Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 02-20-2013, 08:28 AM   #76
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
someone please help me out. Someone else with an 05 sti must have done this mod, and/or someone else must have run into wiring color differences. i would love to get this mod done without process of trial and error.
theres no other red wire coming out of that relay on mine... just red/blue stripe- which you can see I cut. It looks like a different pinout than the OP. I thinnk the white/blue stripe looks like the same pinout, but I don't want to cut it and have it not be the right one again.
tapped orange wire..
only red wire on relay.. red/blue stripe:
VTSubieRS is offline   Reply With Quote
Old 05-04-2013, 05:26 AM   #77
jose_a_v31
Member#: 280138
2006 Impreza STi
Nice write up, my only question is, does it stay off when the car is off? There is another mod that involves only one wire, but it gets tied to a constant 12v, so the lights stay on regardless if the car is off.
jose_a_v31 is offline   Reply With Quote
Old 05-04-2013, 12:47 PM   #78
rex.effect
Member#: 99745
2013 C-Max Hybrid
Titanium White TriCoat
no, doing it this way powers them off when you take out the key.
rex.effect is offline   Reply With Quote
Old 05-07-2013, 06:13 PM   #79
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
Want to do this to my 2013 wrx hatch. Any DIY's for it?
ScoobyFreak86 is offline   Reply With Quote
Old 05-08-2013, 09:17 AM   #80
rex.effect
Member#: 99745
2013 C-Max Hybrid
Is the 13 model that much different than the 11's? I haven't had my subby for a while now, so I am a little out of the loop.
Here is my write-up for the Fog Light Bypass on an 11' STi Limited.
Old 05-08-2013, 12:40 PM   #81
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
^ Definitely a great write up, but still a little confusing to me. Not great with electrical work as I feel I would get a bit overwhelmed with the different colors and what to actually do. I would feel more comfortable having someone there that knows what they are doing. Thanks though!
Old 05-08-2013, 01:00 PM   #82
rex.effect
Member#: 99745
2013 C-Max Hybrid
I understand you apprehensiveness. Yes, it is all a little confusing, but the premise should be the same through all the model years. Find the lead from the stalk, sever it. Find the lead from the module, severe it. Run a "jumper" wire from stalk lead to "out" side module lead. All this process is doing, is literally taking the start of a wire, removing the "middle man" control module, and reconnecting the wire on the other side.
If your concerns come from the wire colors, i.e. you get under there with the panels off and don't see the wire colors mentioned in the write up, then all you need is a volt meter.
Turn the fogs on, test each wire at stalk side for voltage, note color. If you get more than one positive result, then turn off the fogs and try your wires again. Do the same thing on the back side of the control module. Once you have the correct wires noted, then you just cut and connect as described in each of the write ups.
Anyone local to Northeast Baltimore with a 2013 can feel free to contact me for a meet up. I can climb under there and figure things out pretty quickly to tell if the wires are still the same colors.
PS - I did this mod in my 04 WRX, 05 STI, and 11 STI.
Old 05-08-2013, 05:22 PM   #83
wrxposer
Member#: 188219
2007 2.5i Ltd.
CGM
Is 06-07 wired differently (see the diagram I posted in this thread) because this did not work on my 07? Can anybody else confirm this? This worked on your 04-05? I really wanna do this so I can shut off my HIDs when I want to. Right now I'm just running with them on all of the time with the DRL resistor bypassed.
wrxposer is offline   Reply With Quote
Old 05-08-2013, 09:04 PM   #84
rex.effect
Member#: 99745
2013 C-Max Hybrid
I don't see your post containing the diagram.
Here is the thread for my 05 setup. The other person in the thread had an 06 and was able to follow the guide to get it working. Again, the 06 should be the same as 07 in wires color. Check my second thread and see if that helps you.
I miss my Subbie so much
Old 05-09-2013, 07:19 PM   #85
wrxposer
Member#: 188219
2007 2.5i Ltd.
CGM
my bad, sorry I thought I was posting in the Fogs as DRLs thread that I'm also subscribed to.
Independent fogs with DRLs disabled will probably be the way I have to go though since I can't get the fogs as DRLs to work on my 07
Old 05-10-2013, 11:05 AM   #86
rex.effect
Member#: 99745
2013 C-Max Hybrid
Are the 2.5i's wiring less involved than the wrx or sti? Where did you obtain that wiring diagram from? Are you absolutely sure it matches youR 2.5i.
Old 07-21-2013, 08:29 PM   #87
TheBOOSTisLOOSE
Member#: 343493
Platinum Silver Metallic
Just did this Foglight rewire today and It worked like a charm! great writeup!!!
