Signal (VSS) -- used for speed-sensitive volume, and to lock out some functions while you're moving (such as being able to adjust bass, treble, etc.).
  • Has separate buttons for FM and AM, no SAT button
  • Not compatible with OEM satellite radio tuner accessory
All 3 head units:
  • Use same 20-pin connector and pin-out for power, speakers, illumination, steering wheel controls (SWCs), power antenna control
  • Have the same additional rear sockets/connections:
    • 16-pin socket for Bluetooth mic and aux input
    • 4-pin Hirose socket for USB input
    • Pigtail lead for "tel mute" input (for external Bluetooth cell phone kit)
    • Motorola socket for AM/FM antenna
    • Ground lug for redundant ground harness
All three are "Type B" in the cars' owners manuals (Type A is the base HU model without BT, and Type C has the 4.3" screen, discussed here).
"NIDC" allows you to have your headlights on, but restore your instruments and HU to daytime brightness (the way they would be if your headlights were off). See your car's owners manual where it talks about the dash light dimmer wheel ("Illumination Brightness Control").
The same service manual covers both the WRX and Forester models CZ624U1 and CP625U1. I don't see any significant differences there.
SVXdc is offline   Reply With Quote
Old 02-16-2013, 09:19 PM   #27
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
CP635u1 installed
Old 04-07-2013, 12:22 AM   #28
basara808
Member#: 262588
2012 Impreza 5Dr CVT
Default Glove box
What is the trick to get remove the glove box in a 2012 with out removing all of the screws? After I disconnect the lever on the right side I can't seem to pop it out.
basara808 is offline   Reply With Quote
Old 04-07-2013, 08:35 AM   #29
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
You have to squeeze/flex the sides of the glove box in enough to allow the plastic stops molded into the side of the box to clear the opening. You have to squeeze pretty hard to accomplish this. Once it clears, the box drops much further open than normal, at which point you can just pull it out.
Make sure you empty the glove box, or you'll dump its contents on your feet during this process.
This is a good process to learn, as it's required to replace your cabin air filter too.
Old 04-07-2013, 10:43 AM   #30
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Words of wisdom right there sir!
MackDaddy is offline   Reply With Quote
Old 04-09-2013, 03:51 AM   #31
basara808
Member#: 262588
Thanks. This is why I want to get it out. 2004 needed to unscrew. Thanks again.
Old 06-23-2013, 09:31 PM   #32
protivakid
Member#: 265148
2001 Legacy
This guide is great for getting the HVAC bezel off. Didn't even need any tools, just used my fingers / nails and didn't have to use as much force as others were saying except for the very bottom.
protivakid is offline   Reply With Quote
Old 09-02-2013, 11:55 AM   #33
Stapleface
Member#: 354242
2013 Crosstrek XV
Tangerine Orange Pearl
Flyboy, how did you go about running the antenna to the roof? I'm attempting to do this install today and I can't seem to figure this step out. There hardly seems like there's even any room to run the wiring behind that bar and the hvac ductwork.
Stapleface is offline   Reply With Quote
Old 09-02-2013, 12:40 PM   #34
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I followed the wires out towards the drivers side, then ran it up the door seal until the top of the a pillar, then just inside the headliner to where my antenna is stuck to the inside of my windshield just above the mirror
('11-'14) Why does Canada get nicer features than US for the 2012 2.0i? monkeyracer Impreza Forum 33 08-27-2012 10:49 AM
2012 2.0i Audio Build tangredsocks Car Audio, Video & Security 16 07-30-2012 12:34 PM
2012 Trim Levels: 2.0i vs. 2.0i Sport chicagocpo Brakes, Steering & Suspension 0 05-18-2012 02:22 AM
('11-'14) 2012 2.0i - engine ping? brockd Impreza Forum 12 05-01-2012 09:35 PM
