Old 09-03-2013, 08:44 AM   #676
dsn112
Member#: 332561
2016 WRX LTD
Originally Posted by sleeperlodo View Post
That doesn't even have sat and I bet the reserve is pretty high. Too many people know these aren't easy to get. Crazy paying a penny over $250 for a us unit
Old 09-03-2013, 04:24 PM   #677
Freud
Member#: 340065
2013 WRX
Just recieved and installed my Euro version that I got from Aliexpress. Paid $118 and the took about two weeks to get here. Install is easy and it looks fantastic! My only gripe is that AM radio only kinda works. The tuning resolution/discrimination is 9 Khz unlike 10 Khz in the US. For example if you dial in 630, then the next frequency up in 639, 648, 657, ect. instead of 630, 640, 650...Maybe someone knows a way to change this.
I'm older and do spend some time listening to AM so I would like this to work, but overall I'm happy with it and definitely worth the money.
Freud is offline   Reply With Quote
Old 09-03-2013, 11:48 PM   #678
GotWRX?
Member#: 254167
2011 WRX Sedan
SSM
So if it wasnt for the screen, would this be worth it for sound quality improvement alone for the aliexpress version?
GotWRX? is offline   Reply With Quote
Old 09-04-2013, 08:17 AM   #679
dsn112
Member#: 332561
2016 WRX LTD
No way.
Old 09-04-2013, 11:40 PM   #680
thescreensavers
Member#: 333820
2013 WRX Limited
Just for Comparison Sake, very dim area mostly working on reverse lighting only.
10 G37 Coupe
Rydeen Duo
thescreensavers is offline   Reply With Quote
Old 09-12-2013, 11:46 PM   #681
boober
Member#: 35284
08 tribeca
fyi, i'll be selling my non-nav 4" monitor radio pulled out from my 2013 crosstrek premium.
PM whoever is interested.
boober is offline   Reply With Quote
Old 09-14-2013, 06:15 PM   #682
62tele
Member#: 368282
2014 WRX STi 5-Door
Pearl White
Sent you a PM
62tele is offline   Reply With Quote
Old 09-14-2013, 06:34 PM   #683
Chrisf4i
Member#: 330313
2012 WRX sold
Originally Posted by 62tele View Post
Sent you a PM
I did too, as soon as he posted, but haven't heard anything.
Chrisf4i is offline   Reply With Quote
Old 09-16-2013, 11:15 AM   #684
rwfloberg
Member#: 327538
2012 WRX (307/344)
Originally Posted by dsn112 View Post
No way.
Why not? No improvement on sound quality? This runs contrary to a lot of the posts in this thread?
rwfloberg is offline   Reply With Quote
Old 09-17-2013, 11:06 PM   #685
sleeperlodo
Member#: 362048
2010 Forester XT
Does any 09-10 Forester's owner try this aliexpress HU ?
http://www.aliexpress.com/item/SUBAR..._3193523&vd=30
Just want to know will work on factory steering wheel control (SWC)?
sleeperlodo is offline   Reply With Quote
Old 09-21-2013, 08:19 PM   #686
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Installed it in something a little different. Since I went full nav swap [AVIC-X9310BT] in the 2011 STI Hatch I put this one in the 1998 GC Coupe.
Not plug and play BTW, completely different harnesses. The previous owner hacked a junk unit in the coupe so I opted to cut the old plug out and solder the newer harness in. Now the coupe is swappable to any GR head unit.
Old 09-22-2013, 03:03 AM   #687
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
[CP435L1 Subaru 86201SC430 Clarion PF-3304B-A on AliExpress.com]
Short answer: No, your Forester's SWCs will not work (and your car's aux harness has a different plug, too). See this post (#42 in this same thread), and #44 after that.
Old 09-22-2013, 03:06 AM   #688
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by JSchell1309 View Post
Installed it in something a little different. Since I went full nav swap [AVIC-X9310BT] in the hatch I put this one in the [1998] GC coupe.
Old 09-22-2013, 08:50 PM   #689
JSchell1309
Member#: 321321
Tuxedo Black
Originally Posted by SVXdc View Post
Haha thanks for the clarification. I updated original post with more info for anyone looking at it.
Old 09-23-2013, 03:58 PM   #690
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
10 G37 Coupe
Rydeen Duo
eeeshhhh.....dang it, i wanted the duo also but after seeing that, im not so sure. can't see crap.
