Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 09-02-2013, 03:42 PM   #1
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Default No spark on 3 & 4, my rear two cylinders are not getting spark
Anyone have an idea why rear two coils on plugs won't get spark, wiring seems fine, timing belt lines up, coil packs are fine...
93GC8Dub is offline   Reply With Quote
Old 09-02-2013, 11:25 PM   #2
dome24
Member#: 111845
97 RUBAsU Tall2dr
96 Neota Tacoma 4x4
I was chasing this for 6 months on my Imprezas, mine turned out to be the timing belt was misalligned. I replaced the cam and crank sensors, ignitor, plugs, coil all just to find out i messed myself up with the belt...
dome24 is offline   Reply With Quote
Old 09-05-2013, 12:37 AM   #3
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
I just did twin to single legacy swap and I have cam gear off, same reference points, just getting frustrated, I guess I'll try to realign, and reassemble, but could it be any other reason, this is the third time I've had to align
Old 09-05-2013, 12:38 AM   #4
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
How did you mess up?
Old 09-05-2013, 01:15 AM   #5
dome24
Member#: 111845
97 RUBAsU Tall2dr
96 Neota Tacoma 4x4
I aligned to the wrong mark on the crank gear instead of the tone ring.
The keyway in the crank should be straight down and the cam pulleys have to match the same ones thatbcame off the car originally. The tone rings.on.the back of the pulleys is different sometimes.
Old 09-06-2013, 10:08 AM   #6
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Ya i have the belt good, i have continuity to the plug too, is there any reason why the ECU might not run my 02WRX converted coilpack with no ignitor box(built into coil)? but only on the rear cylinders?? banging my head against that wall
Old 09-07-2013, 11:12 PM   #7
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
It's not the timing belt, it's lined up, the issue is that we have weak signal to the rear plugs
Everything else checks out. Just not enough volts, 1-2 goes to 6 volts and the rears only 0.4 volts, I'm using 02+ coilpacks but the front two are working, I don't understand(and yes all coils work and have been tested)
Old 09-23-2013, 05:33 PM   #8
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Bumpy Bump
Old 09-23-2013, 06:27 PM   #9
DentMagnet
Member#: 352689
2004 Impreza
dark green but looks blak
For some reason I can't pull up an ignition diagram for your car but my default answer for 0.4v is that the transistor that drives these is clobbered.
And 6v is what you'd see with a 0 to 12v square wave with a 50% duty cycle (dwell angle, sort of).
DentMagnet is offline   Reply With Quote
Old 02-18-2014, 03:45 PM   #10
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
What ive narrowed it down to...
The ECU i put in is a V4 ecu...the ignition system is the 02+ coilpack swap(ignitor removed, Car ran on the swap before i swapped ecus) for a V2 ecu.
meaning i have got from 4 signal wires to 2 signal wires. I have bridged them from the ecu to have 4 signals but only two of the cylinders fire.(front two), and i have tried switching them and bridging two of the opposing coils together... could really use a wiring schematic of both the V4 and V2 set up. or an alternative ignition system that would work for me
Old 04-09-2014, 10:34 AM   #11
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
And we still have the issue, tried replacing the igintion system to match the ECU, didnt work, still only had 1 of the 2 ignition signals.
What would cause the ECU to only shoot of one of the ignition signals?
Does the tensioner matter between styles? my understanding is if it lines up, timing is correct...
common scoobi fans, its almost summer and i want this beast running
Old 04-09-2014, 01:44 PM   #12
dome24
Member#: 111845
97 RUBAsU Tall2dr
96 Neota Tacoma 4x4
whoops just realized I posted twice with the same answer 6 months apart.
D'oh
Old 04-10-2014, 01:14 PM   #13
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
ya timing is on and lined up. with correct sprocket marker
Old 04-11-2014, 09:20 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Since this question isn't Legacy specific, I would suggest you post in more appropriate forums where you'll get more exposure - either the Subaru Conversions forum or Engine Management & Tuning. You're asking a very limited audience here in the Legacy forum.
Old 04-15-2014, 12:08 PM   #15
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
ended up being that the crank and cam signal wires at the ecu were not merged making them not speak to eachother limiting the singal from ecu. Thanks for help guys, Car is running and sounds BEAST
