Old 08-20-2013, 05:16 PM   #426
Turbo zxy
Member#: 356038
so finally efr 7163 has been relished in match bot, though I must say that I am not so impressed about it, though it say it is a development map but rated to max 60lbs/min, the resistance against surge is not that good like the efr 6258 is outstanding, must say I am little confused what they have been thinking of.
Turbin part seams nice though
Turbo zxy is offline   Reply With Quote
Old 08-20-2013, 05:21 PM   #427
Leafy
Member#: 330625
2006 WRX
It only looks like its not very resistant to surge because the damn map got all the way out to a PR of 4. FOUR! Overlay the 62xx map over the 71xx map, the lower flow areas are almost identical.
Old 09-06-2013, 02:27 AM   #428
NA STI
Member#: 285083
2006 STi
So anymore news? Its the last month of Q3 now... lol
Im very interested in getting one of these, just kinda hesitant with the new 60lb/min version as I doubt it will respond like the OP's 7163 setup. Do you guys have any dyno sheets of the most current 7163 turbos that are out for testing?
NA STI is offline   Reply With Quote
Old 09-07-2013, 06:27 PM   #429
LittleBlueGT
Member#: 96204
2013 STI GR
I will be picking up my FR EFR6758 kit tomorrow (parcel company south of the border - I am from Canada).
Might still be a month or two til I have info on it, but I will try and provide whatever people want for logs (comparisons to stage2+) etc....
LittleBlueGT is offline   Reply With Quote
Old 09-07-2013, 06:37 PM   #430
RobSTI89
Member#: 225268
2005 STI
I also picked up a efr6758 protune date is the 14th Will make a thread on it after numbers. Hoping for 400-450whp!
RobSTI89 is offline   Reply With Quote
Old 09-07-2013, 07:07 PM   #431
NA STI
Member#: 285083
2006 STi
Yeah make sure you guys post it up, im very curious to see the power and response of efr6758 setups also.
Im confused thoe, they used to show the efr6758 being a 49 lb/min turbo, but now on matchbot it shows it as a 53 lb/min turbo. Did they change the design of the wheel and make a new version (like they did with the 7163) or is it still the same old turbo and they just changed the flow rating?
Old 09-07-2013, 07:29 PM   #432
RobSTI89
Member#: 225268
2005 STI
I am in break in right now hit about 5-8psi but I swear it spools as fast as stock turbo. I got full build 272 cams and I am doing a race gas map so we shall see how far we can push it. Tune will be on a mustang dyno too.
Old 09-07-2013, 08:23 PM   #433
point78
Member#: 344329
2008 Wrx, 6mt
Break in should be about 20mins-then its on, like donkey kong!
point78 is offline   Reply With Quote
Old 09-07-2013, 08:34 PM   #434
RobSTI89
Member#: 225268
2005 STI
The motor needs broke in
Old 09-08-2013, 01:31 AM   #435
NA STI
Member#: 285083
2006 STi
I wanta see what it will do when that turbo is pushed, you should make 450-460whp on race gas with a good setup.
Also do you know what changed to put the 6758 from 49lb/min to 53lb/min recently?
I want to see non wastegated vband .64 exhaust housings to be made for this thing already
Old 09-08-2013, 08:52 PM   #436
Leafy
Member#: 330625
2006 WRX
Motor break in should only take 20 minutes, I forget the EFR recommended break in or if its even required with the correct material turbine wheel.
Old 09-08-2013, 10:26 PM   #437
RobSTI89
Member#: 225268
2005 STI
Motor builder and tuner all said 600 miles so I do what they say. Not in a rush to ruin my large investment.
Old 09-12-2013, 05:50 PM   #438
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
hey everybody - I dont know who follows our Full-Race Motorsports facebook page - If you'd like to see Full-Race, we will be at Subiefest 2013 - being held Saturday September 14th at Auto Club Speedway (AAA Speedway) in Fontana, CA. This year is going to be the biggest and best Subaru event to date! We will have our stock location EFR kits, twinscroll rotated kits and other legendary Subaru Impreza STI products on hand as well as the EFR turbos on display 8374 twinscroll, 7670 twinscroll, 6758 stock location and all of our turbo manifolds as well. 7163 details will be announced from BW next week, but we may have some info to share this weekend. Sorry to say I wont be able to make it (got really sick) but Jon and Jeremy will be there holding things down with our Freakoboost F150 !
