Old 07-25-2013, 01:34 PM   #1376
Rarh
Member Sales Rating: (4)
Member#: 22433
2012 WRX Limited
Looking good RWU, i love white Subarus. Sorry i did not realize you posted that earlier.
I would contact ISC and let them know the noise and assumption its Coil Bind. I believe they will send you new thrust bearings as well. Take note you will have to pull the coilover off and disassemble and put back together. This requires another alignment... which is why i am content for now to not hear the noise anymore and replace the part in the future. According to ISC coil bind will not cause any damage so i am content for now.
Btw what did you set your dampning too out of 32?
Rarh is offline   Reply With Quote
Old 07-25-2013, 04:49 PM   #1377
Rwu00313
Member Sales Rating: (17)
Member#: 82153
2016 WRX
CWP
Yeah I'm going to try greasing the area you mentioned and see if that takes care of the issue. If not i'll contact ISC and deal with installing the new thrust bearing if they end up sending me a replacement. As for dampening, right now I'm set at 10 clicks from soft in the front and I believe 12 clicks in the rear. I think I may go slightly softer in the fronts...maybe 8 or 6 clicks.
Rwu00313 is offline   Reply With Quote
Old 07-25-2013, 04:59 PM   #1378
Rarh
Member#: 22433
2012 WRX Limited
I started off with 16 from Soft.. and it felt to soft. Everything is personal experience but considering the street setup at max clicks is the softest setting of the track setup i figured i would play with it.
I ended up with 24 on front and 26 on rear... its a world of a difference. I love it but hate it at the same time driving around NY/CT area. These roads suck unless you go further up. I am still playing with the settings and may soften them up a little.
Good luck with your hand.. i mean lube job.
Old 07-26-2013, 01:04 PM   #1379
ISC Suspension
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 252676
If you want to repack your thrust bearings with grease you can do so without needing another alignment by simply:
(having the vehicle on jack stands or on a lift)
Dropping the top assembly of the strut down while keeping the bottom mounts attached/ installed.
Take off the top 19mm nut then the 3 12mm ones that hold the plate to the vehicle, the thrust bearing comes right off as you pull the camber plate/ top plate off.
Clean it and re grease it once a season or so (in more moderate climates this often not needed)
Put everything back together
Jack the knuckle assembly back up until the strut is back in it's place and tighten those 3 12mm's and the 19mm.
Hope that helps/ makes sense!
__________________
Business Hours:
9am-5pm EST
603-715-9078
Join us on our Social Media!
Contact Info:
All service, rebuilds, and customer support done in USA.
ISC Suspension is offline   Reply With Quote
Old 07-29-2013, 02:36 PM   #1380
NIXONwrx
Member#: 363704
hi everyone my name is Nash and this is my Subaru . im new to this and what brought me here is the ISC coilover thread. I've read almost all 56 pages of this thread and after all that reading i decided to join =). lot of people with a lot of good info! I currently looking to replace my HELIX coilovers and after A LOT of research came to the conclusion that the ISC's will be my new next set.
NIXONwrx is offline   Reply With Quote
Old 07-29-2013, 02:56 PM   #1381
AJW Performance
Vendor Sales Rating: (38)
Member#: 219896
Nice looking car,
you will def be happy with them!
__________________
Best Pricing and Customer Service in the Business!
Shop Line: 603-715-9076
Hours:
Monday- Friday Closed weekends
9:00 AM to 5:00 PM at shop
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
facebook us: "AJW Performance"
Follow some of our work-
AJW Performance is offline   Reply With Quote
Old 07-29-2013, 03:32 PM   #1382
NIXONwrx
Member#: 363704
Thanks. Looking to make a purchase sometime this week. I will post my reviews once I get them. Looking to purchase the Street/Sport. Looking for a comfy ride but able to perform when needed. hope thats what these will provide.
Old 07-29-2013, 05:29 PM   #1383
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
awesome!
__________________
Open Daily
#1-941-257-9618 AIM= importimagerace
Best Deals on
!!! WE BEAT ALL PRICE QUOTES!!!!!
