Old 09-02-2013, 03:27 PM   #1
Schlanseay
Member#: 340978
2013 13 WRX Hatch
Default Will my radio work?
Will my 13 wrx head unit non navi work in an 09 forester non navi?
Schlanseay is offline   Reply With Quote
Old 09-26-2013, 03:02 AM   #2
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The main features (radio, CD), as well as illumination/dimming will work. For those functions, the 20-pin power/speaker harness is plug-and-play.
The older car's SWC buttons (if it has them) won't work. Cars with the phone/BT buttons use completely different resistors and have 8 buttons instead of 6 on the older cars. See this post.
The older car's aux harness (again, if present) has an 8-pin plug, as opposed to the 2013 HU using a 16-pin socket (for aux and BT microphone). I can build an adapter harness so the Forester's aux jack works. Adding a BT mic is a bit trickier, but can be done.
The older car doesn't have a USB socket. To add that currently would require a very expensive OEM USB harness, plus the newer-style pod in the center console that has both a USB socket and 3.5mm aux jack. Not worth the expense, IMO.
SVXdc is offline   Reply With Quote
