Welcome to the North American Subaru Impreza Owners Club Friday April 24, 2015
Old 09-04-2013, 06:55 PM   #501
Aquase
Member#: 292264
02 WRX
Its not him. Its an imposter.
Aquase is offline   Reply With Quote
Old 09-04-2013, 07:30 PM   #502
95ONE
Member#: 349550
If you're ever in Houston... There are plenty of guys who aren't in the 1000hp range who still like to have fun. It's just that you are right in the fact that so many ARE. Streets are long and straight. Drive 20 miles, turn right, and you're where you were going. Big end power rules down here. I'm one of the few that enjoys to turn though. Texas World Speedway, Houston Motorsport Ranch, Grand Sport Speedway are a few tracks close to home if you like to carve corners. Grip, not Drift. AND.. there are tons of drift events also if that's what you're into.
SO bring whatever power car you have to Houston, there's tons for everyone to do with a car.. or bike. or 4x4.
95ONE is offline   Reply With Quote
Old 09-04-2013, 08:09 PM   #503
C J
Member#: 132587
2006 JrTuned STi
Stock engine 9.77@147mph
C J is offline   Reply With Quote
Old 09-05-2013, 12:07 AM   #504
yamahaSHO
Member#: 73932
2005 STi - E85
2004 S2000 - E85
CJ shifting like a boss! It's amazing what that motor is holding up to and then I lift a head a just over 400whp with very mild timing. I see 3 motors we need to build this winter!
Old 09-05-2013, 11:19 AM   #505
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Garnet Red Peal (33j) e85
CJ....I can not believe that thing ins still holding together...the Asian person that assembled the thing much have a god like touch lol
SuaveCougarBait is offline   Reply With Quote
Old 09-05-2013, 06:17 PM   #506
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
CJ get'n it done!
Old 09-06-2013, 04:22 PM   #507
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Ive never lifted a head on a stock motor.. and as you can see from CJs car, my own car that went 106-108 1/8th, or Adrians that went 135mph its not like I don't push them. Cracked rings, bent rods.. sure
You sure you lifted a head? What is mild timing and what fuel?
Old 09-06-2013, 04:36 PM   #508
Clark Turner
Member#: 178047
02 WRX STI Spec C
I see a lot "head lifting" on E85 at over 25 psi with stock bolts with GT30R or larger turbo, Pretty common. Coolant splashed in engine bay around top of heads. Never saw one come apart from this though. Just back off boost and this goes away. ARP will hold up to 30 or so then you need arp-625 or larger bolts. On Gasoline/race fuel its not an issue.
Old 09-06-2013, 08:56 PM   #509
manitou
Member#: 193757
2006 XTI Limited
Yeah, What'd you make on my VF Jr. 450WTQ at 3100 on PnL's dyno? It got de-tuned a bit but the ring lands cracked with all that torque. Never a coolant issue.
Even now with my built motor, I thought I lifted head(s) at 29 psi and but nope, it was fricking radiator hose clamp.......and it was my idea to install them.
Old 09-07-2013, 01:38 PM   #510
yamahaSHO
Member#: 73932
2005 STi - E85
2004 S2000 - E85
It's pushing coolant to the top of the reservoir and tested positive for CO with a sniffer.
Pk tq timing 13-14 degrees / Pk RPM 26-27. TD05/20G/8cm @ 23.5 PSI (ELH, EWG, CAI, inlet, exhaust, blah, blah, yada. AFR was 11.5:1 (gas referenced E85). Clutch started going first, so I didn't run it any higher.
The car was feeling extremely healthy and I happened to notice my coolant level was at the top. I didn't spill any and the temp gauge did not indicate overheating. I happened to notice right after taking CJ for a ride.
Old 09-16-2013, 10:39 PM   #511
C J
Member#: 132587
2006 JrTuned STi
Pretty good run from the weekend. Healthy 408 windsor in a friends fox body. Mid 10 second car.
http://www.youtube.com/watch?v=jz-O2...ature=youtu.be
Old 09-16-2013, 11:26 PM   #512
SuaveCougarBait
Member#: 255092
2007 WRX Limited
That fox looks nice off the line.
Old 09-16-2013, 11:39 PM   #513
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Still kicking ass!!
I got your text CJ lets see what we can muster up for the next outing .
Old 09-17-2013, 11:53 AM   #514
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
doood your getting it done! nice to see someone who can get the car off the line properly without just side stepping the clutch lol. and huge win for the motor taking what seems like full time abuse every night
Old 09-17-2013, 12:06 PM   #515
manitou
Member#: 193757
2006 XTI Limited
You sure can drive CJ! Way to give er!!
Old 09-17-2013, 12:24 PM   #516
SuaveCougarBait
Member#: 255092
2007 WRX Limited
..CJ's motor was assembled by some Asian god at in the mother land. I'm still mind blown, this car is a factory freak for sure. If anyone else did this it would have tapped out by now I would guess.
Old 09-17-2013, 12:49 PM   #517
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yeah he is a really good driver. very consistent. any monkey can launch one but it takes more skill to smoothly get them off the line. Im glad ive kept my stock axles together on mine using the lc and over 500 hp.
and yeah this motor seems to be stout!!
Old 09-17-2013, 02:16 PM   #518
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is what i like to see more of! Thank you CJ! Awesome driving!
FuJi K is online now   Reply With Quote
Old 09-17-2013, 02:30 PM   #519
manitou
Member#: 193757
2006 XTI Limited
^^Coming from another good driver!
Old 09-18-2013, 08:12 PM   #520
C J
Member#: 132587
2006 JrTuned STi
Thanks guys, the fox runs pretty hard and it was a good run.
Old 11-13-2013, 07:56 PM   #521
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Very impressive! Just found this thread by randomly catching the 1320 vid on youtube. Like others have said, I am amazed the block has held together. I lifted the heads on my stock block running 26psi on e85 @ about 400whp.
STiled_04 is offline   Reply With Quote
Old 11-13-2013, 10:29 PM   #522
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
Junior tuned ftw.
99STM is offline   Reply With Quote
Old 08-16-2014, 01:14 AM   #523
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
10.7@134mph tonight still on the stocker
1.48 60ft on another pass as well.
The car and driver are doing work lol
Sent from my iPhone using NASIOC
Old 08-16-2014, 08:15 AM   #524
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Wow congrats CJ. How many miles do you have on the motor?
Old 08-16-2014, 09:56 AM   #525
CatfaceType-R
Member#: 81102
Originally Posted by 99STM View Post
Junior tuned ftw.
^this. Great job, CJ. You have a true-blue subaru unicorn!
2007/2008 STI = Same R180 ? experts please! Team Scream Transmission (AT/MT) & Driveline 9 05-21-2013 03:02 PM
2006 Forester E85 / Mustang Dyno PoZeR Proven Power Bragging 8 06-29-2011 03:51 PM
FS : 2006 Aspen White STI (Ready for E85 conversion) biker921 Private Vehicle 'For Sale' Classifieds 0 08-08-2010 10:43 AM
Cheap quiet RCA's please? Experts, please contribute. ebeck Car Audio, Video & Security 20 11-29-2004 01:22 PM
