Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Old 09-10-2013, 05:22 PM   #1
knighthawk1104
Member#: 241940
2011 WRX Hatch
Default SMY's Rigid Collars coming soon!
Honestly, I was skeptical. Most people were skeptical as well. Let me tell you, these little things make a world of a difference. The road I take every day to school has bumps that I know to avoid. I hit most of the bumps that I know wouldn't damage my suspension or wheels and they were so much smoother.
Install should be no more than 45 minutes to an hour. Four subframe bolts up front and four subframe bolts in the rear. I don't have pictures but SMY, where I got the collars from, has all the pictures and I will try to get some to post up. If you have any questions you can message me and I will try to answer all your questions to the best of my knowledge. If I don't know I will try to ask and get the correct answers. These things are amazing. These will be officially for sale when all the fitting issues are sorted out. Thank you for reading!!
knighthawk1104 is offline   Reply With Quote
Old 09-10-2013, 07:06 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
stop spamming all over the place
PARANOID56 is offline   Reply With Quote
Old 09-10-2013, 08:30 PM   #3
knighthawk1104
Member#: 241940
2011 WRX Hatch
lol i figured more people go in general than here.
Old 09-10-2013, 08:50 PM   #4
meat_WRX
Member#: 96919
2004 sti
black
and no picture or link?
meat_WRX is offline   Reply With Quote
Old 09-11-2013, 03:29 PM   #5
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
and SMY said only STi kits were available.
how did you get a WRX kit?
how much does it cost?
stop being vague and give us answers!
gsrcrxsi is offline   Reply With Quote
Old 09-11-2013, 03:52 PM   #6
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
sooo, was your car used to design and fit prototype wrx specific collars? did you have fitting issues?
did you install these yourself? is complete removal of the subframes neccessary?
+1
isotopesope is offline   Reply With Quote
Old 09-11-2013, 04:01 PM   #7
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
im going to assume that you can probably slide these in without full removal of the subframe. just take the bolts out, drop it down, then slide it back in place and tighten the bolts.
the inserts are probably only about 1" height. youll need an alignment afterwards.
Old 09-11-2013, 07:30 PM   #8
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
cool, thanks! so, i still have yet to install my whiteline rear subframe bushing inserts, and i know i can just lower the rear subframe to get those installed... but is it a good idea to get an alignment even after just installing those?
or is it really a matter of the front subframe becoming repositioned and thus needing an alignment?
