Old 09-15-2013, 06:54 PM   #1
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
Default Newb turbo question - URGENT!
Hey guys I've been hearing this noise come from what i think is the turbo
happens in high gear when im at low rpm, low mph. when i step on it its like before the turbo is spooling or as it just starts to spool
hard noise to explain but after it gets to around 2-3k rpms it starts to spool and push air as normal.
not sure if thats normal cause the turbo is just spiining without any air coming through or what. PLEASE HELP!!
I have 3 video clipss but cannot figure out how to add them in here
Mrbojangles019 is offline   Reply With Quote
Old 09-15-2013, 06:55 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
upload to youtube then post link
Shortpersonbk is offline   Reply With Quote
Old 09-15-2013, 07:01 PM   #3
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
You should have a warranty, take it to the dealer.
Chicago AJ is offline   Reply With Quote
Old 09-15-2013, 10:16 PM   #4
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
Old 09-15-2013, 11:28 PM   #5
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
try shifting so you don't have that situation?
A man goes into a doctor's office and says, "Doctor, every bone in my body is broken! It hurts whenever I touch it with my finger." The doctor looks over and says, "Well don't do that."
I think I combined two jokes and didn't get either of the punchlines correct. But if you're only hearing the noise while doing something you shouldn't be doing (low RPM high gear)... Don't do it.
Or warranty.
Old 09-16-2013, 12:28 AM   #6
jimbosv650
Member#: 261307
04 wrx wagon
Downshift
jimbosv650 is offline   Reply With Quote
Old 09-16-2013, 12:55 AM   #7
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
No warranty. and I usually don't im just wondering why its like that. is that normal for a turbo if youre in a high gear at real low rpms?
Old 09-16-2013, 01:05 AM   #8
sWagonRX
Member#: 324522
2005 WRX Wagon
Or warranty.
I think the punchline is "You have a broken finger" or something to that affect lol.
As far as the noise, it doesn't sound too bad. If it is a concern though,just take it in.
sWagonRX is offline   Reply With Quote
Old 09-16-2013, 01:26 AM   #9
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
Yeah, ill try to get a different video. I can hear it clearly in the car. I'll have someone take a look at it when i get tires and brakes done
Old 09-16-2013, 02:39 AM   #10
btc2112
Member#: 322981
2012 WRX 5 Door
Or warranty.
^^^ this
Is exactly what I told him in his other thread he started about the exact same problem. I nailed the punchline though :-)
"My car sounds weird in high gears at low rpm when I stand on it..."
Then dont go WOT in high gears at low rpm. Duh.
Op-take your car to a mechanic and use your warranty. You really trust strangers to diagnose your "sound" over the web?
Yeesh, good luck with that, maybe you can just throw $$$ at the noise until it goes away. Start with the harmonic dampener, sounds like it might be loose...
btc2112 is offline   Reply With Quote
Old 09-16-2013, 02:54 AM   #11
Swan1234
Member#: 347448
I have an 02 wrx w/2.5 and I can get to make all kinds of noises and rattles and vibrations driving "wrong". Best advice would be to check plugs, keep oil and coolant topped off, and if you have the money gather some data logs via cobb AP or opensource w/ Tactrix cable; if all check out good don't worry about it.
Swan1234 is offline   Reply With Quote
Old 09-16-2013, 04:23 AM   #12
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
not like im gonna start throwing money out cause someone told me whats wrong. but its a good place to start. thats what these forums are for.
Old 09-16-2013, 01:55 PM   #13
Freep
Member#: 238640
2007 WRX STi
Built wrb (Sold)
It's normal, you are bogging the motor. You are too low in rpm for that high gear to be thinking about going WOT...don't do that. Downshift if you want to WOT on the freeway at that speed.
Freep is offline   Reply With Quote
Old 09-16-2013, 02:10 PM   #14
the suicidal eggroll
Member#: 51961
2005 STi
You're doing something you shouldn't, and the car is letting you know.