TheBOOSTisLOOSE is offline   Reply With Quote
Old 07-22-2013, 08:22 PM   #88
silver_subaru
Member#: 362756
[quote=insane_one;35979489]
Maybe I missed this when I read through the thread. Do the fog lights work all alone? I keep seeing pics where the running a lights are still on!
silver_subaru is offline   Reply With Quote
Old 07-23-2013, 12:22 AM   #89
TheBOOSTisLOOSE
Member#: 343493
you have to have at least the switch turned to parking lights for the fogs to work. this is wiring to make the fogs work with running lights or with head lights
Old 07-23-2013, 01:12 AM   #90
silver_subaru
Member#: 362756
Oh ok I was hoping you could wire it with nothing but the fogs! Thanks for the tutorial! Can't wait to get it done!!!
Old 07-24-2013, 12:49 PM   #91
donnyjaguar
Member#: 363137
Default Anyone have a wiring diagram for 2008 Legacy/Outback?
I'd like to modify my foglights to do the same but this modification doesn't look at all like my car. FWIW, my car uses the middle "parking" lights for the daytime running lights. Every wiring diagram I've seen shows the low-beam as being used for the DRLs. Any help/links appreciated.
donnyjaguar is offline   Reply With Quote
Old 08-18-2013, 12:26 AM   #92
emphrum26
Member#: 287380
2006 Legacy GT
Brilliant Silver
Thanks for the great write up!
Here's mine
emphrum26 is offline   Reply With Quote
Old 08-21-2013, 08:03 PM   #93
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
i gotta mount my new led driving lights...install the new fog lights and re-wire the whole damned thing so i can light up the night....driving at night way out in the middle of nowhere where there isnt ANY light other than your lights, REALLY shows the weakness of the stock lighting.....im still diggin the osram rallye 65w H7 + 9011 combo in my 06 wrx but the stock fogs are garbage and a set of good, PROPERLY AIMED, driving lights has just gotta happen.
Old 09-09-2013, 05:11 PM   #94
rdeezWRX
Member#: 349202
I just did a quick test before I ran to the store to get a terminal for the ground and it seems like the button is working without rerouting the green/yellow fog wire.. Should I reroute it anyway or can I leave it as is without touching it? Would it mess anything up specifically if I didn't?
rdeezWRX is offline   Reply With Quote
Old 10-18-2013, 04:46 PM   #95
Culti
Member#: 248192
2007 STi
No one seems to have answered the 2007 STi question so I'm going to ask again. There is no ORANGE wire to tap into for 12V constant power... Can someone please post a picture of the wire to tap into for power for 2007 STi. I've posted in 5 other suby forums for an answer because there seems to be no info on it... Thanks in advance.
Culti is offline   Reply With Quote
Old 10-24-2013, 03:57 AM   #96
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Originally Posted by popeball View Post
i followed the instructions exactly but my foglights are not independent, they require the parking lights to be on. other than that everything works. is there any way for me to now get the foglights to run by themselves, without any other exterior lighting?
i have a 2006 2.5i
thanks
im wondering the same thing, how can you do this and have them 100% independent along with the indicator light stating that the fogs are on
tjmmason93 is online now   Reply With Quote
Old 11-19-2013, 11:15 PM   #97
shredhead511
Member#: 371199
2007 Impreza Hatch
Great write up man, worked great. Pictures like this are always helpful.
shredhead511 is offline   Reply With Quote
Old 11-25-2013, 10:04 AM   #98
Con6tY5efs
Member#: 374396
neat soldering tip that is perfect for these kinds of wiring jobs.
Con6tY5efs is offline   Reply With Quote
Old 12-22-2013, 02:32 AM   #99
kozeeh
Member#: 312098
thanks insane_one for the awesome DIY ! just did this earlier took about 20mins, i followed the instructions to have the fog light button illuminate but mine is not working, maybe a bad ground? (1 of the 2 10mm nuts above fuse box) too lazy to go back under there and find good ground i will live with it for a bit until i decide its bothering me. THANKS !
kozeeh is offline   Reply With Quote
Old 04-26-2014, 11:25 AM   #100
Scuba Roo
Member#: 384037
2014 Bonestock hatch
Charcoal
YES PLEASE! i have a 2014 and cant find a DIY similar to this one i really would rather do this then have to wire a separate relay and all that bs.
Scuba Roo is offline   Reply With Quote
How to DIY: DRL Disable insane_one Electrical & Lighting 25 10-04-2015 09:38 PM
Independent Foglight Mod writeup for the BE Guys MitchGT Legacy Forum 5 04-29-2005 01:20 AM
how to change the foglight bulb Grey Ghost Electrical & Lighting 12 04-27-2005 11:25 PM
how to aim my foglights? legacy2003 Electrical & Lighting 2 09-24-2004 10:14 AM
How to aim stock foglights? ShutUpGeek Electrical & Lighting 2 01-11-2004 08:20 PM