IMPORTIMAGE is online now   Reply With Quote
Old 08-13-2013, 01:09 PM   #1384
ISC Suspension
NASIOC Manufacturer
Member#: 252676
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 08-13-2013, 02:57 PM   #1385
Rarh
Member#: 22433
2012 WRX Limited
What is the difference between your springs vs swifts? What would the end user experience between them both
Old 08-13-2013, 04:08 PM   #1386
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
swifts are going to be more comfy, its just a higher end spring
__________________
Open Daily
Best Deals on
Old 08-13-2013, 04:39 PM   #1387
Rarh
Member#: 22433
2012 WRX Limited
If we have basically brand new ISC or even used what is the cost for upgrade?
Old 08-15-2013, 08:42 PM   #1388
diirk
Member#: 204238
2013 BRZ Premium
There's also a larger selection of spring rates available from Swift.
diirk is offline   Reply With Quote
Old 08-15-2013, 08:43 PM   #1389
diirk
Member#: 204238
2013 BRZ Premium
Well, it's been a while, but here's the latest.
Had ISC coil overs purchased from AJW Performance installed by Pure Performance. Street/Sport version. I think that's 8k/6k.
So far so good. No noise. Ride is decent. Need to dial it in a little more due to a little bit of bounce in the rear.
Have it down about 1.25"
Old 08-15-2013, 08:48 PM   #1390
AJW Performance
Member#: 219896
looks good! Thanks again
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 08-16-2013, 10:18 AM   #1391
Rarh
Member#: 22433
2012 WRX Limited
Been tweaking the suspension since i got it. I must say i love the fact that its so adjustable but i hate it as well lol. Every weekend i tweak the dampning and i finally had a chance to drive it on some mountains roads this past weekend. Had it on 24/24 and was content but not super happy. Pulled over at a scenic road stop and turned her up to 32...wow what a difference. The car felt AMAZING.
ISC or vendors, anyone know if there is a middle of the ground setup? For example Street sport 32 is 1 on track right? Is there anything that is in between?
Old 09-09-2013, 12:41 PM   #1392
AJW Performance
Member#: 219896
The stiffest on street sport is the softest on track race.
Glad you are happy with them!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 09-11-2013, 02:44 PM   #1393
avidworks
Member Sales Rating: (2)
Member#: 144415
Anyone cut the bump stops on their fronts? I went a little lower and now I'm getting some hollow clunking noises over uneven surfaces... never happened before that so I'm assuming that's the issue?
avidworks is offline   Reply With Quote
Old 09-12-2013, 12:39 PM   #1394
silviajdm
Member#: 163703
09 Forester
SSS
I tried going to the ISC store but it's down. Do you guys sell the allen-key screws for the rear top mounts?
Putting together a strut a few months back I think 2 are coming loose make a clunk in the back. Thanks?
silviajdm is offline   Reply With Quote
Old 09-12-2013, 12:41 PM   #1395
ISC Suspension
NASIOC Manufacturer
Member#: 252676
Yes it is getting revamped right now.
Give support a call 603 715 9078 we can get you situated!
Thanks,
ISC
__________________
Business Hours:
9am-5pm EST
603-715-9078
Contact Info:
Old 09-17-2013, 06:47 AM   #1396
sackytar
Member Sales Rating: (46)
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
One Lap on ISC N1s. Hitting 120mph on the back straights into hard braking!
Old 09-17-2013, 08:45 AM   #1397
AJW Performance
Member#: 219896
Awesome Video sir! Thank you for sharing!!!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 09-17-2013, 08:08 PM   #1398
sackytar
Member#: 149262
PrimerGrey
Anytime. I work these things! At track and autox!. They work for me.
Old 09-19-2013, 08:44 AM   #1399
scrappydoo225
Member#: 262933
2005 Leztastic wagon
cayanne red pearl
So question.
I was adjusting my dampening yesterday and I felt the the clicks but it just kept spinning it never reached an end. Sooooooo dafuq did I do wrong?
scrappydoo225 is offline   Reply With Quote
Old 09-19-2013, 09:09 AM   #1400
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
great video!
__________________
Open Daily
Best Deals on
ISC-N1 coilover dark_throne31 Car Part Reviews 1 07-04-2013 06:36 PM
Gauging Interest: A'pexi N1 Coilovers ScrambleBoost Bay Area Impreza Club Forum -- BAIC 6 10-22-2003 11:57 PM
A'pexi N1 coilovers- open box Gruppe-S Vendor 'For Sale' Classifieds 3 10-02-2003 12:48 PM
