Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 09-13-2013, 02:42 PM   #1
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Default Cable speedo VSS compatible with WRX VSS signal?
So despite the fact that my hybrid swapped OBS goes like hell, my lack of a VSS signal to the ECU means a fuel cut between 5-5.5k rpm. No bueno.
My car is a 97 with the cable driven speedo. The cluster has a vss that sends a signal to the ECU/Cruise/TCU in the stock configuration. Just wondering if it's within reason that if I tap that output, and run it to the WRX ECU input, that it may work. Would love to know if someone has already done it so I can avoid installing a 3 wire VSS and losing my speedo.
I don't have an oscilloscope available to track waveform output and see if they're the same, but being how "Lego" Subarus tend to be, I'd be surprised if it wasn't the same as the 3 wire.
cal_look_zero is offline   Reply With Quote
Old 09-13-2013, 03:02 PM   #2
RSmatt
Member#: 8039
94 v2 STi RA - RHD
It will work. Just tap the VSS wire going from the cluster to the ecu. This is how the VSS works with the cable driven clusters.
RSmatt is offline   Reply With Quote
Old 09-13-2013, 03:13 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Yeah, I figured as much. I'll tap it later and make sure the car is happy. Fuel cut that early is really harshing my groove.
EDIT: Thanks for confirming though. Can't get a straight answer on rs25.