Yes, the map changed for the 67mm compressor in MatchBot, but no hardware change was made to the compressor or turbo. The increased flow rating is simply due to BW running up to the fifth speed line and getting actual data up there ... before, that region was estimated. With running the higher speed and full flow (choke) points, they were able to produce a more representative comp map.
Looking forward to your results how did the install go?
Originally Posted by discopotato03 View Post
Geoff I hope BW plans to have big stocks of these 7163s because the punters are champing at the bit .
Full-Race will have the EFR 7163's first and we do have a decent amount due to arrive. Anybody interested, the reservation list is the best way to ensure that you will get one of these, there is no cost to be on the list of course.
Full-Race Geoff is offline   Reply With Quote
Old 09-14-2013, 10:34 PM   #439
RobSTI89
Member#: 225268
2005 STI
6758 made 408/420 on pump and 420/440 on 110 race gas. These where on a mustang dyno that a stock said read about 210/215ish. I will post graph when I get a digital copy. We over laid it on a stage 2 sti and it spooled 200 rpm later so basically no lag. Turbo would not hold till redline 23psi peak drop to 20psi
Old 09-14-2013, 10:38 PM   #440
Ilovecugars
Member#: 299442
2005 Forester XT
Stock port heads?
Ilovecugars is offline   Reply With Quote
Old 09-14-2013, 10:57 PM   #441
RobSTI89
Member#: 225268
2005 STI
No they are built heads with Kelford 272 cams, 1mm bigger valves, springs, retainers and ported head. Build bottom end.
Old 09-16-2013, 01:01 PM   #442
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
solid result for a mustang dyno, I think you are probably one of the first to try this kit with a built motor
Turbo would not hold till redline 23psi peak drop to 20psi... built heads with Kelford 272 cams, 1mm bigger valves, springs, retainers and ported head. Build bottom end.
can you verify its the 179284 "stiff" actuator and tell me how much preload did you have on the actuator?
Old 09-16-2013, 01:27 PM   #443
FASTofwestchester
Member#: 292964
1998 Legacy RHD TT
Geoff,
It is the stiff actuator. We set it up with 8mm preload
FASTofwestchester is offline   Reply With Quote
Old 09-16-2013, 03:38 PM   #444
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
ok, good.. with the built motor and big cams theres obviously a lot more exhaust flow than the stock motor/head/cam setups this kit is usually run on.. Making that power and spooling ~200rpm later than stock is solid!!
Old 09-16-2013, 08:05 PM   #445
LittleBlueGT
Member#: 96204
2013 STI GR
Bump for the graph.
Is the 200 rpm later spool attributed to the turbo, or to the bigger cams/valves?
Old 09-16-2013, 08:10 PM   #446
Bru1212
Member#: 178770
06 STi
04 FXT
Yup, this is the info I've been waiting for. I'm sold. Can you give a list of support/bolt ons please?
Bru1212 is offline   Reply With Quote
Old 09-16-2013, 09:57 PM   #447
RobSTI89
Member#: 225268
2005 STI
Waiting for email digital copy of graph best I have. That shows a 2012 sti stage 2 and my car.
My mods are....
Efr6758
Full race uppipe dp header
Gimmick motor sports catback
Grimmspeed 8mm manifold spacers
Aps 70mm intake
Aps inlet
Aps dr525 fmic
Aps fuel lines
Injector dynamics top feed conversion 1000cc
Dw 320 fuel pump
Manley 100mm pistons
Manley h beams
Kelford 272
Manley 1 mm oversized valves
Manley springs retainers
Apr head studs
I am sure I am forgetting something but feel free to ask away.
This turbo spools super fast makes amazing power through the whole power band. Turbo sound super amazing and bpv noise is badass.
Big thanks to fast of west Chester they helped me with everything. Message them to get your efr/full race needs. Also TpG tuning in pa they did amazing job with tune!
Old 09-16-2013, 10:10 PM   #448
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by LittleBlueGT View Post
Bump for the graph.
Just attribute it to the setup. It would be real hard to quantify what actually made the change because 1 + 1 doesn't always equal 2 when combined. I don't think the claim was ever made that it would spool just like the stock turbo anyway.
Old 09-16-2013, 10:20 PM   #449
RobSTI89
Member#: 225268
2005 STI
Cams typically move powerband to the right so cams didn't affect spool helped topend. And I believe they call 6758 the stock turbo killer and I believe it did that by making double power then a stock sti!
Old 09-17-2013, 10:17 PM   #450
RobSTI89
Member#: 225268
2005 STI
Me-6758 + blouch 20gxtr + stock sti
Can't believe how it out spools a smaller turbo !
