Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 09-05-2013, 11:42 AM   #1
kesiki
Member#: 318423
SSM
Default Fram oil filter fits?
Hi
I have a 2011 wrx and today I hit up the local Walmart to buy oil and a filter. I bought 5 quarts of ultra penzoil synthetic and xg fram oil filter. So as I was changing the filter out I notice right away the one filter was bigger than the other. I accidentally bought the 7317 filter (used to fit the rsx)which is bigger than the 6607. I just wanted to see if the filter would fit and it does. It threads on perfectly.
My question is will I have any issues running the bigger 7317 filter and what's the size of the filter's purpose?
kesiki is offline   Reply With Quote
Old 09-05-2013, 12:02 PM   #2
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
Step 1: Type fram 6607 in google serach engine
Step 2: Click link most fitting to situation
http://forums.nicoclub.com/fram-oil-...e-t379468.html
Step 3: Speed read for realitive info. - reduces time spent
"I'm no expert by any means, but a quick search on Fram 6607 and 7317 show them as interchangeable. They also work in Mazda's and Acura's. The 7317 has more filter surface area and the 6607 is suggested for limited-space applications."
Step 4:
PLAN B - Lay your burden upon another
JDMJNKY is offline   Reply With Quote
Old 09-05-2013, 12:05 PM   #3
kesiki
Member#: 318423
SSM
Haha thanks for the quick reply. I feel better now.
Old 09-05-2013, 12:59 PM   #4
FaastLegacy
Member#: 11671
You might as well put the ****tiest dino oil you can find in it if you're going to put a FRAM filter on it.
FaastLegacy is offline   Reply With Quote
Old 09-05-2013, 01:13 PM   #5
JustyWRC
Member#: 153088
2005 Baja Turbo
09 WRX
Been using FRAM for decades. Not a single problem.
Old 09-05-2013, 02:00 PM   #6
mejifair
Member#: 11356
2012 WRX STi Hatch
Seen this yet? Didn't think so.
mejifair is offline   Reply With Quote
Old 09-05-2013, 02:20 PM   #7
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Fram filters will work, just not very well.
That being said I use OEM when the car is under warranty, then step it down to Purolator PO. You can get a bundle of OE filters for almost the same price as aftermarket, why risk your engine not being covered over small change.
surowrxa is offline   Reply With Quote
Old 09-05-2013, 02:45 PM   #8
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
M1 EP 0w20 73,820 miles
Originally Posted by kesiki View Post
Hi
6607 is that really small filter, same M20 x 1.5 threads as the taller 7317. No problem there. The XG is the top line Fram filter. It has 2 layers of synthetic media and a wire screen in between. It is a much better build quality than the old orange can (OCOD). Search for the XG Fram on Bob Is The Oil Guy and see for yourself. Only thing is, OEM filters are listed having a 23 psi bypass valve and these XG filter are 11.
CLL_OBP is offline   Reply With Quote
Old 09-05-2013, 03:21 PM   #9
JustyWRC
Member#: 153088
2005 Baja Turbo
09 WRX
Old 09-05-2013, 03:22 PM   #10
JustyWRC
Member#: 153088
2005 Baja Turbo
09 WRX
http://www.youtube.com/watch?v=XRRgw4B7R-I
And what does this video have anything to do with my hundreds of problem free filters I've used?
Old 09-05-2013, 06:43 PM   #11
subi400
Member#: 216984
1996 Impreza outback
Green
I don't think you get it do ya.... doesn't matter how the filter filters the oil, if it DOES NOT have the right bypass spec of 23 psi then the filter will be in bypass mode at least 50 % of the time. Tell me how that filter is filter your oil correctly...hmm??
Don't you get it that subaru engines run almost double the oil pressure compared to others there for they require a filter with the correct bypass spec of 23 psi... in order to filter an adequate amount of oil during operation...
Go take your engine apart and tell me how that filter is doing...
I once used the fram orange filter on my 96 impreza 2.2 until I found out that the filter didn't have the correct bypass spec of 23 psi so I made the switch to the PureOne Purelator PL14460 which DOES have the correct bypass spec of 23 psi. It doesn't become the question of if an oil filter filtering oil correctly, but rather does it filter oil the correct amount of time based off the given oil pressure for that engine.
Old 09-05-2013, 06:57 PM   #12
gpshumway
Member#: 43950
07 WRX LTD Wagon
WTF?
Stop throwing around specific numbers when you have absolutely no clue what you're talking about. At least 50% of the time? Based on what analysis? Show me some engineering calculations or empirical data please.
Double the oil pressure? Um, no. The PRV is set at 85 psi, which is pretty normal for all engines, lots of old-school pushrod 'merican V8s have higher PRV settings.
You make an awful lot of strong, inflammatory statements for the amount of real information you provide.
gpshumway is offline   Reply With Quote
Old 09-05-2013, 07:30 PM   #13
subi400
Member#: 216984
Green
Originally Posted by gpshumway View Post
WTF?
Where's your data to show that other filters with under the specific 23 psi bypass spec filter the oil the adequate amount of time during operation... hmm?
Go take a look on BITOG website for a while and tell me I don't know what I am talking about in regards to subaru engines, their oil pressure and the proper filters to use...
