Old 08-02-2013, 06:26 PM   #176
rileymeister
Member#: 344583
rgold01- could you please measure the distance from the ground to bottom of the receiver? Just trying to figure out if the rack I am planning to use (kuat sherpa) will scrape when I enter my driveway. Much appreciated!
rileymeister is offline   Reply With Quote
Old 08-02-2013, 08:16 PM   #177
rgold01
Member#: 69102
9 1/4 inches from the bottom
rgold01 is offline   Reply With Quote
Old 08-02-2013, 09:21 PM   #178
rileymeister
Member#: 344583
Thanks!
Old 08-06-2013, 10:24 AM   #179
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Has anyone here got information on attaching brake lights to a trailer on this car? I'm not interested in towing anything serious, but I would like the ability to tow a light trailer with bikes or something like a small uhaul trailer with personal belongings. I know the car can handle it (obviously since it's rated for 1200kg in Australia), but I'm not sure about wiring up brake lights and such, which are, obviously, critical.
Dirt Bringer is offline   Reply With Quote
Old 08-06-2013, 07:54 PM   #180
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
This is what I got and its great. Involved no splicing, but you do have to run a lead off your battery:
http://www.etrailer.com/Custom-Fit-V...leid=201215499
Blur125 is offline   Reply With Quote
Old 09-01-2013, 12:47 AM   #181
MrLebreen
Member#: 344816
2012 Impreza 2.0i
Dont hate but i actually want to put on a Tow Hook to my ride to match the colour way, is there anyway with installing it without buying the big hitch setup?
MrLebreen is offline   Reply With Quote
Old 09-05-2013, 03:56 PM   #182
clarisax
Member#: 367378
Impreza 5-door
Default newbie question
Newbie here. Thanks for this discussion. I'm concerned about the process of enlarging the forward holes to install the Curt hitch in my new '13 Impreza. Does anyone know if this will accelerate rusting when the metal was filed?
And does anyone know if there is much problem with the clearance below the receiver - does it scrape on driveway entrances?
clarisax is offline   Reply With Quote
Old 09-06-2013, 12:32 AM   #183
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
I really would recommend the Torklift hitch. 1.25" or 2" sizes, completely hidden and tucked away, and no drilling/cutting required to install. It is worth every penny.
http://shop.tlcentral.com/store/pc/2...1-25-p1094.htm
DKsiazek is offline   Reply With Quote
Old 09-06-2013, 12:05 PM   #184
clarisax
Member#: 367378
Impreza 5-door
Thanks. It looks great and I like the fact the it will be a couple of inches higher than other hitches; I'm just concerned about the installation. Did you have to remove the bumper to install? And is it easy to each under to install the pin or bolt?
Old 09-06-2013, 08:55 PM   #185
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I followed the directions that the invisi hitch came with and wish I had not. It's so much easier if you do it this way:
Yes, you need to shave some metal to get the parts through the holes, but that's easy, especially with the car lifted a bit. You would need to swap out the round spacers the invisi hitch comes with for some of the square ones shown in that video...I wish I would have seen that video prior to when I installed mine... The directions have you go through the top of the trunk and there is NO way you can cut through it without a step drill. They mention "wire snips" or dremel in the directions...HA! I'd like to see a video of THAT.
EDIT: At mniute 2:13 in the video, you'll have to drop the muffler to fit the invisi-hitch. Very simple and you can just use some rope/bunji to support the muffler while installing.
Old 09-06-2013, 09:05 PM   #186
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Did you wire it yet? Going to do mine this weekend. Only towing a 12' fishing boat (500lbs) with my hitch.
Old 09-06-2013, 09:57 PM   #187
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
I followed the instructions that were included, which were to remove the bumper. It really only took a few hours, and the plus was not having to file open a few holes.
As far as putting in the pin, I ended up cutting about 2 inches off the black plastic lip that is under the receiver. You can not see it without getting underneath, but it makes a BIG difference when putting the pin in. No problems anymore.
Old 09-06-2013, 10:03 PM   #188
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
I did! I used the linked below adapter, required removing a bunch of interior panels but it wasn't too bad. I also used one of those add a circuit fuses for the interior fuse panel to get the power for the adapter.
Amazon.com: Curt 59146 Converter and Wiring Kit: AutomotiveAmazon.com: Curt 59146 Converter and Wiring Kit: Automotive
I used it to tow a 14' fishing boat up to Lake George to camp, towed very well behind the Impreza. Wished I had a few extra HP for some of the mountains, but overall went well.
Old 09-07-2013, 04:20 PM   #189
clarisax
Member#: 367378
Impreza 5-door
Thanks. I have a '13, so I don't know if your '12 is identical -- on the back side of the black plastic piece below the bumper, there is a plastic box directly behind the knockout opening. It must be for mounting the fog light. Is this what you cut away? I can't see how I can get the hitch past this box for installation.
