Old 08-25-2013, 09:34 PM   #51
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
loving the results. could you post a log up? also curious what afr you're aiming for at wot.
bluemax189 is offline   Reply With Quote
Old 08-25-2013, 09:52 PM   #52
Drewswrx
Member#: 352498
2008 Wrx 2.5L
My afr is 11.1, when I what the wideband at wot goes all the way to 10.8 and by 4000rpm hits 11.1 I have tried putting my logs up but it won't let me. The Cobb ap maxes out at 11.1 and won't show the 10.8 and them moving up. The hardest part of my tune was getting the primary ignition and dynamic advance right where I wanted it for power torque and no knock. That took a long time. I found that more timing does not always mean more power but I finally got where I wanted to be and where I felt safe. I also tuned my avcs map and that was hard also. I still don't 100% understand the system except I know that tuning hand in hand with ignition timing helps with my fuel economy. Everyone said the intake would take the longest but that wasn't to bad.
Drewswrx is offline   Reply With Quote
Old 08-26-2013, 08:31 AM   #53
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
awesome. ive done some basic tuning but obviously you've done a lot more in depth(im still waiting on afr gauge and pod). you can upload the log in google drive and then just post the link to it. your setup is about exactly what im hoping for so im sure ill be picking your brain a bit on the tuning side of it.
Old 08-26-2013, 08:42 AM   #54
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Anytime man just pm me and ill give you my email so I can answer quicker and ill give you my log that way too and ill try the google thing. Do you need a google account for that?
Old 08-26-2013, 09:30 AM   #55
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
yeah, theyre free of course.
Old 08-26-2013, 06:13 PM   #56
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Im not hating I am just amazed at a lot of these threads I only put down 330whp when I had my vf52 on e85 at 24psi. But I don't agree that anything is possible you can only run a small turbo so far before it blows hot air but these vf52 seem to put down power like a 18g.
nate_fisher is offline   Reply With Quote
Old 08-26-2013, 06:45 PM   #57
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Yeah I find with the vf52 I get more power at 20-21psi then I would if I went any higher than that. Because your maxing the turbo out above 23-24&25psi. That's why I won't let it boost higher than 21. My boost peaks at like 20.8 then tapers to 19 and holds. I like this turbo for now but I want to get the Perrin rotated setup to just all out drive faster than I ever have. I know that when I go rotated I will have to upgrade the MAP sensor as well so I don't max out.
Old 08-26-2013, 08:05 PM   #58
Airboy
Member#: 72829
2006 WRX
2015 WRX
Different dyno spits out different numbers for the same car.
Airboy is offline   Reply With Quote
Old 09-03-2013, 02:17 PM   #59
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Hello everyone it has been a while since I posted here. I have been saving some money to start installing an EWG system in my car. Looking forward to seeing any benefits, if any, that happen. When all is done and retuned I will post up new results, thank you for any supporters that I may have out there. Hopfully it will not be long before I am on the track competing.
Old 09-03-2013, 07:45 PM   #60
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
damn, youre doing everything I wanted to do lol.
Old 09-03-2013, 07:57 PM   #61
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Is it me or does that hp curve seem kinda peaky?
Also, don't switch Dynos. If you are satisfied with your results then keep using the same stretch of road and the same software. If you don't you're going to lose all functionality of the dyno (tuning and comparison)... and you also won't be disappointed if you were to see your "real" dyno numbers. Which are almost always lower than hoped for... like 99.9% of the time.
ProfessWRX is offline   Reply With Quote
Old 09-03-2013, 08:19 PM   #62
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Yeah I actually was playing with the timing a little so now I went back to where I was and it keeps hitting consistently. It's not all over so that makes me feel a lot better. A few other tuners I talked to said my numbers are t to far off cause the fmic gives these cars good power. I feel it too its amazing how fat my car just up and goes. I love driving this thing it's like no one can keep up, lol.
Old 09-03-2013, 08:36 PM   #63
SkateAndDestroy
Member#: 133893
JBP 04 Forester XT
PSM 02 WRX Wagon
Anyway you could post a data log? (or host it off Google, email it to me etc)
SkateAndDestroy is offline   Reply With Quote
Old 09-03-2013, 09:01 PM   #64
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
just downloaded and looked at the TTDyno software, not a fan. Uses just Time, RPM and Speed to calculate HP. Then it has you guess the drag coefficient and drivetrain loss and some other parameters. I use Virtual Dyno. Although no virtual dyno program is perfect, at least having the built in profiles for all the different cars makes comparing your car to others a little more on-par.
DrewsWRX do you have the settings you used so I can try and compare my car?
