Old 01-31-2007, 02:01 PM   #1
unwrittenlaw
Member#: 62525
Default Rear Brake Pads More Worn Than Fronts
I just had the 30K service on my 04 WRX (at non-dealer shop), and the tech showed me that the rear brake pads are pretty much done, while the fronts have about 40% left. I don't do any racing/hard driving, and the only mods i have are bigger wheels/tires, and B&G springs.
He said I should talk to the Subaru dealer and ask why the wear in the rear is so much worse than in the front, considering the fronts usually wear down before the rears. He mentioned that Subarus usually go to 40K before the rear pads need to be replaced.
Is something wrong with my rear brakes, or is this normal wear and tear? I do use my parking break whenever i park the car, not sure if that would cause excess wear.
Thanks for any suggestions
unwrittenlaw is offline   Reply With Quote
Old 01-31-2007, 03:13 PM   #2
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
That's odd. I'm curious myself.
volkl23 is offline   Reply With Quote
Old 01-31-2007, 11:27 PM   #3
just smurfy
Member#: 135893
2012 Smart Car
murdered out w/ stickers
Same here, on my pre-purchase inspection on a 29k rex, the mechanic said the rears were at 20% and fronts were 50%. The subie mechanic thought that it was a little unusual but wasn't alarmed......
you are not alone
- in both your situation or your confusion.
just smurfy is offline   Reply With Quote
Old 02-01-2007, 07:35 AM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
My '04 does the same thing, and generates more dust from the rears, too.
I've always suspected the EBD as the cause.
Spenk is offline   Reply With Quote
Old 02-01-2007, 12:08 PM   #5
ESmooth
Member#: 118082
We have heard about folks seeing increased rear brake wear on EBD cars, but mostly when the majority of their driving is around town at low speeds with lots of stop and go. The EBD systems are thought to be using more rear brake than the front in order to keep the car flatter under braking which is better for the driver and their passengers. Under more aggressive braking the fronts will be doing more work making pad wear more normal. We have not done any tests to prove this but are seeing this happen more and more on EBD cars.
ESmooth is offline   Reply With Quote
Old 02-07-2007, 04:35 PM   #6
unwrittenlaw
Member#: 62525
Thanks for the information. Sounds like it may be a common characteristic.
Old 02-07-2007, 04:50 PM   #7
amukaoen
Member#: 62595
04 WRX Cobb S2
Ya, my fronts are at like 50% and my rears are at like 15%... so I was like ... wait, wtf?
Glad I saw this thread and found out it wasn't just me. All my driving (well 95%) is city driving, so that makes a lot of sense.
amukaoen is offline   Reply With Quote
Old 02-07-2007, 08:21 PM   #8
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
same here, I have an 04, do mostly city driving, and my rears wore down faster than my fronts.
It has nothing to do with the handbrake, that has a seperate drum setup inside the hub of the rear brakes.
boundy3 is offline   Reply With Quote
Old 02-07-2007, 10:03 PM   #9
just smurfy
Member#: 135893
2012 Smart Car
Yup, city driving here....
By the time my car's warmed up, I'm pulling into the driveway at work....
Thanks for the info -
Old 02-08-2007, 12:12 AM   #10
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
Default Same here.
I recently took my car in for service, and the tech there showed how my rear brake pads were done, and the front barke pads were still good.
I guess it is normal.
wrXmon is offline   Reply With Quote
Old 04-20-2007, 09:25 PM   #11
David Langseth
Member#: 130292
2002 Forester
Default Happens on Honda's also
In addition to my Subie, I also own an Accord, and the same thing happens on the Accord. Had to replace rear pads at about 25 K, but didn't change the front pads until 43K. Majority city driving. The Honda forums have the same kind of discussions about why it happens. No consensus, but agreement that its common.
David Langseth is offline   Reply With Quote
Old 04-21-2007, 06:22 AM   #12
Lawrence
Member#: 82518
2005 wrx
I have a 05 wrx. Same scenario here. Except my rear right one more worn than the rear left. But, in the big picture my rear is more than the front.
City Driving, also very agressive driver.
Also, my rear right is making noise, like metal on metal.
BTW, what is EBD? I'm guessing Electronic Brake...but dont know the rest.
Lawrence is offline   Reply With Quote
Old 04-21-2007, 07:41 AM   #13
Spenk
Member#: 7164
2000 Miata LS
Electronic Brakeforce Distribution
Old 04-21-2007, 07:59 AM   #14
rudeboy_sti
Member#: 124829
2005 STI
WRB/Gold
I have an 05 STi with 34.5K on it. Rears just got changed by dealer. Fronts are at 30%.
Rears were making a clicking noise from take off going forward or reverse. Just an FYI in case anyone hears the same and wonders what it is. You know how we all drive around with our heads out the window wondering what all these noises are.
rudeboy_sti is offline   Reply With Quote
Old 04-21-2007, 09:33 AM   #15
ESmooth
Member#: 118082
That clicking noise is pad shift that is extremely common with the factory Brembos. You may find that your new pads end up doing the same thing.
Old 04-21-2007, 11:36 AM   #16
Web Foot STi
Member#: 39086
2004 STi
Normal. Under light use the rears wear more.
A bias thing.
Web Foot STi is offline   Reply With Quote
Old 09-10-2013, 09:02 PM   #17
Azrei
Member#: 367999
Thread necro, terribly sorry:
Should this same effect occur on my '00 2.5RS? It probably doesn't have EBD, yet my rears are 100% totally gone down to bare metal after 30k miles and my front almost look like they haven't been used at all, perhaps 10-15% used.
Should I be looking at potential issues, or is this just how they are?
Azrei is offline   Reply With Quote
stock 02-03 late wrx front and rear brake pads 90% pad left, cheap camber bolts fastwrx25 Suspension/Brakes/Handling 10 09-15-2009 02:38 PM
Slightly more worn tires front to rear, ok for track day? xcdhridr Tire & Wheel 1 05-31-2007 10:11 PM
Rear brakes wearing more than front.. why? captaind Brakes, Steering & Suspension 1 04-19-2007 10:20 PM
rear brakes are more than fronts. wtf? rjrutzky Brakes, Steering & Suspension 7 05-31-2006 08:57 PM
Trailing edge of brake pads more worn fliz Brakes, Steering & Suspension 3 01-11-2006 02:56 PM