Old 09-07-2013, 07:03 PM   #190
clarisax
Member#: 367378
Impreza 5-door
Torklift emailed me the instructions and answered my question. You have to cut away the housing for the fog light.
Old 09-09-2013, 02:54 PM   #191
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Thumbs up
Wow! Awesome post, exactly what I needed to see and know. I will be towing a 12" Aluminum with a 9.9 Johnson, so I'm guessing its under 500lbs.
Luckily, I won't be hitting too many hills, so the power of the 2.0l might be fine for my needs.
How is it launching the boat? You dippin the bumper at all?
Old 09-09-2013, 02:56 PM   #192
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
hehe yea I believe that was Step #1. No biggie either, I just used a mini hack saw.
Old 09-12-2013, 02:13 PM   #193
grog71
Member#: 228279
How do you guys feel about subaru and their warranty when it comes to the hitch. I so want to put one on but i do not want to run into problems if I have a problem down the road with the cvt. i hate towing the little boat in back of the tundra. I just cant see the thng back there.
grog71 is offline   Reply With Quote
Old 09-12-2013, 05:21 PM   #194
fistv
Member#: 350063
2013 Impreza sport
Like that hitch. Means I can reuse all my 2" stuff.
fistv is offline   Reply With Quote
Old 09-14-2013, 08:56 PM   #195
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
To me the Hitch use/availability outweighs the warranty. Haven't heard of any issues thus far.. I have a 2" Bike rack and aluminum boat. I'm thinking a utility rack hitch might help with adding more cargo capicity as well.
If stuff hits the fan, tow it home, remove the hitch, and take it in. Remember, the international 12' Impreza is rated for towing (650kg or 1433lbs unbraked; 1200kg or 2645lbs. Braked). I can't confirm the models are identical to US versions, but there's nothing to say that they're not.
If you're only using a hitch carrier of some sort and NOT towing, then I would not concern yourself with the warranty. The transmission and suspension are really the main factors to keep in mind when towing and possible warranty issues.
Old 09-17-2013, 02:16 PM   #196
grog71
Member#: 228279
It would be used for towing a 14 foot aluminum fishing boat. the weight is not to much and is way under the 1400 lbs.
I will just keep thinking about it and maybe someday get aggravated enough to just install one.
Old 09-17-2013, 04:46 PM   #197
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Can someone elaborate on this disclaimer?
Due to the invisi style of this hitch. All ballmounts/bike rack stingers cannot exceed more than 2-3/8” of an inch from the center of the pinhole to the end of the stinger. Failure to do so will cause ballmount/bike rack stingers to not fit or cause NON WARRANTIED damage to the exhaust system.
foghelmut is offline   Reply With Quote
Old 09-17-2013, 05:25 PM   #198
ans2k
Member#: 315631
2012 Impreza Sport
I asked the same question to the company. This is there response.
"Thank you for your interest in the Ecohitch for your Impreza. I have attached 4 photos showing a demonstration of the limitation of the stinger. The Insert (stinger) I have provided for the demonstration is 2.5 inches long from the center pin hole to end. It would hit the exhaust muffler if used in the hitch for your vehicle. The simple solution to this is to trim off 1/8 inch from the end of the insert (stinger). It then would not hit the exhaust system. Many bike rack stringers and inserts have lengths shorter than 2 3/8" inches from pin hole to end so they will work without any trimming. Make sure to measure all of your inserts/stingers ,as we have in the demonstration, to be sure yours will fit. Please also note that I purposely used a stinger that would not work for demonstration purposes to show that it will hit the exhaust if not properly addressed."
Old 09-17-2013, 06:41 PM   #199
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Due to the invisi style of this hitch. All ballmounts/bike rack stingers cannot exceed more than 2-3/8 of an inch from the center of the pinhole to the end of the stinger. Failure to do so will cause ballmount/bike rack stingers to not fit or cause NON WARRANTIED damage to the exhaust system.
Just a warning that if your stinger is too long from the eye of the hole to the rear, it will hit your muffler.
The only way it will damage your exhaust is if you were to ram it into the hitch like Ron Jeremy
Old 09-18-2013, 02:06 PM   #200
fistv
Member#: 350063
2013 Impreza sport
Oh well, so much for the flesh light stinger I was thinking about marketing...
2012 Subaru Impreza Sport trailer hitch? mckinnon99879 Interior & Exterior Modification 7 06-15-2012 10:17 AM
2012 Volkswagen Passat 3.6 SEL vs. 2011 Honda Accord EX-L V6, 2012 Hyundai Sonata 2.0 AVANTI R5 Non-Subaru News & Rumors 2 09-12-2011 10:02 AM
'08 Impreza 2.5i 4d Trailer Hitch Zell Interior & Exterior Modification 2 12-19-2010 08:59 PM
Providence: FS Impreza 93-06+ Class 1 Trailer Hitch / 2 Bike rack psyber_0ptix NESIC Private Classifieds 8 09-10-2006 07:03 PM
