Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-04-2012, 01:46 PM   #1
Fernie_rex
Member#: 241991
2004 Impreza WRX
Default Struts & springs combo for an 04 WRX
Before you guys attack me, yes i have been doing my research, but no i havent found a thread that talking about struts, just springs. or good combos for WRXs.
Basically, im looking to freshen up my suspension for an 04 WRX. I dont want coilovers due to the money and the fact that I dont need to adjust camber, ride height and the whole shebang for DD & spirited driving with an occasional autox event. All i want from my suspension is a decent to smooth ride, a 1in-1.5in drop at most, because lets face it, stock height is just wwaayyyy to high lol.
i will say i think the suspension has 90K miles on it since the original owner probably didnt buy a new suspension (i got it at 70K), which i think is a bit much, but ill let you guys be the judge.
I already have Group N tophats and I bought a set of 04 STI USDM springs light on the miles. I guess all i need now are some struts to go along with it. Ive been thinking of koni inserts since everyone raves about them, but im not mechanically prepared to do everything myself since i dont have most of the tools i need in order to make them. But if anyone finds that there are other spring/strut combos that work well for what I am looking for as well please feel free to comment.
Or if you think what i already have is good enough let me know!
Thanks for looking guys
Fernie_rex is offline   Reply With Quote
Old 01-04-2012, 02:33 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
If you're just looking for a decent oem replacement i would look into the Tokico HP's. They're a little more performance oriented then the stock struts and will hold up to aftermarket springs better. I ran them with Tein S techs and really liked the set up for a DD.
Mike
GrimmSpeed is offline   Reply With Quote
Old 01-04-2012, 03:26 PM   #3
Web Foot STi
Member#: 39086
2004 STi
OEM '04 STi struts revalved by Feal, or D-specs. The used STi struts and revalve will be a little less expensive depending on your cost for used struts. Do you want custom valving, or adjustability and new?
Depending on where you buy the Koni are ~$75 less than the D-specs with 921 spacers, but you know about the extra labor for the Koni's.
Oh, and the heaver STi is ~10mm lower than the WRX. The OEM springs may not give you the drop you want.
Web Foot STi is offline   Reply With Quote
Old 01-04-2012, 05:07 PM   #4
Fernie_rex
Member#: 241991
2004 Impreza WRX
Im going to look into the Tokico HP's. yeah im looking for a bit more performance
i would just rather not mess with revalving myself because i dont want to ruin the struts. I read somewhere that the STI springs with stock struts only drop it about 5mm-3mm from stock, (not 100% sure). besides i gotta them for a killer deal, $75!
Old 01-04-2012, 06:14 PM   #5
Web Foot STi
Member#: 39086
2004 STi
A lot of the extra weight in the STi is the tranny and one of the reasons the WRX doesn't drop as much with the STi springs.
Feal revalves the STi struts. To us they are bolt on, but tuned for your application. No one that I know of revalves the WRX struts. The WRX OEM struts are sealed units and the OEM STi struts can be disassembled.
FYI Look under 2004-2007 Subaru, STI, Dampers.
http://www.rallyracingsuspension.com/
Old 01-05-2012, 11:46 AM   #6
Fernie_rex
Member#: 241991
2004 Impreza WRX
right i understand the weight issue.
I guess for right now ill be looking for some STi struts, but with the added cost of having them revalved it might just be a better buy to get some new struts. ill probably want some new springs as well to match them. it seems like one answer leaves harder questions lol
Im going to start saving up for this, i dont wanna go wrong in this. anyone else has an opinion?
Old 01-05-2012, 11:57 AM   #7
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
What's your budget?
Byzantium is offline   Reply With Quote
Old 01-05-2012, 11:59 AM   #8
Web Foot STi
Member#: 39086
2004 STi
Originally Posted by Fernie_rex View Post
...it seems like one answer leaves harder questions lol
Usually does.
Old 01-05-2012, 01:27 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
There are many good options out there as some have mentioned. The least expensive that I would consider is the Tokico HP's. They are non adjustable, but work well with a variety of springs and are inexpensive. You already know about konis and Dspecs which are adjustable, but a bit more expensive. STI struts if you do them would definitely need to be revalved at this point as any that will fit your car are getting old and worn out.
Let us know if we can help. We have access to everything.
Tony
Old 01-05-2012, 03:59 PM   #10
Fernie_rex
Member#: 241991
2004 Impreza WRX
budget, i looking for around $700 if i decide to get springs. but with just the STi springs i have now i don't want to spend more than $500, plus any labor that i might be paying for.
Ill be looking around if i can find a good deal for STi springs to be revalved. Thanks Tony, when and if I'm ready for revalving ill be sure to contact you guys for pricing how the process works.
Old 01-06-2012, 02:33 AM   #11
NcKidd
Member#: 133267
2004 psm WRX
mucho door dingo stg 2er
Tokico D-specs and any good pair of springs is a great setup...I am beyond happy with mine.
Depending on how many miles on ur car, you mite wanna consider replacing the tophats as well.
NcKidd is offline   Reply With Quote
Old 01-06-2012, 10:35 AM   #12
MyRuRex
Member#: 21349
02 WRX Wagon
I just did this recently... STI Springs / 04+ Grp-N tophats all around / KYB GR2 - 04+ Wagon
I like the stance... The GR2's are similar to the HP's I believe, about 10-15% stiffer than OEM. Got them for $270 shipped. OEM Springs is suppose to lower like 10-15mm only. Little bouncy on certain roads but a nice DD, nonetheless.
I previously had Swift springs on AGX's which was very nice but I needed to soften things up a bit for my baby on the way. I guess the change to 16" wheels helped also
BUT If your budget allows, I would do the D-Specs to match it to the springs better.
MyRuRex is offline   Reply With Quote
Old 01-07-2012, 03:17 AM   #13
Fernie_rex
Member#: 241991
2004 Impreza WRX
I already have the group n top hats, I'd jut rather wait until I have the whole new suspension parts.
Nice wagon, thats the perfect wheel gap i want, about 3 fingers. Wait so you're telling me that the STi springs go well with the Dspecs? And as for your past set up, about how much did it cost?
Old 09-10-2013, 10:58 PM   #14
Boxer4turbo2004
Member#: 106190
Tony
I have a 04 sti and have a set of karlton flares with my volks..and have about 70k miles on my stock struts.. with the flares I don't think I need any camber adjustments with that said I want to lower the car 3/4 -1" are you saying you can insert the tokico in the stock housing and make it new then put a lowering spring and get the car lowered and have a better suspension than most coilovers under $1,500? if so where do I sign up..do you guys do the work if so give me some info. and you say the konis are adjustable..what exactly can you adjust? and is it worth the extra money..thanks
Boxer4turbo2004 is offline   Reply With Quote
WTB: Coilovers or Strut & Spring Combo for 02 WRX KitchenerWRX Private 'Wanted' Classifieds 4 03-19-2010 11:21 AM
WTB: Aftermarket Strut and Spring combo for 2004 STI sonic03rex Private 'Wanted' Classifieds 4 02-17-2009 01:12 AM
impreza strut and spring combo for $80 fungalex Private 'For Sale' Classifieds 0 04-18-2006 08:34 AM
FS: GC8 Tanabe Sustec H strut & spring combo skater3820 Private 'For Sale' Classifieds 1 01-23-2006 05:07 PM
how do i make KYB AGX struts for an 04 wrx sedan fit my 02 wrx sedan? dln84 Brakes, Steering & Suspension 7 05-26-2005 01:33 PM