You shouldn't even be cruising in high gear below 2k RPM, much less going WOT...stop abusing your car and it'll stop making scary noises.
Old 09-16-2013, 02:22 PM   #15
btc2112
Member#: 322981
2012 WRX 5 Door
^^^This
^^^And this
You're bogging your motor, stop it.
Old 09-16-2013, 03:43 PM   #16
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Downshift, your car is crying out in pain.
Napalm3nema is offline   Reply With Quote
Old 09-16-2013, 03:53 PM   #17
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
I can hear what reminds me of waste gate flutter. Is it the slight hissy, fluttery noise you're talking about? You haven't mentioned if you have any performance mods or a tune added to your engine so I can't comment on whether that would intensify the noise you're hearing.
If you shift down a gear and step on the gas, you don't hear that same noise at all? Are you sure? Maybe it just happens more quickly since the turbo is creating boost sooner?
Gallo2011 is online now   Reply With Quote
Old 09-16-2013, 03:58 PM   #18
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
+1 for bogging the motor, your engine HATES this. Downshift and dont go WOT in 5th gear.
shamrock 05 is offline   Reply With Quote
Old 09-16-2013, 08:01 PM   #19
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
I think it seems like im bogging motor. my car is completely stock still.
Old 09-16-2013, 09:29 PM   #20
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Well, easy fix then. I find that my engine is happiest when it's at least at 2500 rpm in the lower gears and 3000 rpm in 4 5 and 6. Your gearing is taller than mine so I would say try to keep your engine at those rpm at a minimum. Cruising at 3000 rpm isn't going to hurt anything and is where the engine is ready to quickly build boost.
Old 09-16-2013, 09:37 PM   #21
Member#: 51961
2005 STi
A little higher than I like to keep it on my '12 WRX, but not much.
For accelerating I keep it at at least 3k, for cruising I'm typically between 2-3k. If traffic accelerates and I reach 3k in whatever gear I'm in, I upshift. If traffic slows down and I reach 2k, I downshift. 2-3k is the window that I stay in while cruising. If I need to accelerate more than about 20% throttle, I just make sure I'm above 3k.
Add about 1k to those numbers for my STi, but that's mostly because of the cams.
Old 09-16-2013, 10:14 PM   #22
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
knock knock knock... hello?
Mr. Lin is offline   Reply With Quote
Old 09-17-2013, 12:00 AM   #23
Mrbojangles019
Member#: 364936
2013 Focus ST3
Moondust Silver
Yeah I just got the car so I've kinda been driving like a bitch lol. cruising through town at super low RPMs, shifting at like 4k. Doesn't help i got a ticket the first day i had the car when i got on it a little. thanks for the .02 though everybody that seriously answered.
Old 09-17-2013, 12:05 PM   #24
btc2112
Member#: 322981
2012 WRX 5 Door
Or warranty.
Originally Posted by jimbosv650 View Post
Downshift
Originally Posted by btc2112 View Post
^^^ this
^^^This
^^^And this
Originally Posted by shamrock 05;40605489[B
]+1 for bogging the motor, your engine HATES this. Downshift and dont go WOT in 5th gear[/b].
Oh really. You think it seems like you're bogging the motor?
Knock knock...Mcfly...hello? Anybody home?
Old 09-17-2013, 01:03 PM   #25
Masta Splint
Member#: 189211
2005 18g WRX wagon
I would say the general concensus is your bogging your motor and should stop. Why this was even a question that got asked I have no idea. This should be common sense to not do this.
Also you shouldnt be driving like a granny to break your car in, yes you should try to shift most of the time at about 4kfor the first 1000 miles, but you want to be in boost a lot, really get the turbo working and I dont mean slamming threw the gears and going WOT. You can tell when you hit boost and it doesnt have to be WOT, its just in certain rpms in certain gears you want to be in and out of boost a lot and every once in a whole yes go WOT to open the car up. But you def. want to be fluctuating in and out of boost often during break in so your rings seat correctly.
Masta Splint is offline   Reply With Quote