Old 09-04-2013, 06:29 AM   #65
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Yes I do, I'm at work now when I get home I will post all my numbers and post my data log if I didn't get rid of it. Also if I can't find that then after my retune I will make sure I post everything. I didn't realize I would need to keep my datalogs. I always reset them cause Tt will not read from cobb ap only the logs from ATR. So after I put logs into software I save my dyno info and delete logs. Ill try to retrieve them from my hard drive and email anyone who wants them and when I retune for ewg I will make sure I keep all logs and email anyone else who wants them. I get out around 3pm est
Old 09-04-2013, 08:32 AM   #66
Drewswrx
Member#: 352498
2008 Wrx 2.5L
I just want everyone to know that I didnt just copy specs off of VD or just some website. I did my research to be as accurate as possible. I want my numbers to be real not just big. even if it only spit out a 310 I would be proud cause I did all of it myself. I take a lot of pride in what I do and I like my work to be done right. And the main reason I dont keep logs is after so many pulls you lose track of which ones are which. Anyway, like I said when I get home today I will see if I can locate the log if not you all will get the log of my retune and for the ones who want the data I used I will post that tonight as well. Thank you to all who are taking interest in my thread I really appreciate it.
Old 09-08-2013, 03:32 PM   #67
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Here is the pic of my dyno software still figuring out how to post the data log. Currently have purchased 38mm ewg 38mm ewg uppipe Grimmspeed iwg bracket grimmspeed tgv to engine spacers also got an sti wing that I will be installing. All parts will be installed and car retuned by end of the month and I will post new results for those of you who are following. Thanks to all and to anyone that can help me post my data log please do. Thanks in advance.
Old 09-09-2013, 11:54 AM   #68
Drewswrx
Member#: 352498
2008 Wrx 2.5L
I know I just added tis to my original post, but for those of you who are following and not reading the original again. I just wanted to tell the guys that are going to start modding their cars. If you use http://www.gotboostinc.com/. This is where I got my parts from. The guy Dave here is a great guy and his customer service is A+. You email him a question he is back to you in min. He will beat anyone else's price, find something cheaper than his, let him know he will beat it. Visit the site look around contact him and told him Drew sent you, he will take care of you. His shipping costs are low spend a certain amount and get free shipping. Returns are no hassle the site is easy set up and Dave and his staff are there to help. I'm looking forward to finishing up and posting my new numbers hope I still have some followers out there.
Old 09-23-2013, 09:19 PM   #69
Drewswrx
Member#: 352498
2008 Wrx 2.5L
This weekend the 28th and 29th I will be upgrading my uppipe and wastegate to an ewg. I will also be adding GS's 8mm spacers to tgv and deleting my tgv's. Then I am adding my new GS AOS and retuning my car. I can't wait to see if my numbers go up down or stay the same.
Old 09-23-2013, 09:40 PM   #70
BURNING4ORCE
Member#: 356215
Awesome setup by the way as well as on the numbers. I'm also contemplating on going ext on my bigger turbo setup but I'll probably tune it on internal first to see if I experience any issue with creep before upgrading since ext setups are $. So I will keep an eye on your thread to see what kind of gains you get with the new upgrades. For tgv detetes I tuned my friends sti with basic stage 2 and it needed a bit of enrichment during early start ups.
BURNING4ORCE is offline   Reply With Quote
Old 09-24-2013, 09:06 PM   #71
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
excited to see the results!
Old 09-24-2013, 10:43 PM   #72
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Me too, I'm hoping I get some good and noticeable changes. I would like to thank all the people following my build. Anyone following me who is also building there own car, please give me the link.
Old 09-29-2013, 12:31 AM   #73
blurple203
Member#: 360576
2013 Base WRX
Plasma Blue Pearl
damn, i gotta hand it to you. you don't see many people doing all the modifications to their car AND tuning very often.
do you have an engine build in progress? and hows the clutch holding up to all that torque?
blurple203 is offline   Reply With Quote
Old 09-29-2013, 10:33 AM   #74
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Engine build is planed for the future and the clutch is holding good for now. I haven't really been beating on it. I'm actually in the middle of an up grade this weekend. Ewg, removing air pump and a Grimmspeed AOS. Then a little retune. I am also in the middle of talking with a local vendor for sponsorship. They made me an offer and I sent my proposal in just waiting to hear back so wish me luck. Thank you for your compliments I'll make sure I keep this updated because I'll be racing time attack soon and I will also be going to a lot of shows.
Old 09-29-2013, 11:49 PM   #75
Drewswrx
Member#: 352498
2008 Wrx 2.5L
Here are pics of this weekends project. I will be doing a retune after work tomorrow. Two days it took. Took everything apart Saturday only cause I worked Saturday otherwise I would of done a lot more Saturday. Sunday worked till 9:30pm I am so sore holy crap. Work tomorrow is going to suck lol.