Old 09-06-2013, 11:27 AM   #14
subiFKNpowers
Member#: 361942
06 TR VF39/E85
Graphite & Carbonfiber
Its ur car run what you want. But I will never use fram in my subi or any of my other vehicles. Look into the roki mazda rx8 or even the brz filter has same bypass with a larger filtering media.
subiFKNpowers is offline   Reply With Quote
Old 09-06-2013, 12:08 PM   #15
subiFKNpowers
Member#: 361942
06 TR VF39/E85
sorry for double posting but i watched both fram videos and i will say im impressed by the rigorous testing that do on their products.
Old 09-06-2013, 01:26 PM   #16
FaastLegacy
Member#: 11671
Your car probably won't notice the difference between synthetic and non-synthetic oil either, but why would you cheap out on a $3 oil filter when you can get something better for a cup of coffee more?
It always makes me giggle when I see someone buy one of the best synthetic oils on the market like the OP did and then cheap out on the filter. Really?
Ultimately, it's your car and you can be a cheapskate if you want to. I don't know why you wouldn't suck up the extra $2-$3/filter and buy something far superior.
Old 09-06-2013, 03:16 PM   #17
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Here is the irony. Fram Extended Guard filters are not cheap. The 7317 model is $9 @ my Wal-Mart. Here is an OE filter package deal from Chaplins:
http://www.subarugenuineparts.com/pr...oducts_id=1520
They come out to $5.55 each. Did not calculate shipping, but Byers (OH) ships free with dirt cheap prices too.
My guess is Wal-Mart was the "one stop shop" for the OP. I can't blame them, I don't want an extra stop running around getting stuff done...but then there is the internet.
Old 09-06-2013, 03:19 PM   #18
bluesubie
Member#: 767
04 FXT
Show me a Subaru turbo used oil analysis using a Fram oil filter and the uoa was flagged for poor oil filtration. One may exist, I really don't know. People also say the OEM Honeywell filters suck, yet they continue to produce stellar uoa's.
Why would anyone look at random videos or pics of cut up filters when there is DATA on these things in our cars right here on nasioc? Yeah, really.
-Dennis
Old 09-09-2013, 07:45 AM   #19
motorking
Member#: 254457
1967 mustang
black
Hi
Hi,
I am the tech manager at FRAM. The 6607 and 7317 do both have the same thread size at 22mm, and the same bypass valve setting at 13psi. The gaskets are very nearly in exactly the same place. I have a 2005 Nissan 350Z that also calls for the 6607 and I run a XG7317 on it. I personally like having the larger filter due to having a big turbo on this car. No issues, that said I must tell you this as a oil filter company employee. If you install a filter on your car that is incorrect for your car, you not be covered in the event of a failure. Claims processors (at all auto parts companies) are trained to confirm the right part number was used in the first place.
So, sorry for the long answer but like anything else, its complicated
motorking is offline   Reply With Quote
Old 09-09-2013, 07:47 AM   #20
motorking
Member#: 254457
1967 mustang
black
Well, you get what you pay for. The FRAM Ultra (formerly extended guard) is a way better filter than the oe filter. Dual layer synthetic media wrapped around a pleated metal screen vs a standard cellulose/synthetic single layer media.
Old 09-09-2013, 08:01 AM   #21
motorking
Member#: 254457
1967 mustang
black
Really? That is a pretty harsh comment with nothing from you to back it up. I work for FRAM so I do take it personally. I run XG filters on my 480HP 350Z and my 430ci windsor 67 Mustang. So you know better than the engineers at Subaru?
The FRAM XG filter is by far the best oil filter made at any price. If you actually took the time to do a little research, you would figure that out.
The XG filter is a dual layer full synthetic media wrapped around a stainless steel screen, silicone antidrain back valve, 99% efficiency using ISO 4548-12 testing, 15k change interval capacity, nothing in the oil filter industry comes close.
Old 09-09-2013, 08:01 AM   #22
point78
Member#: 344329
2008 Wrx, 6mt
I've been using the 2009 rx8, Tokyo Roki filters.
Proper bypass & have a suspicious black color...
point78 is offline   Reply With Quote
Old 09-09-2013, 01:48 PM   #23
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
And the oil filter hypocrites can all shut it. The best filter on earth is an oil bypass unit. Don't have one? Shut it. I run orange Frams or whatever is on sale at Walmart.
Old 09-09-2013, 02:03 PM   #24
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I used to use the FRAM TG filters, until I had several in succession that leaked at the seam. Prior to this event, I have used Fram filters on all my cars for over 30 years. Never a problem.
If you don't experience the leaky seam, FRAM filters work very well, as long as they fit that is .
Old 09-09-2013, 04:01 PM   #25
rdieder
Member#: 257818
2007 STi
from bitog:
"According to Purolator, the Honda OEM filter bypass setting is 12 to 14 psi. WIX (NAPA Gold) builds their oil filters with a bypass setting of 8 to 11 psi, while AC Delco builds theirs to a setting of 11 to 17 psi. How much do these differences matter? I don't think anyone knows, even the engineers, and each has its own set of advantages and disadvantages.
If you do lots of racing, you're probably better off with a higher bypass setting.
If you do lots of *cold* starting, especially in the winter, or seldom change your filter, I think you're better off with a lower bypass setting. However, with few exceptions, bypass pressures for spin-on filters run in the 8 to 17 psi range, and any of them should work acceptably. "
Good to know i didnt hurt my engine when i was lazy to get an OEM oil filter from the dealer. IMO probably most folks on this board daily drive their cars..so the low bypass setting in the Frams would work just fine. The way i see it , once the oil gets to temp,the Fram should filter oil just as effectively as an OEM filter.
rdieder is offline   Reply With Quote
