Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 05-26-2011, 02:55 PM   #26
weirdpuffy
Member#: 171262
2001 2.2 WRXRS
Silver Thorn Metallic
brand new hardware
So as of right now, to complete my shortblock parts list, i need rods and bearings (Eagle H-beam rods & ACL race bearings). Pretty easy to find, but just trying to shop around for the right prices. Hope to start assembly of the block next week and then get it balanced while the heads will be worked on.
weirdpuffy is offline   Reply With Quote
Old 05-28-2011, 10:07 PM   #27
Spec R
Member#: 187752
99 RS/X5/Volt
nicely done on the determination and learning things the hard way. If I dont have the correct tools, I simply cant rig stuff. I guess its my training from school holding me back.
subscribed for another EJ205 equipped STM GC.
I'll definitely go through this thread if my motor pops - which we all know is a matter of "when". EJ205 bearings = Rotary Apex seals haha
I'll also hit up that subaru guy for some random parts as Im in socal also.
Spec R is offline   Reply With Quote
Old 02-03-2013, 06:08 PM   #28
mrchyes
Member#: 294069
98 Forester
Green
very interesting to see. im currently working on getting a EJ205 needing to be rebuilt.
I will for sure check back here when i tear it down!
mrchyes is offline   Reply With Quote
Old 02-11-2013, 07:49 PM   #29
WelDun1
Member#: 249130
1999 Ver5 STi RA
Just curious, you say this is an 04 ej205 right? Is it an 04 WRX block with a STi intake mani? The only reaso I ask is cuz the 04 STi is an ej25. I'm not trying to correct u at all, I just got confused. Anyways, I'm about to rebuild a ej207, and I was curious as to where you got the gasket.kit?
WelDun1 is offline   Reply With Quote
Old 02-17-2013, 04:23 PM   #30
weirdpuffy
Member#: 171262
2001 2.2 WRXRS
i got the OEM gasket kit from the subaru dealership. And yeah the STi manifold did not work out. Your going to have to make a custom plate to get the wire to work with the IM. Good luck on the 207 build!
Old 09-11-2013, 11:58 PM   #31
Shinji Hirako
Member#: 301002
08 Impreza Wrx
nothing new?
Shinji Hirako is offline   Reply With Quote
Old 10-05-2013, 10:28 AM   #32
Wr3nch0matic
Member#: 355648
2000 Impreza 2.5RS
Red
Originally Posted by weirdpuffy View Post
Ok then i ran into a minor road block again. I was removing all the cam gear bolts using a 10mm hexbit, then all of suddenly i snapped it. Took about 30 minutes to go to lowes and replace it with another. Lowes lady informs me that they wont be carrying hexbits anymore so if i break another one of these in the future i have to buy snap ons or craftsman. :wtf:
eff lowes:monkey:
So a trick I learned from a guy who works on his own Porsche is to smack a stuck bolt with a hammer and drift. Hit it from alternating directions and then head on with the socket in place. Do this a few times (8-10 blows total) and you'll "wake up" the bolt - that's a Porsche term - and it totally works. Saves broken tools and stripped bolts.
Wr3nch0matic is offline   Reply With Quote
Old 10-05-2013, 12:25 PM   #33
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
^^ like he said, tighten the bolts a bit first then it should crack the loctite, rust, or corrosion so then you can unscrew it. It took me so long to learn that little trick
bigolrig is offline   Reply With Quote
Old 06-07-2015, 12:26 AM   #34
codbeastyou
Member#: 358737
2001 impreza 2.5rs
blue
how far are you now? i am building my EJ205 and don't know that much about building them.
thanks,
justin(codbeastyou)
codbeastyou is offline   Reply With Quote
Engine Maintenance & Rebuild Parts! S&R Performance Engine/Power/Exhaust 1 07-13-2010 01:56 PM
2-pot brake expert needed & rebuild kit stigc8 Brakes, Steering & Suspension 28 02-13-2009 07:09 PM
Need Some Info on EJ205 rebuild jamesfacts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-05-2005 03:22 PM
EJ205 possible disassembly and rebuild, options and routes? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-09-2004 10:46 PM
Got a question about brake caliper specs & rebuild kits Legacy777 Brakes, Steering & Suspension 2 06-20-2002 10:03 PM