Old 09-24-2013, 12:06 AM   #691
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
10 G37 Coupe
Rydeen Duo
[click thumbnails to see larger versions]
I just noticed that the camera image on the Infiniti G37 has double sets of parking guide lines. That's usually only the case when someone installed an aftermarket camera, and couldn't (or didn't bother to) disable the lines that the camera generated.
Do you know anything about that camera? At first, I assumed it was an expensive OEM camera that came with the car, but if it's something the dealer added, it might really be something people can find for a semi-reasonable price.
I found this YouTube video, supposedly a 2010 G37 -- shows how to enter the setup menus, disable camera for sonar only, and view the camera even while not in reverse (via the parking line adjustment screen).
Starting at ~2:15, you can see it only has the multi-colored lines (which that OEM HU is generating). The long yellow lines on yours must be coming from the camera itself -- notice how they're slightly skewed from the HU's lines.
Old 09-24-2013, 11:34 PM   #692
bry03cobra
Member#: 204371
Not sure if that's the Cam's fault if the pic. I would guess the screen in the Infinity is better quality. I'm using the Duo. My screen was kinda scratchy til I finalized the install and soldered the connections.
bry03cobra is offline   Reply With Quote
Old 09-27-2013, 05:12 PM   #693
sleeperlodo
Member#: 362048
2010 Forester XT
Short answer: No, your Forester's SWCs will not work (and your car's aux harness has a different plug, too). See this post, and #44 after that.
I just got stock 11 Forester HU with HD/SAT radio from local Craigslist for $60
Subaru Stereo Decks
Like you said, After installed, everything works great except Steering Wheel Controls buttons not working at all.
Sound quality better than my stock HU. Anyway I'd keep it
Old 10-11-2013, 08:36 PM   #694
jfitts23
Member#: 370670
BLK
Question
Does anyone have any new leads on a HD/SAT radio?
jfitts23 is offline   Reply With Quote
Old 10-12-2013, 11:38 PM   #695
jojo69
Member#: 309196
2012 Hatch
wrb
Nop although some have been lucky apparently! I've been scouting for local listings but nothing yet so i decided to go a different route. My euro one will b up for sale real soon. Good luck on waiting for a usdm one.
jojo69 is offline   Reply With Quote
Old 10-13-2013, 08:45 PM   #696
feakara1
Member#: 302220
2011 Sti
Swp
Why wait for a sat unit when u can use one from a 12 impreza or crosstek. As long as the sat plug is on the back of the radio it will work. You can even store 6 presets. The only difference is that you can only access sat by pressing the mode button on the steering wheel control and selecting a preset via the steering wheel only moves the station up or down numerically. Not sure if the regular sat unit has more than one sat setting ie sat 1 sat 2
feakara1 is offline   Reply With Quote
Old 10-17-2013, 07:07 PM   #697
jfitts23
Member#: 370670
BLK
Just a update, I found one of these head units on car parts.com. Searched 2011 Forester then it gives you a list of deck options to choose from. I found CP635U1 listed in the description. But it was under the indash 6 disc catergory. It was only 200, seems fair.
Old 10-17-2013, 09:11 PM   #698
Rymar
Member#: 310672
2012 Impreza Ltd 5Dr
Dark Gray Metallic
If you are curious as to how these radios are put together (and how to take one apart), check out this teardown at ifixit.com:
http://www.ifixit.com/Guide/Subaru+C...ut+Mod/17985/1
Rymar is online now   Reply With Quote
Old 10-18-2013, 08:20 PM   #699
Arossteven
Member#: 363673
Link?
Arossteven is online now   Reply With Quote
Old 10-18-2013, 08:40 PM   #700
jfitts23
Member#: 370670
BLK
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket SubeDooS SCIC Private Classifieds 1 04-14-2011 03:05 PM
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims johnpaulm1208 Tri-State Area Private Classifieds 1 04-06-2011 10:32 PM
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale mug23 Suspension/Brakes/Handling 3 06-26-2008 12:35 PM
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? ScoobyNubieToo! Car Audio, Video & Security 3 02-11-2008 08:26 AM
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires singincanary Private 'For Sale' Classifieds 5 08-30-2005 08:50 PM
