Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 09-04-2013, 03:22 PM   #1
Portland Dave
Member#: 59891
Default Used TDC when installing timing belt on rebuild.
As the title says I used the wrong mark when installing the timing belt and figured that out when she wouldn't start. It's a new engine rebuild. I understand that the engine is an interference design in respects to the valves but what about the pistons to valves? The engine turned freely by hand. By my figuring, if the pistons are lagging the valve train by 90 degrees then only the intake valves are at risk. I also read that possibly Subaru may have engineered the engine so that there is no valve to piston contact. Has anybody (not afraid to admit it) done this and was able to correct the timing without damage? Thanks.
Portland Dave is offline   Reply With Quote
Old 09-04-2013, 04:01 PM   #2
Dillinja666
Member#: 332644
07 STI
It's white
Yep, if you can spin it by hand you didn't contact. You know when you contact cause you can feel it unless you were using a huge bar when you were turning the motor over and bend the valves by hand. Re-set your timing belt and give it another go.
Dillinja666 is offline   Reply With Quote
Old 09-04-2013, 04:28 PM   #3
Portland Dave
Member#: 59891
Hmmm, when I said by hand I meant using a socket and breaker bar. The only thing I think I ever felt was resistance when the valves were compressing.
Old 09-04-2013, 04:45 PM   #4
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
That sounds normal. You can take the spark plugs out to eliminate the compression variable and see how freely the engine spins. If timing is off enough then the pistons will hit the valves After a little google digging, some people have done the same thing (crank 90 degrees off) with no ill effects...
http://bbs.scoobynet.com/general-tec...ming-belt.html
...As Dillinja said, I'd reset the timing and see where that puts you. If the engine rotates freely with the cams and crank correctly aligned (take the spark plugs out to get a better feel) then I would just fire it up. I think the alternative is to remove the heads and check all the valves and pistons for signs of impact. I definitely would not do that, but if you wanted to be 100.00% sure, that's the way to go...
tibug is online now   Reply With Quote
Old 09-04-2013, 05:31 PM   #5
Portland Dave
Member#: 59891
The engine was on the bench with no plugs when I checked it. Thank for the link, my searches never pulled that one up. My hope is that the intakes are starting their way closed when the piston reached top and you get a near miss instance.
Old 09-04-2013, 10:29 PM   #6
Dillinja666
Member#: 332644
07 STI
It's white
Ya man you're fine. Ive seen these things scary far off and after a correct installation of the timing belt run perfect. If you made it around by hand with a breaker bar and you were not giving it serious effort to actually bend a valve by hand you're fine to reset everything and throw it in the car. The poor subarus I have seen roll into my shop when I was spinning wrenches would make you cry sometimes. Couple teeth off timing wise on a hand spun motor = no issues. Hell I had one where the guy kinda did the same thing cept he couldn't make it spin all the way around so he brought it in. I thought he had something 180 out and tried every combo of cam/crank there was. I ended up pulling off the head thinking he bent something and found the hose clamp for the fuel line had fallen in the cylinder while he had the heads off and he didn't see it. Slapped it back together with a new head gasket ( guess the right side the first time!) and off it went.
Old 09-07-2013, 05:58 PM   #7
Portland Dave
Member#: 59891
I got the timing straightened out and she started right up. I ran her for 10 min at 1500 rpm. Stopped allowed her to cool off and topped off fluids.
Now another issue has come up. At a cold start everything sounds good but when the engine gets up to temperature I get a knocking sound that I've narrowed down to the left head on the exhaust side. A consistent volume just above the normal valve train noise. Reminds me of a bad lifter but we don't have those. Sticking valve?
Old 09-07-2013, 06:12 PM   #8
Dillinja666
Member#: 332644
07 STI
It's white
valves adjusted properly?
Old 09-07-2013, 07:03 PM   #9
Portland Dave
Member#: 59891
As far as I know, I had Bearing Service here in Portland OR do the work. New seals, guides, passing leak down test.
Old 09-13-2013, 10:04 PM   #10
Portland Dave
Member#: 59891
Well, yes these are interference engines and yes the pistons did hit the intake valves on all cylinders. No use screwing with it so back to the shop for the heads.
Old 09-15-2013, 11:21 AM   #11
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
That sucks dude. Did you not have a shop manual handy when you set the timing? I could forward you a copy of the procedure if you don't have it.
Old 09-15-2013, 10:52 PM   #12
Portland Dave
Member#: 59891
Thanks, but I do have a manual and stupidly got the marks wrong cause I wasn't paying close attention. The manual really stresses on how to properly move the cams when attaching the belt but has a one liner for the crank markings. Any suggestions on good replacement valves?
