Old 08-31-2013, 11:36 AM   #1
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Default cross-thread recommendations
In the process of re-installing the passenger side fuel rail bolt it started to cross- thread. I stopped and now can't get it to start without pulling back into the improper threading. The bolt looks fine but I think I can see the thread damage in the hole
My question has to do with the material the TGV is made from on the 2011 sti and if it will be ok to re-tap. Also, I have never re-tapped something since I have never let a bolt cross thread and I am a little afraid.
Any suggestions/recommendations would be appreciated.
Thank you.
tazswing is offline   Reply With Quote
Old 08-31-2013, 11:51 AM   #2
jam007
Member#: 174706
2008 LGT-B
Try chasing the threads with the same pitch and a bottom tap, lube her up and take your time. It'll come out good as new
jam007 is offline   Reply With Quote
Old 08-31-2013, 01:01 PM   #3
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Thank you!
Old 09-04-2013, 10:47 AM   #4
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Thank you, again. It worked out fine. Lube, clutch on the drill and taking my time I was able to re-establish the top of the thread and the bolt threaded with expected effort (which is not much).
Old 09-08-2013, 06:45 PM   #5
jam007
Member#: 174706
2008 LGT-B
Nice, glad it turned out good I end up in these sticky situations all the time.
Old 09-08-2013, 08:11 PM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
it is almost always a better idea to do those kinds of things by hand
im amazed that you didnt have issues using a drill
Old 09-10-2013, 11:14 PM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
This^^^!!!!!!!!
Wow you got lucky! Next time don't use a drill. Do it by hand.
Bikelok is offline   Reply With Quote
Old 09-10-2013, 11:22 PM   #8
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
LOL you are afraid of crossthreading and you retapped with a drill.......... Boy aren't you lucky today.
pho_shizzle is offline   Reply With Quote
Old 09-10-2013, 11:26 PM   #9
jam007
Member#: 174706
2008 LGT-B
I totally missed the fact you used a drill....yikes.
Old 10-12-2013, 04:16 PM   #10
EABiker
Member#: 359836
You were lucky! Not even enough time to say "Ah S..." if you mess up with a drill!
EABiker is offline   Reply With Quote
Old 10-14-2013, 08:57 AM   #11
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
You guys are acting like a drill only has speeds 0 and "over 9000!!"
Plenty of drills are easily speed modulated by the trigger. Once you get it started in the threads it's perfectly fine. I've done it with a drill lots of times without ever messing it up. The drill is especially useful where you don't have enough room to use the hand tap.
gsrcrxsi is offline   Reply With Quote
