Old 09-15-2013, 09:56 PM   #1
09wrbrex
Member#: 350382
2009 WRX
Default Hill assist, traction control, abs lights, no codes?
So twice in the last week my 09 wrx stage 2 has thrown on my abs, hill assist, and traction control lights. They go off once I restart the car but then come back and when I plug In my accessport no codes show up. So I've done some research and many threads say it could be the brake light sensor, but they also had three codes pop up and I have no codes. So could just adjusting my brake light sensor fix it or could it be something else? Thanks in advance!
09wrbrex is offline   Reply With Quote
Old 09-15-2013, 10:13 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Utilize your warranty?
Old 09-15-2013, 10:47 PM   #3
09wrbrex
Member#: 350382
2009 WRX
I'm well past the bumper to bumper warranty and i like to avoid the hassle if the dealership as much as possible. Especially if it's just a cheap sensor
Old 09-16-2013, 01:57 PM   #4
sk8eroyaker
Member#: 328067
2008 Impreza WRX
2008 wrx here. I've had the same thing happen to me two or three times. All the lights come on but no codes stored in the ECU. I've also read that it could be a faulty brake light sensor. Has anyone sucessfully fixed this problem?
sk8eroyaker is offline   Reply With Quote
Old 09-16-2013, 02:26 PM   #5
09wrbrex
Member#: 350382
2009 WRX
Yea all the threads I've read where people replaced the brake light sensor, said they had codes in the ECU which we don't so I'm hoping someone can help us out lol
Old 09-16-2013, 03:39 PM   #6
Member#: 301037
2004 Forester XT
Chances are the darn dealership would say "I bet it is something wrong in the ecu adjustments that tuner you put on it did"
art@grimmspeed is offline   Reply With Quote
Old 09-16-2013, 05:45 PM   #7
09wrbrex
Member#: 350382
2009 WRX
^^^ Yea after they charge me $100 to maybe find the problem lol I guess I'll just try adjusting the brake light sensor and see if that helps
Old 09-16-2013, 09:05 PM   #8
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
" That tune you put on retarded the brake bias too much and wore your rear brakes out. You're gonna need new pads and rotors."
Did I get that right?
Gallo2011 is online now   Reply With Quote
Old 09-16-2013, 10:03 PM   #9
wadowrx
Member#: 343621
2012 Impreza WRX
Dark Metallic Gray
I had this happent he other day after I installed my Cobb DP, I think I bumped the main connector attaching clip on the passenger side above and right of the turbo. I could be wrong but it was fine up until then, shut the car off, moved the connector down about 1/8" and then it was fine. I have under 18k onmy car fyi.
wadowrx is offline   Reply With Quote
Old 09-16-2013, 11:12 PM   #10
ryansx
Member#: 324527
2013 wrx
white
Your AP can't pull the codes. Abs codes are stored in ebcm not PCM. You have to find a scanner that will pull them(couple hundred $$ or more) or got to a shop/dealer to pull($100ish). Throwing parts at it will end up wasting money. If you really suspect it's your brake switch, when it acts up find a reflective surface you can back up to and see if brake lights work or if they come on by themselves without touching pedal. Note:that may or may not give you answer.
ryansx is offline   Reply With Quote
Old 09-17-2013, 03:52 PM   #11
09wrbrex
Member#: 350382
2009 WRX
Oh I didn't know that, that sucks lol but yea my brake lights come on after pressing down the pedal pretty far so ill adjust the sensor anyways. I would really hate to spend the money at a dealer if it is just this $15 sensor so ill find out soon enough
Old 09-17-2013, 06:22 PM   #12
mistreater
Member#: 332710
09 wrx
dgm
Had this on mine 2 months after buying it. No codes etc. Replaced BLS, fixed it.
Also set it so the brakes actually come on when I pressured the pedal.
mistreater is offline   Reply With Quote
Old 09-17-2013, 06:50 PM   #13
mosnowbro
Member#: 362312
2013 Impreza WRX
WR Blue Pearl
I had the same thing a month ago on my 2013 wrx stock tune. Restart and haven't seen it since
mosnowbro is offline   Reply With Quote
Old 09-17-2013, 06:57 PM   #14
mikereiser
Member#: 291941
2010 Wrx sedan
Hope this helps, originally posted by eric at torqued performance. Worked great in my 2010 wrx (i believe this is good for 08+)
Reading DTC's with the Combination Meter. It can also display ABS/VDC codes.
I got this from a customer and figured I'd share. No scan tool required and you can even read codes having to do with the VDC system(steering angle sensor,yaw sensor, wheel speed sensor, etc)
DTC DISPLAY MODE It is possible to display the DTC of the combination meter through the following procedures.
1) Within 3 seconds after turning the ignition switch to ON. set the lighting switch to tail light or headlight pos ition.
2) Press the odo/trip meter knob four times
. 3) Turn the lighting switch to OFF, and press the odo/trip meter knob four times.
4) Set the lighting switch to tail light or headlight position again, and press the odo/trip meter knob four times.
NOTE: Perform the steps described in 2) and 4) within 10 seconds.
When the engine starts during diagnosis, the self-diagnosis function is not cancelled, however, once turning the ignition switch to OFF or the vehicle starts driving, DTC display mode is cancelled automatically for safety.
When the DTC display mode operates, {ECM}, (TCM}, {ABS/VDC} is displayed cyclically in this order for every three seconds or every press of the trip knob. DTC is displayed in the following table according to type of control module, receiving DTC, DTC detected, No DTC. When the DTCs of individual control modules change from current malfunctions to past malfunctions, and the trouble is cleared, when the engine is started three or more times, the DTC will no longer be displayed in the combination meter.
Trip A displays codes for the ECM with PXXXX and the ABS/VDC system with CXXXX Trip B displays codes for the TCM with PXXXX. This only applies to automatic cars.
mikereiser is offline   Reply With Quote
Old 09-18-2013, 01:12 AM   #15
dannyngnX
Member#: 303207
2012 Wrx
Pearl freakin white
In for this thread.
happened to me twice since i owned my wrx, scared the $hit out of me every time it happens.
i thought it was something to due to my axcessport tune.
but just turn the car off and everything is back to normal. or is it? any ideas whats going on?
dannyngnX is offline   Reply With Quote
Old 09-18-2013, 06:44 PM   #16
ryansx
Member#: 324527
2013 wrx
white
If this works that would be awesome
Old 09-19-2013, 10:02 AM   #17
masterforce
Member#: 221580
2011 WRX STI
Maybe your wheel sensors need to be cleaned or they are broken?
masterforce is offline   Reply With Quote
